marshian
    6
Everything posted by marshian
  1. Loft has no ridge vents - fitting them would be an PITA and involve a shed load of scaffolding - it will need a roof job at some stage so I'll do that then In the meantime I'm either going to put a couple of air bricks in the top of the gable ends (4 gable ends - stupid T-shaped house) or core drill a 110mm hole the equivalent of bathroom extractor vents and then put mesh ends on them - both would help a lot of trapped heat escape and possibly improved the ventilation / humidity levels in the winter I get you on that - Lemon Gin is way better than IPA - not quite as good as ghost ship mind
  2. PIV works for us most of the heat used to hit the upstairs from a poorly insulated loft (just 70mm of insulation) with a large south facing expanse of concrete roof tiles which really soak up the heat from the sun Yesterday peak day time temp outside was 22 deg C - loft temp hit 34 deg C - PIV turns off at 25 Deg C Now we have 370mm (well we will have shortly when I finish the last areas) I’m already seeing lower upstairs ceiling temps so it is helping My main issue is Mrs Alien refuses to have windows open at night (apparently something to do with eight legged things) Not an issue in winter house doesn’t overheat then but as a result of that “commandment” I’m slightly constrained in spring, summer and autumn In life if someone gives you lemons you have to make lemon gin
  3. We have PIV unit - In the summer we run it flat out during night when air is cooler and during the morning until the unit temp sensor hits 25 deg - then it turns off until temp drops below 25 it’s proved very effective at cooling the house - not AC cool but just cooler than it had been before we installed it. we do adopt a blinds/curtains closed on south facing side of the house which minimises solar gain during the day in the height of summer spring and autumn the solar gain is appreciated and it’s not as big as it is in summer
  4. I’d started a couple of tasks yesterday but not completed finished 2 & 3 this afternoon Boxed in the bathroom extractor fan unit (and insulated around the pipework inside the box) Lid is removable for maintenance or replacement but main purpose of boxing in was to use up some offcuts and insulate plus stop me tripping over the pipe Loft hatch completed This is the top hatch 25mm of celotex glued to a thin ply board original loft hatch also lined with celotex 25mm to help seal up and also improve insulation properties of a badly fitting plywood hatch It’s very noticable the impact on the PIV output, before with just the single plywood loft hatch when it was shut and the PIV was on you could feel the airflow escaping through the hatch into the loft now with the new set up you can’t so the PIV will hopefully reach places it didn’t before Damn it was hot up there when I started!!!! Hatch open and patio door open I’m getting a decent airflow to push out the hot air and it’s down to a much more comfortable 28 deg C
  5. Still ticking along with this although the recent warm spell has made it a bit uncomfortable up there (it's currently nearly 5pm and my loft temp and humidity sensor is telling me it's 34.6 deg C and 32.5 %RH One end from hatch to the gable wall is now fully finished Other end with the water tanks in the distance I need to join the side section to the middle area Also need to 1. Raise the lights up a smidge I keep clipping the with my head 2. Box in the shower extract fan 3. Insulate the loft hatch board and create a second trap door to increase the sealing 4. Re-do the pipework on Right that goes from Airing cupboard to the Cold Water store and F&E tank
  6. That just makes my eyes go weird!!!!
  7. Can't do that one I'm at Goodwood doing a car show build up
  8. Excellent result and IMO bloody good value as long as the aches and pains go away with time
  9. Couple of points I think your water calcs are a bit pessimistic (Appreciate worst case is probably safer but......) 1. Mains water does vary but around 10 deg C is as cold as I've seen in Norfolk 2. The tank is always going to have some bleed of hot to cold so at the point of re-heat it's more likely for the bottom of the tank to be in the 20 deg area and top to be low to mid 30's as a start point This mornings water heating with a gas boiler was 4.5 kW used Start Temp Top 34.1 C End Temp Top 51.7 C Start Temp Bottom 26.4 End Temp Bottom 51.1 Tank is about 115 Litres
  10. I'm absolutely sure it would work on all houses (as you say you are just putting the same amount of energy in to replace the energy lost) but I'm also equally sure that if I had WC on our house 25 years back I wouldn't have liked the bills much.......... I think once you get the level of insulation/air tightness up to a half decent std it comes into it's own in comparison to scheduled heating
  11. I bought into Wiser system - pretty convinced that when I was running scheduled heating times with the old boiler with “smart” TRV’s it did a pretty good job of saving energy (I was manually compensating for outside temp ) Now with new boiler running WC and 24/7 I’m fairly convinced that Wiser and the “Smart” TRV’s aren’t making any saving the only functionality I’m finding really useful is the ability to control HW schedule remotely. I’m pretty sure removal of 80% of the TRV’s and replacing with decorators caps is going to happen soon but for the remote control I’m pretty sure I’d go back to a simple on/off programmer and a wired thermostat on the wall in case of too much solar gain in shoulder seasons……. so much for technology
  12. Really interesting info - I've gone thro similar albeit still using gas boiler Over the past 4 years I have gone successively from gas fired, heating to a schedule trvs everywhere, flow temperature pinned at 68C and rooms all set to different target temps "probably over zoned" gas fired, heating to a schedule trvs everywhere, upgraded rads lower flow temps 48C was pretty much as low as the boiler would go to 55C in the worst of winter (best description is manual WC) - I was using "hour boosts" in shoulder seasons when house needed a little heat but a full schedule was too much. heating 24*7 still got trvs everywhere but majority set too a temp that cannot be achieved WC flow temp (32C at 0C OAT) (I still have a couple of areas where effectively the TRV's are in operation but they are high heat loss areas) In the last few weeks I've been experimenting with turning of the boiler for a several hours during the day and I'm rapidly coming to the conclusion that it's not saving me any energy - or rather energy not being used during switched off period is being used to get the house back up to temp Comparing energy used v HDD data it's pretty clear to me that proper WC (using OAT sensor and the correct curve) combined with open zones is a way more comfortable environment at the expense of a slight increase in energy usage * over the winter period (* compared to Scheduled heating) That increase in energy usage is now being recovered as a result of WC being far more efficient at keeping the majority of the house at target temps now we are in the shoulder seasons so where I was considering going back to scheduled heating or turning off the heating for periods I'm leaving it 24/7 Data HDD Month 2022 2023 2024 2025 Jan 377 366 414 Feb 294 248 332 Mar 291 251 288 Apr 239 211 161 May 141 101 Jun 55 84 Jul 39 45 Aug 42 31 Sep 28 38 88 Oct 116 130 159 Nov 217 283 278 Dec 399 291 300 Total 759 2,219 2,161 1,195 KW (Heating only) Month 2022 2023 2024 2025 Jan 1,388 1,440 1,901 Feb 1,076 942 1,507 Mar 1,056 814 1,024 Apr 604 600 342 May 99 38 Jun 24 54 Jul - 41 Aug 5 - Sep 108 8 183 Oct 384 399 651 Nov 776 663 868 Dec 1,442 1,146 1,429 Total 2,710 6,468 7,061 4,774 KW/HDD Month 2022 2023 2024 2025 Jan 3.68 3.94 4.59 Feb 3.66 3.80 4.54 Mar 3.63 3.25 3.55 Apr 2.52 2.84 2.12 May 0.70 0.38 Jun 0.44 0.64 Jul 0.00 0.91 Aug 0.12 0.00 Sep 3.88 0.22 2.07 Oct 3.32 3.08 4.11 Nov 3.57 2.34 3.12 Dec 3.62 3.94 4.77 Avg 3.57 2.91 3.27 3.99
  13. Indeed I have Copper pipes under a suspended ground floor and running in a very well ventilated void - these are all insulated (CW, HW and CH Flow and Return) Copper pipes above an insulated cold loft that is ventilated - these are all insulated (CW Tank Feed, HW F&E The only pipes between loft and floor that are insulated are the flow and return to the HW Tank from the boiler and All pipework in the airing cupboard All HW, CW and CH flow and returns inside the heated envelope are not lagged mainly because they are boxed in or under the first floor - I did consider it
  14. A Gas boiler - output and modulation rate chosen poorly and run at non condensing temps will also hit you in the wallet 100% agree - Condensing boilers were mandated with little or no explanation of just how the efficiency could be improved with lower temp heating and DHWP - I'd take a punt and say that most condensing boiler temps are set at 55-60 deg C as that's really the temp which gets the HW tank up to a sensible level and aren't set up for WC S and Y plan aren't really the problem as such - boilers not being told if they are heating HW or doing Space Heating is the issue The mandated move to condensing boilers is just another example of governments trying to do the right thing but making it a utter horlicks of it all Same with BUS grants - all it's doing is inflating the cost of the conversion from gas boiler to ASHP - increasing the profits of manufacturers and installers and being funded by the taxpayer.
  15. I'm sure we can be flexible on the date..........
  16. I'm not talking about safety related issues here I have a simple rule for all white goods "insurance plans" or "extended warranty" costs - I get a minimum of 1 year for free - if something is going to go wrong it's more likely to do so in the first year so I'm very skeptical about the benefits. (You don't hear many companies offering warranty cover going bust) If the cost of the cover for additional 2, 3, 5, or 10 years (Based on a reasonable expectation of expected life) is more than the cost of a replacement new item they can get in the sea * see note I take 25% of the cost of the plan and stick that in a savings account It meant that when I replaced my gas boiler last year the £3500 it cost was all from that same savings account I have a neigbour who covers all his appliances with "Extended Cover" - last year he was crowing about he had his american style fridge freezer replaced FOC -but he pays somewhere close to £300 per month for all appliance cover he has. By my logic American fridge freezer say £700 - 800 he could have covered that cost in under 3 months and as a plus It wouldn't have took 3 "engineer" visits with various parts being replaced as a potential fix while suffering a below par fridge performance before they accepted the fridge was beyond repair (who knew a fridge has a motherboard!!!) Note * It always is!!!!
  17. Last one I did looked like this but it was years ago - Cost was pretty much free as most of the wood was scavenged Sorry didn't build the house so no idea on costs
  18. Bravo Then end of "da bungalow" is the new beginning I'm not surprised at the attitudes of the neighbours - you are exibiting considerate destruction - much better than a munching machine
  19. I'd be up for that - I got a ban from the cherry tree in 1980 (Don't ask it was a misunderstanding about the legal age to drink in a pub without an appropriate adult) However I'm pretty sure 1. They won't recognise me now compared to the spotty teenager I was 2. The grumpy twat that ran the place is probably dead anyway
  20. Or May? First Thursday is the 1st of May (I thought it was a bank holiday but that's Monday the 5th May so nicely away from the 1st)
  21. I'm playing catch up with these blog entries - you have a great writing style - just the right balance of humour and gritty detail - thanks for sharing.
  22. It is indeed
  23. Christ that's darker than @Iceverge
  24. Dark very dark indeed
  25. I know what temp ours gets too................. Highest in 2024 was 40.2 Deg C, Lowest was -2.1 Deg C Summer months pretty typical to never drop below 25 deg C in the day time Large south facing side - concrete tiles - overheats like an absolute twat!!! Have vented eves - all clear of insulation and they do diddly squit - I'm going to stick an airbrick in each gable end as high up as I can in the hope that it allows some heat to bleed out. Anyway good work on the demolition and skip avoidance
