stu w
Everything posted by stu w
When I have re-laid flooring in the past following on from someone else what has failed due to uneven sub floor I would say no the underlay will not absorb the deviations at around 6mm. I personally have and never will use a levelling screed over a timber floor, especially onto joists. What area is the floor ?
Take any fixing out in the high areas , plane the 6mm raised areas and any bad bits so all the floor is totally flat , re-fix then overboard with 6mm ply glued and screwed to get the strength back into the floor
Some are heavy yes depending on the size you are using . It's a straight forward enough job if installed properly and will save a fair amount of money. Yes just have to find a plasterer who is happy to render boards you have installed
I have used a mixture in the past on different builds ranging from tiling batten 35mm sq untreated etc . Personality I prefer a slightly larger void to stop anything puncturing the vcl . On my own builds or for friends I use 3x2 cls , dry, nice and wide for fixing your plasterboard and deep enough to protect the vcl and get electrical back boxes in etc
When you say cavity batten , do you mean for the service void internally, or for external cladding
My extension is similar structure, I am using 145 x 45 regularised , and the flitch beam is similar in size but the span is shorter at 2.5m I personally would increase your upstand to 50mm, it will meet up with the internal PIR and you can tape them together. Plus I have opted to use kingspan but the nyrock frame slab as it is 32 not 35 with 50 PIR internally then my vcl then service batten. What are you covering your sts with below damp , mosiac render or leaving plain ?
I have recently designed a flitch beam and had it passed by an SE . All depends on the total loadings , bolting pattern etc , the span shouldn't be a problem if designed correctly and the jack and King studs are adequate. Cold bridging wise , can PIR cover the internal beam to help ?
What is the opening span for the bi-fold doors
The work is poor , a facia board joint strip should be used but the intial join/cut should be alot better than the picture you have posted regardless. Silicone is not an acceptable way to close a joint
problems getting SWA into a CU mounted on plasterboard.
stu w replied to jpadie's topic in Consumer Units, RCDs, MCBOs
Strip the swa right back to the wall , put the cable into a 45 conduit elbow, then into the bottom on the CU -
Interesting video talking about procurement.
stu w replied to Square Feet's topic in Building Materials
Watching it Procurement is just a small section of his video . The majority of the topics he raises is due to lack of experience/knowledge rather than procurement. I see it regularly, customers taking on medium to large projects after studying youtube for 12mths and wonder why they come across issues and miss their budget because they feel their buying power should result in the same purchase prices as a time served tradesman, or just lacking in experience -
How to fill / seal gaps between skirting and hard floor?
stu w replied to embra's topic in Decorating
Orcon f , it does not crack or shrink like decorators caulk etc -
Sorry I read that as you were using the PIR externally 🤦♂️. All your questions answered, might be worth just reminding your plumbers ,electricians not to poke holes through the vcl once it's fitted , at times they don't understand the importance of the air tight barrier especially if the service gap is small
Thin STS insulated tile backer board , covered in EWI Mosaic thin coat render in black so no staining .
Roll of the dice mate , I find some don't check or spec, others are by the book
Whatever I've hung them that's what the BCO has requested yes , open towards main route of escape. Then you have the intumescent strip, handles,hinges etc if they are really fussy , and at times request a closer
Fire doors are predominately hung in the direction of escape
Mcalpine do a self sealing Tundish ?
How to find replacement kitchen drawer slides
stu w replied to laurence_b's topic in Kitchen Units & Worktops
A very slim chance you will find spares or the same drawers. You will probably be better just finding a drawer box with runners what fits your unit opening, then fix your original drawer fronts onto that. -
I have calculated this myself but want to get it checked so it can used
Thank you I certainly will , I will get the calculations/design confirmation back Monday/Tuesday. 20 years ago at university when studying the institute of wood science and technology course, I went on to do a short 18 month sister course, structural design in timber ( yes very basic but gave me some insight ) . I have done the loading calculations with snow etc and hands up used some previous designs what I have made on site from structural drawings with similar spans Very interested to see how mine compares with a structural engineers when he returns it next weeks . Still lots to learn with so many variables as you say combining timber and steel
I found with an extension they are ok as don't catch your eye, if you are toothing they will stick out like a sore thumb. Good thing with the ibstock is very little waste , last time I used LBC around half were unusable
Correct. If the right people are hired in the first place the tolerances should be all the same making everything straight forward
Yes it's always nice to have them all similar, quicker to work on also
