stu w
Everything posted by stu w
Difficult to tell from that picture, could just be discoloured from age or the sun, but could also be vac vac treated. I would say it's not pressure treated personally . Trim a tiny bit off the end and see if there is impregnation marks
Which glue for T&G (solid wood) floorboards to joists?
stu w replied to markocosic's topic in General Flooring
As said D4 Spax wirox flooring screw -
As said Hep is best and in my opinion a superior fitting to JG speedfit and polyplumb. Keep the pipe clean and scratch free, make sure ALL the pipe is cut using a proper cutter. Use the barrier pipe with the Hep stainless steel insert in every fitting . The majority of all new builds use this system now and if installed currently it is trouble free . One downside I have seen several times now is rodent attack
That's sorted then . Personally I would try and blend it in with your neighbours, a better job long term
As you say a bonding gutter can be used. Or speak to your neighbour and take a couple of rows of slate off their roof , felt abd batten it overlapping into the original roof and tie it all in properly. Just be aware the corrugated sheets could possibly be asbestos. A simple sample test will confirm this either way for about £30/35
No problem, they may well have security clips on the outside depending on the age of the windows , some deduct a few mm overall to allow a slight tolerance for this . Personally I have never had an issue.
If measuring from the inside on external beaded upvc windows , you need to add 15mm either side / top and bottom for the correct measurement: ie 30mm overall on the width and height of the DG unit off the internal bead, that's measuring off the plastic, not from the rubber gasket. Doing this will give you the same measurement if you were measuring from outside and taking 5mm off either side , so 10mm overall Ordering formula = Width,Height, Thickness, clear or obscure glass , then if toughened is required or just float .
STS, never had a problem on TF properties
Recommendation - private treatment plant
stu w replied to Lincolnshire Ian's topic in Waste & Sewerage
Marsh industries, they will answer any questions and supply -
Drilling through a brick pier
stu w replied to Steve1309's topic in General Self Build & DIY Discussion
A 32mm core drill would give you the neatest outcome -
Combi boiler filling loop placement and other peripherals
stu w replied to Del-inquent's topic in Other Heating Systems
As above , just purchase the internal filling link with your boiler -
Block Paving - Batch issues different shade
stu w replied to canalsiderenovation's topic in Driveways
The builder sounds a joke , just laying them with a colour match that far out is highlighting his poor quality and certainly his integrity. -
I would hazard a guess, where the paving has been stored, something has been spilt on them , it seems a little to sporadic for a whacker etc to leak like that looking at your pics -
The supplier will wipe their hands of any issues if your contractors go back to them with this, they clearly state in their correspondence and its common knowledge always complete an area in the same batch -
It is , and bricks , wall tiles , roof tiles, anything manufactured in batches , even same colour paints I mix together as they will always differ. Just a incompetent block layer or just don't care and just thinks about 💴💴💴💴 -
As said above, Personally I have found plasmor block paving very under par in the past especially in 50mm, I always use 60 but not plasmor Your block layer is either partially sighted or just don't care about the finish because he hasn't mixed the packs, even if he had with the colour differences it will still show Rip it up and use formpave/forterra for a far superior block and will last a lifetime -
Depending on how many windows and if internally beaded , you could just have new units made up with privacy glass is an option
- 1 reply
Plasterboard - supporting at perimeter?
stu w replied to low_and_there's topic in Plastering & Rendering
Personally I think it makes a better and easier job with noggins around the perimeter -
I just read your other post , sorry see it is trusses now rather than a cut roof . They All look good from the photos so can't see why doubling up would make any difference as been designed for the load
Good chance a cut roof , have a look in the loft and see what you can see if any rafter have pulled away from the ridge etc
Dig out around the 110mm pipe, fit a branch and come across to fit a proper gully , then take your waste into that
Removing outhouse wall, do I need a support beam?
stu w replied to spleenharvester's topic in Demolition
Impossible to tell from those pictures and description. Get a professional to advice you after looking at all the variables once a site visit has been done -
Planing/routing proud door frame - tools/techniques?
stu w replied to DeanAlan's topic in Doors & Door Frames
The linings should have been extended before the plasterboard/skim was carried out . A flush trim bit would do what you are looking for but not the correct way of doing it -
This happens a lot when walls are over boarded with the original linings left in place . Depending on the amount of linings you need to do, you would be better reducing the size to the correct depth before fixing , or find some timber what is very close . You will need a couple of mm over the finished plaster anyway. Door stop is used fairly regularly for this due the the thickness, or get a local merchant/friend/joinery shop to run it through their planner thicknesser. You will get a more accurate and better quality finish by fitting a regulerised section than trying to trim it when fitted, as you will get deviations which will then show when the architrave is fixed -
Excellent news 👌. Keep that test result as you well may be asked to prove that's the case on disposal, it still may have to go in the asbestos skip at your local tip
