Everything posted by marshian
South facing rear of the house with french doors in both Dining Room and Living Room means solar gain is a useful bonus but doesn't really overheat until we are out of the heating season. What has really surprised me is how effective WC is in meeting the heating needs there were only a couple of times when it got caught out with big temp swings in a very short space of time But my manual weather compensation that I was doing before would have been caught out too š I think that's the benefit of WC and 24/7 - house temps are amazingly stable and as a result you can run slightly lower target room temps and it feels fine. I'm comfortable in temps from 17 to 19 with no drafts (lack of air movement makes a huge difference to comfort levels at lower room temps) Downside is Mrs Alien is slightly more sensitive to room temps and to her "toasty" is 22 and "Freezing" is 19 but she's getting used to the new regime and back end of winter had stopped declaring the house to be "like an ice box" at 20)
I am using a little more gas but part of that is down to ālearningsā during the heating season so up from 8500 to 9500 but 9000 would be a reasonable expectation For a boiler to condense the return temp to it needs to be below 54 deg. The lower the return temp the greater the condensing energy recovery
Similar situation with my house suspended ground floor with decent sized void under it - 75mm kingspan PIR between the joists made a massive difference to energy bills - rads all rooms no UFH Running WC flow temps max 34 deg c at -2.5 Don't discount rads as an option
Not updated this thread for a while but now the heating season is over it's time to consider where I go next - let call this an end of term report. Boiler review - Did I buy the right boiler Yes - unlike the previous boiler purchase. Very happy with it's weather compensation and low flow temp capability and by the time we got to early spring I'd settled on a WC curve of this. I still have a little niggle about it's output being a little higher than claimed min but it's close and I am running at lower flow temps. System improvements/changes I've ordered 9 Danfoss RAS-B2 valves to replace most of the drayton EB4 bodies (adjustable flow via selecting one of 6 orifices) Why? 1. majority of the rads are running orifices between 1 and 4 and in most of the rooms the difference between one setting and the next one (up or down) is too coarse and I need finer control to stop the rooms being too cool or overheating without TRV intervention. 2. I want to get rid of nearly all the wiser smart TRV's and replace with decorators caps and I can do that if I have finer control of the flow thro the rads. Leaving them on the rads just gives me an expensive battery powered room temp indicator (where I need to replace that batteries every 300 days) 3. Replacing the TRV bodies means a drain down and that's an opportunity to re-configure the rads from BBOE to TBOE and tweak a little more efficiency out of them (5%) and I think it might help increase the delta across the rads It's quite amusing to think 4 years ago I was 1. running a boiler that was capable of producing 5 times the energy compared to the heat loss of the house. 2. Running the boiler at a temp that was only ever condensing in the warm up phase 3. Micro managing room temps with "smart" TRV's to heat only when needed via scheduled heating (over zoning) to now 1. running a WC boiler at a max flow temp at -2.5 of 34 Deg C so is condensing all the time and running at 97% efficiency 2. Heating 24/7 with minimal zoning 3. Planning to drop nearly all the smart TRV's and just controlling the room temps with WC flow temps Weird journey when you think about it............
Top Mounted Vertical Immersion
marshian replied to John Carroll's topic in Boilers & Hot Water Tanks
I don't get a lot of turbulence with a vertical top mounted element and you certainly get a very defined stratification with minimal heat transfer to water - down side to my element is it's quite short, maybe less than 1/3 of total tank height so it really only heats about 50 litres max - just enough for two decent showers or a shallow bath -
Oh I get that and 'it's why I might (in the interests of "science" ) move the bottom sensor up to a position on the outside of the tank level with the end of the immersion It's a top mounted vertical immersion in a 115L tank and it has it's own internal thermostat just as yours does Question will be at what point the internal thermostat signals re-heat and after how much water has been drawn off? gut feel from how we've used it before is you can pretty much use 70% of the water before it will kick in again and try and reheat so maybe 40 litres -
OT I lived for years first on a Volvo 3.0 CD and then a Senator 3.0 CD plate was relevant to both š rather than to me When I couldn't find another Senator that wasn't full of tin worm it carried on first on my BMW 740i and now on my current BMW "130i" I did get a daft offer once from someone who wanted it for their Audi A3 but I kinda like it and 30 years is a long time to have a plate
I don't think that would tell you anything meaningful unfortunately This is what I have on the tank (Library picture from a legionaires cycle to 61 deg C - followed by pouring a bath) the top one is looking at the top of the tank - the bottom one where the boiler tank thermostat is I'd need to put another temp probe in or move the bottom one up to roughly where the immersion element ends to get a better idea of hysterisis -
Fabric and ventilation heat loss calculator
marshian replied to Jeremy Harris's topic in Heat Insulation
Looks like I'm going to have a play with the original spreadsheet and @AartWessels web based app I originally did heat loss calcs with https://heat-engineer.com/en/ From memory £12 paid for a single one off survey - took a bit of time with a tape measure but the results for my submission were pretty accurate v real world energy usage over the winter and it felt like good value I've recently improved a few aspects of my house as well as moved to a low temp heating regime and I want to to do another heat loss survey to see what I could expect compared to the original Price now for a single user / single survey is now £100 not sure that represents good value any more- 204 replies
- heat loss
- ventilation
(and 4 more)
Well done - clearly the poorly installed installation was very much the driver for your heat loss issues - only thing I don't understand is why there is a mixture of materials - surely with the roof off it could have all been kooltherm PIR?
Block paving staining help, not coming off
marshian replied to wakewaterblue's topic in Bricklaying, Blockwork & Mortar
Brick acid will normally take off sealant - however it is very aggressive stuff - A friend of mine arrived on my driveway in a car leaking a lot of very hot transmission fluid - it went straight past the sealant on the brickweave and all the normal gunk/jizer oil removal preparations did nothing - brick acid worked but it's obvious which bricks were treated - the surface finish is very different -
Should I replace my cavity wall insulation?
marshian replied to rowan_bradley's topic in Heat Insulation
Do you live in an area that gets a lot of driving rain and or the house is in an exposed location? -
couple of points 1. You could but the output might be horribly compromised - heat rises and doesn't sink so the top of the rad might be warm but there won't be a lot of heat traveling down. 2. Most "good" vertical rads clearly indicate inlet and outlet in order to work with the diverter that is installed in the rad (I'm not sure they can be fitted upside down either you need to discuss that with the manufacturer) 3. I've linked to my post about my experiences with a couple of oval vertical column rads as not all manufacturers have the same level of quality control and diverters are crucial on vertical rads in low temp systems 4. I'd run the pipes behind the rad and feed from the bottom (maybe paint them the same colour to hide them)
Similar arrangement for me but only time I use the immersion is when the HW/CH system is drained down for changes in the summer. My thermostat is set to 55 Deg C it's only a fairly short element maybe 40 L but that's enough HW at 55 deg for two showers or one shallow bath (I have a tank temp display and from memory the thermostat was quite accurate v the temp sensor) I can't help with re-heat set points as we heat only when (or just before) we need it so I've never noticed what hysteresis is applied -
My question as far as you wanting to run at "low flow temps" are concerned is just how low will your oil boiler go down in terms of flow temp? I think this is an important point as you need to size the rads for the lowest realistic flow temp that also keeps the boiler happy I heat with gas and previously had a glow worm condensing boiler that was oversized for the house 24kW - I upgraded all my rads to match the heat loss at a flow temp of 40 deg C but realistically 48 deg C flow temp was as low as the boiler would run without excessive cycling and I ended up running it slightly higher and controlling room temps with TRV intervention (which isn't great for cycling). Moving to a new gas boiler (I wasn't brave enough to go ASHP at the time) it happily runs in from mid 20's to low 30's (Weather compensated flow temp) - only had to change one more rad to balance the house warm up (one room took way longer to get to temp) most TRV's are set to elevated target temps that can't be achieved in order to minimise circuit shrink due to TRV's shutting down. All Rads are fed with the flow they need for the WC flow temp although I am planning to improve this area as the Drayton EB4 TRV Bodies only have 6 flow settings and I could do with a slightly finer adjustment on a few rooms so I'll be changing a few for Danfoss RAS-B2 TRV bodies as they have a finer adjustment for flow rates House is heated 24/7 no set backs - it's way more comfortable at a lower room temps because there are no temp swings, In the heating season the boiler cycles once per hour max - the length of the cycle determined by the heat loss If the old room comfort target was 22 it's now 19 to 20 max House is 4 bed detached - extended with a 2 storey ext - is a stupid T shape with several rooms having 3 external walls - some insulation improvements - floor area total across two floors is 113 m2 and peak heating at -2.5 is 39W/m2
Thoughts on commissioning a Vaillant Arotherm Plus 12kW
marshian replied to sharpener's topic in Air Source Heat Pumps (ASHP)
just for info I have a lot of data on gas usage for my house and one thing that really stands out is summer DHW usage is very very different to winter DHW usage. in summer tank losses are lower due to higher ambient temps in the house water from the mains can be 10 deg higher in temp coming into the house typically my summer DHW usage is 3 to 4 kWh for the heat up - Winter it's closer to 5 kWh - that's a significant % increase that you probably need to factor in MCS I agree is a bit crap - worst case on worst case - might be worth ignoring the grant element and pricing up what you need without EPC pretty much fiction and not really a good guide -
Still here - watching because I want to see a happy endingā¦ā¦ prob page 1367 at this rate š
ASHP - our architect negative about them
marshian replied to Wadrian's topic in Air Source Heat Pumps (ASHP)
Separate pump for rads? Turn pump speed down and or open up lockshields and run rads same temp as UFH if sized correctly I hate system noise itās a sure sign something is working harder than it should -
Covered Decking Area (pergola)
marshian replied to marshian's topic in Landscaping, Decking & Patios
Anaesthetic hasnāt worn off yet so currently no pain at all - pretty sure that will change soon -
Might be a few days before I start back on it surgery Iāve been waiting 2 - 3 years for I reckon @JohnMo will have his finished before mine š -
I've used two of these in the past for an awkward soil pipe to pan angle - try to get one with ridges on the rings that lock up the joints as the smooth finish ones are much harder to get tight. (Flo Plast ones definately have that)
Then I think I'd be avoiding them and going for a supplier of known and guaranteed suitable material
If you have a heat loss (w) required by the room then it really is simple Lets take the example of the Room 1 - from the table you supplied heat requirement/loss is 612w So you need a radiator that supplies 612 w at your target flow temp Radiator outputs are normally stated at Delta 50 (Flow temp 75, Return Temp 65 so mean rad temp 70 Deg minus room temp 20 gives difference of 50 Deg. Rad outputs by size and type can be found here https://www.stelrad.ie/wp-content/uploads/2015/08/Compact-K3-Technical-Specification-Brochure.pdf Taking a T22 Rad (double panel / double convector) which is 600 mm tall and 1400 mm wide it has an output of 2.425 kW (2425 w) at Delta 50 Correction factors DT50 is 1 DT45 is 0.872 DT40 is 0.748 DT35 is 0.629 DT30 is 0.515 DT25 is 0.406 DT20 is 0.304 At Flow temp 45, Return Temp 35 so mean rad temp 40 minus room temp of 20 gives a difference of 20 Deg (or Delta 20) so the correction factor for that is multiply the original rad output by 0.304 2355 multiplied by 0.304 is 737 w so a little over what the heat loss required is so you could reduce the size a little but I'd go a little bigger everywhere and then tweak the flow temp back a smidge. The key for me when up-sizing rads is to try and ensure all are up-sized by similar factors for all the rooms - I made that mistake myself in not thinking about whole house heat up being balanced. With ASHP your rad flow temps and return temps are going to be a lot closer than the 45 / 35 but the important thing is the radiator mean temp so a rad is going to give the same output at 45/35 as it will at 42/38 or even 41/39 If you are looking at designer rads, vertical rads or towel rails up-size a little bit more because in my experience they are a little optimistic in terms of output and that impact gets worse as flow temps get lower Highest Flow temp (central heating) that I ran my gas boiler at through Dec, Jan and Feb was 34 deg C - house is all rads (no UFH)
