Crofter
    11
Everything posted by Crofter
  1. Re: space-based mirrors for increasing the output of PV arrays on the ground. Never say never, but I just can't see how this stacks up. The mirror has to be considerably larger than the area of arrays on the ground, to make up for all the losses involved (albedo of the reflective material, angle of incidence, beam divergence). Keeping the beam parallel and aimed at the ground array would be a serious feat of engineering, especially considering the space element would presumably be a huge lightweight mylar sheet, perhaps spin-stabilised to maintain tension. It would have to be extremely lightweight for its size, due to launch costs (currently around £20,000 per kg, although this could fall by a factor of ten if Elon Musk's plans work out. Still pricy). From a safety point of view, a tiny degree of convergence in the beam could cause it to focus all that energy on a small area with harmful consequences- although it would probably be quite unlikely to happen by accident. However if we have the technology to keep the beam parallel, we probably can also focus it accurately. A scary thought.
  2. Are the openings just roughed out in the frame? I would just knock up some panels from OSB and 2x4. Go for 18mm and it'll be sturdy as anything. Make seven of them lockable from inside and that leaves only one that needs a good hasp/staple on it, and a big padlock.
  3. I found these details surprisingly hard to pin down, and the best approach was to actually phone the guys who were going to do the job(s). If you have a groundworks contractor they will probably be able to keep you right. Safest approach is to dig it deep enough for the water, that has to be deepest for frost protection (up here anyway- might be different down south)- from memory this was 700mm. Electric shouldn't need ducted unless it is going under a road or close to the surface. I had to lay a bit of ducting where it went under my driveway and initially the guys were not happy about using a duct that they hadn't themselves laid. Their fears were partly justified as we had a right job getting the cable through- I guess a stone might have partly crushed the duct at some point. I don't know how close I came to them calling it off and wanting the whole thing dug up again, which would have been pretty annoying seeing as there wasn't a machine on site at the time.
  4. Don't forget eBay as well- I got my twin pack from a German seller on there. They offered free postage to the Highlands, unlike most sellers in England
  5. I've got 4ah Makita batteries and see no need to go any bigger. It makes the tool heavier anyway. I go whole days without charging them, if it's just drill and driver use, although the saw and the grinder make more of a dent. I would probably have been better off with three smaller batteries instead of the two 4ah ones that I have- the other day I was doing a job that needed the saw, the drill, and the driver, and had to keep swapping a battery over
  6. I would just use a normal circ saw set to the appropriate depth, and a multitool to finish off at the corners. Curious to see if there's a better way, though.
  7. Nope, it's not temporary- that's quite a different adjective and presumably legal definition. It is moveable/portable that we are talking about here. By my understanding, it's simply a case that a line has to drawn somewhere between a caravan* and a house. *or mobile home, site hut, shipping container, SORNed Winebago, landlocked narrowboat, etc.
  8. It's absolutely fine. The engineered timber I-joists sit on hangers within the ring beam, and the bottom of them is flush with the bottom of the ring beam. But the osb is in the form of strips between each joist, and sits on the lower flange of the joists. So they are a couple of inches up from the lowest point of the building, and all they see is the very dry and well ventilated underfloor space.
  9. Caravans Act nineteen-sixty-something. Less than 6m wide, 18m long, internal ceiling height of 3.048m or less, and demountable into up to two sections. It *can* be constructed on site, if it can be shown that it would be feasible to later move it. And the nature of being moveable lies within the building itself, so if it ends up boxed in by obstructions that prevent any real chance of ever removing it in one piece, that doesn't count against it. Edit to add- a flat pack approach doesn't qualify, unless the roof is a sort of 'module' that could be craned on and off in a single unit. The two-section limit means you can't make it up from a set of prefab panels.
  10. My wee house is also built on a timber ring beam. I've put 9mm osb under the insulation, so that's what you see underneath the house. And being three feet off the ground ensures access by cat/terrier/alsatian/rentakill etc.
  11. OK getting my head round this... Kitchen run I think is easy- a 15mm cold and a 15mm hot, the cold will have a tee off for the washing machine and dishwasher, then both end up at the sink. Bathroom is trickier. Looks like a dedicated hot and cold for the shower, the cold coming off the PRV on the tank. Then a separate pair of 10mm hot and cold, not balanced, feeding the basin and WC?
  12. I had wondered about noise, but was sure that fast flow in a small pipe would actually be worse? But I suppose it's the fill rate of the cistern that's the cuplrit really, not the noise in the pipe.
  13. Must be an easier way to fix it than knocking the whole house down! What's the advantage of 10mm by the way? Other than getting hot water to the basin slightly quicker.
  14. Ah Taytos... best washed down with a Smithwicks, personally. Well done!
  15. So this whole balanced feed thing... Does the mixer shower need a dedicated cold supply? I hadn't realised or planned for that- it will be much easier to have the single cold feed as planned, so the WC and basin would tee off it. Will this cause problems?
  16. It's very little work/cost really to add a counterbatten. I think TRADA specify a minimum of 12.5mm, although I used 25mm. I had to do this because I had sarking so you really can't skip the counterbatten if you are going that route. Also in the back of my mind was my parents' house- sarking, tiles, no counterbatten = rotten battens where water cannot run off. For the sake of a few pounds worth of wood it is going to create an awful lot of work when they finally have to rip all the tiles off and replace the rotting battens.
  17. Ah now that is useful info! I had been planning a simple system of a hot and cold run, everything just teeing off the cold- including the shower, which is the only mixer. I could run a second dedicated pipe run for the shower, tapped off the PRV- perhaps this is a good idea anyway? Any thoughts on leaving space for the shower unit, by the way?
  18. Ah but the cold system would not have a PRV... would it...? Mind you a quick peek at Google suggests I'm about 30m lower than the tank, so that makes three bar, I think. So sounds like a reasonable margin for safety.
  19. It appears that Hep2O is the gold standard when it comes to plastic stuff. I've got quite high water pressure and will be using a UVC so don't want to cut any corners. But presumably the other makes, like JG or Floplast, are all approved and should be perfectly up to the job? It would be interesting to hear if there any genuine reports of failure with the up to date versions of the cheaper systems.
  20. I did use push fit copper once, something about it seemed a bit too much like magic and somehow I trust a compression fitting more. Weird I know! So I'm not looking at plastic primarily from the persepctive of ease of use of the fittings, it is more to do with being able to 'cable' the pipe around awkward spaces.
  21. I'm reaching the stage where my vague ideas of where to put pipes ('over there somewhere') has to translate into actual plans and decisions. In my infinite* wisdom, I have already laid the floor and had just assumed that all the 15mm water pipes could run in the 25mm service cavity. Now that the wiring is going in, the remaining space is looking tight at certain points. I'm tempted to use plastic, at least in part, because I can reduce the number of fittings. And I've happily used it in the past. But the push-fit fittings are too bulky to hide within the service cavity, so can I just switch to copper for these? Or alternatively, seeing as all the fittings will be in cupboards, behind kitchen units etc, then just bring the plumbing out from behind the plasterboard. It seems if you google long enough, you can find every opinion available on the pros and cons of plastic and copper, and whether to stick to one system throughout or mix and match (plastic with copper fittings). And then of course there are the different brands of plastic system. In the past I have merrily used whatever was available and never had a problem, but that was always small changes and this is a whole house (albeit a very small one). A final question: the (TM) shower will be going on an external wall. Other than aesthetics, anything to consider? A concealed one would obviously look neater but require a bit of rework to make the space for it in the wall. Or I could bring the wall forward a bit with a plywood panel. *this may include infinitely small
  22. Thanks all going to be bamboo flooring, just the 10mm stuff. Jury still out on whether to go with electric UFH which affects the FFL (side note- the UFH would be lovely but the depth of bedding compound needed means the whole thing is starting to look just too expensive). I have built whole partitions including doors etc before, in my previous house, so I know that I can do it, but I remember it being a bit fiddly and it's the kind of work that is very much 'on show'. With speed becoming more and more of the essence, I was thinking of contracting this bit out to someone who would probably do all three (!) doorways in a morning, compared to me taking a few days.
  23. I'm building my internal stud partitions but will probably get a joiner to do the fiddly final fitting of doors, frames, architrave etc. So I just need to leave a space that will allow him (or her!) to do their thing. I guess this comes down to the sizes of timber that are generally used around the door frame- and obviously what size doors are used.
  24. It does read like buzzword bingo. PH cert at 36m2, and with that much glass, is a really, really tough challenge.
  25. I'll have to spend a bit longer doing a more accurate calculation, but I reckon I've only got about 125m2 to do. This is assuming no skim required on thr bathroom walls or inside the cupboard. It really is quite a small house So if I can get a similar rate to Jeremy, the right side of £500. Probably worth it, but not in the budget. Will check behind the sofa.
