marshian
    6
Everything posted by marshian
  1. Lovely post @SimonD @mikeysoft "Experience is what you get when you don't want it" My house built in the early 80's had T11 rads throughout - they were originally fed by a high temp non condensing boiler and I'd changed that to a condensing boiler and got a little energy saving Over the years single glazing got swapped out for double glazing - 25mm of loft insulation got upgraded to 75mm - empty cavity wall got insulation blown in - all giving small but incremental improvements in energy consumption A few years ago I "upsized" some of the rads in my house (mostly bedrooms, living room and hallway) from original single panel, single convector rads to double panel double convector rads - my assumption was I could run lower flow temps improve boiler efficiency and reduce my gas usage It was to be frank a bloody disaster Rooms with upsized rads heated up far faster than ones with the original rads, the TRV's closed to limit the room temp This meant that the heating circuit was half the total volume once the TRV's shut down - the boiler then cycled like crazy wasting loads of gas and my energy costs went up not down Lower flow temps meant that the rooms with original rads didn't heat up as quickly but now with a circuit volume that had shrunk and a boiler that cycled like crazy they never came up to temp unless I increased the flow temp Increasing the flow temp meant that any condensing eff gains was lost and I learnt a valuable lesson I upgraded the remaining rads and was then able to run lower flow temps for the whole house - downside was my boiler wasn't capable of running the lower flow temps to not overheat the house 45 deg C was as low as it could go with sensible burn times I did a room by room heat loss calcs - swapped some rads about and replaced a couple of rads where the move from T11 to T22 wasn't balanced to the heat loss and ended up with a house that could be heated with 30 deg flow temp even at zero outside Except my gas boiler would short cycle when set to anything below 45 So I changed the boiler for one that could run low flow temps and now I can heat 24/7 low and slow and get the benefits of boiler efficiency It doesn't matter if you use Rads or UFH you really need to have a very good idea of heat loss and align flow temps with the size of the rads or spacing of the UFH pipes to meet the needs of the room Oh and micro managing room temps to save energy doesn't work either - there is a great heat geek video on that "Stop turning off radiators in unused rooms" it covers the reasons why it can actually cost you more So in summary people on here are trying to stop you making the same mistakes we've already made
  2. Two ways to do do UFH - With a lot of insulation under the floor or with none Skip to 11:30 to the bit that covers UFH in an un-insulated slab @JohnMo is pointing out you are in "no mans land" where a little insulation can actually be worse than none
  3. You don't - You can have different temps in different areas of the house by controlling the flow rates (you can do this with flow rate supplying each loop) what you don't want to do is control temps with thermostats/actuators @JohnMo is stressing the importance of having a nice open system with no thermostat/actuator controlled zoning which is bad for efficiency (boiler cycling) I have 13 rads - only two have set backs using "Smart" TRV's - rest all are controlled by matching flow rate to heat loss to achieve the desired room temp means system volume is ~100 Litres so plenty of water to keep the boiler happy
  4. to expand on ^ if your boiler can run low flow temps for CH and flip to higher temps for HW (ie with Weather Compensation and DHWP) then running at fixed flow temps with mixers and additional pumps for UFH make no sense my max flow temp for CH at -2.5 outside is 34 deg C (weather compensated system) return temp is in mid to high 20’s so condensing all the time with a boiler efficiency of 97.5 % (validated because I found out how to calculate it) my max HW reheat temp is 80 deg C - efficiency is probably not much more than 86 % - I don’t care because I run the CH 24/7 on low flow temps at max eff and only heat HW tank for 20 - 30 mins a day. So the efficiency gains on CH cover off the poor eff on HW
  5. So are advantages of split units using refrigerant things like no glycol/antifreeze valves, no defrosts and a higher flow temp is possible than A2W Heat pumps? The COP from memory was high 3’s in middle of winter and high 4’s to low 5’s in shoulder seasons House is a fair size (so will cost to heat) but to me the energy bills over winter are eye watering it was built 6 years ago to regs UFH throughout with additional big towel rails in all the bathrooms what concerned me from an efficiency perspective was the buffer, number of pumps in the system and thermostats in every room
  6. I wasn’t questioning the modulation 😉 The boiler will have a min flow temp that it can work at - that temp may well be higher than a UFH system can cope with my old Glow Worm boiler stated min flow temp was 39 deg C - it wouldn’t run at that temp - lowest practical operating temp was 45 current boiler min flow temp is 20 deg - lowest practical operating temp is 25 deg should be documented in the installation manual
  7. I think it must be
  8. I don't think @mikeysoft's WB LPG Boiler is capable of the low flow temps for UFH - and probably not able to do DHWP either
  9. Data is always good - I'm seeing an improvement in both internal humidity levels as well as loft humidity levels Changes have been driven by Improvements to loft insulation (from 75mm to 300 mm) and ventilation (eaves trays and gable end vents) (Loft temps are rising, humidity levels are falling) Changing the speed of the PIV unit for the shoulder and summer months (Increased Air changes and air supplied from the loft is drier) I was tempted to move my internal temp and humidity monitor as it's in a relatively cold room compared to the rest of the house but because it's always been there I'm reluctant to have a change in data. Add to that the insulation levels above the room have been improved I'm hoping I can heat 24/7 without setbacks
  10. I'm guessing it's high temp split with refrigerant I only noticed the pipe size because the insulation is also quite small and is in a poor state in places - guess that might be impacting efficiency?
  11. Went to my friends house this weekend - fairly large bungalow with a ASHP set up Looked at the heat pump and was really surprised to see the primary pipes are tiny (like microbore size) I was expecting 28mm pipework from the ASHP to inside
  12. I am right in thinking that ring circuits is very much a UK thing and stems from "economy" post war - less wire used and lower grade of cabling required? In Europe they are radial??
  13. Just to add Setting 2 has been my winter setting but Setting 4 has become my go to setting for spring summer and autumn Reason is adding insulation to my loft has resulted in an increase in loft temps - the PIV cuts out if loft temps get over 27 deg C So it's running half the time it would during winter so I've increased the flow rate and it seems to work nicely - especially at night when the loft temp rapidly falls and it's helping to cool the bedrooms during the night. The silver fan of doom hasn't been deployed yet this year (Mrs Alien doesn't like it hot in a bedroom in the summer so despite the fact she's a light sleeper the fan gets deployed and as it's a constant noise she copes with it - I can't stand the noise it makes although I can sleep thro a hurricane I can't get to sleep in one so dislike the fan being deployed) In spring / autumn during the day it does a reasonable job in transferring warm loft air to a cooler house
  14. Christ!!! That's quite a number. /joke - But then again if I'd applied to build a dungeon under my house I'd have probably got a few more oblections Having said that with the water table as it is it would be a below ground swimming pool 90% of the year and a little drip would be the last of my concerns 😉 How many of the neighbours still don't talk to you?
  15. I had three objections to a two storey extension to the house and a single storey extension to the attached garage (all in one application) All were from an immediate neighbour. 1. Over development of the land (from neighbour with less garden than I would have post extension) which made me chuckle. House extension was replacing the footprint of an aluminium single glazed conservatory and garage extension was replacing a wooden shed. 2. Concerned about the possibility of running a business from the garage (I like cars I have a few and I do all my own maintenance / restoration - not got time to do work on other cars) 3. Proposed new window for en-suite would overlook neighbours bathroom window (their window was frosted glass - proposed new window was specified as frosted glass) Planning was granted
  16. Home made induction heater was what I called it Anyway apologies for the OT back to ring mains and fused spurs
  17. I’d better state the case for defence (of the lazy) 1. it’s the shortest immersion I could find (seriously stubby) 2. it will heat approx 30 litres of a 115 litre tank before tripping out on thermal overload (temp of the water thermal overload - not melting the plug thermal overload) 3. it is absolutely a get out of jail solution for major gas boiler breakdown/failure 4. I’m well aware it’s probably well past the ragged edge of acceptable just an aside I once needed to do a bit of welding on a car - rather than turn the car round so the welder could be plugged into it’s normal 16 amp socket - I plugged the welder into an extension lead (un coiled just what was needed to reach the welder) that ended well…….. Next time I used the extension lead it uncoiled to the same point - the rest had welded itself together / scrap basically
  18. you’ve just reminded me I need to wire in my 3kW immersion heater to a fused spur connection off the ring main (rather than the current 3 pin plug it’s currently wired into) before I turn off the boiler, drain the system for a couple of days to do a few circuit/rad valve changes prior to the heating season. yes I know it shouldn’t be on a 3 pin but in 33 years it’s only been used twice (very much a energency use only)
  19. flipping the question round why would you want to switch the flow off to the UFH and rads if it’s heating season?? Well set up weather compensated flow temps should mean that the heat source is only replacing the heat lost not more and not less…..
  20. reminds me of the Urban Plumbers Skit on Viessmann Boilers and why the company makes life so difficult for installers Skip to 11 mins and enjoy
  21. Pretty much what @JamesPa said I'd certainly try WC first with as much of the system in play as possible before adding lots of thermostats and micro zoning I've currently got Wiser "Smart" TRV's on every Rad (13 in total) The only ones that actually have some room influence are on the north facing side of my house with 3 external walls on the rooms and they are used to set back temps during the periods where we aren't using those rooms and overnight for same reason primarily because of the high heat loss. All the others are set to an elevated target temp and act as temp limiters rather than temp controllers (for solar gain on south side or an unexpected and sudden temp change outside) I'm going to try to re-coup some of the cost by selling the smart TRV's and replace them with decorators caps as really they are just expensive battery powered room temp sensors and I have stand alone units already in most rooms
  22. I mostly DIY because - with the exception of plastering and brickwork - when I've paid a tradesman to do work it's not been to a standard I regard as acceptable - that doesn't mean it's shoddy or terrible it's more that they want to get the job done in the minimum time and it shows. Your maths works and makes sense but I enjoy the satisfaction of knowing 1. I did it myself and 2. If I need to maintain/alter/replace something I know how it was put together (I tend to think of the access requirements at the fabrication stage and build it in)
  23. Excellent progress - getting vehicles stuck on site is fun................ One of my treasured memories is getting a cement lorry stuck in my back garden after delivering 15T of concrete and it buried to it's differential casings due to driver not understanding that spinning the wheels from the start was unlikely to do anything other than dig a really big rut. Seeing it pulled out by another one - happy days.............
  24. Fun comparisons Weekdays Roughly Translated to Sleep - Wake up Get Up - Work - Get Home - Have tea - drink tea - bed Weekends Roughly Translated to Sleep - 1 person wake up - get up and do stuff - 2nd person get up - stick on laundry 3 loads - tea Oven - watch movie - bed Winter is heavier on laundry due to TD/dehumidifer drying usage
  25. Or too high a pump speed for the system volume and lockshields screwed down to slow the flow (aka "balancing not balancing") One of my pet hates is system noise - I won't repeat the post I wrote around pump getting blocked up with magnetite resulting on the need to run the pump as twice the previous speed and generating a lot more system noise as a result But this was the pump impeller and once cleaned up I was able to revert to the previous min speed and had a perfectly quiet system again......
