Anyone got a WUFI Pro licence?
MikeSharp01 replied to Drellingore's topic in General Self Build & DIY Discussion
Respect..... I looked at DIY WuFi and decided the learning curve was not worth the candle so paid for a pro to do it. -
Posi joist - This install feels rubbish, thoughts?
MikeSharp01 replied to boxrick's topic in Roofing, Tiling & Slating
If you have a sloped base you have transformed the loading from all directly down to somewhat (mostly in this instance) down and somewhat (not much - but still some) along the beam in the direction of the slope. So if you load the beam it will somewhat want to slide down the slope and push the wall / support the other end - beware.... -
Its true what you lot say!
MikeSharp01 replied to mjc55's topic in General Self Build & DIY Discussion
great - keep on keeping on, the challenges will keep coming but you will see the end eventually. -
Cladding battens, Pressure treated or not
MikeSharp01 replied to gavztheouch's topic in General Joinery
We used Helifix inskew's stainless, they did the loading calcs and gave us a fixing schedule, dead easy to drive in with the SDS fitting good for pitched and vertical cladding - not expensive really. https://helifix.co.uk/products/warm-roof-fixings/inskew/ -
Grey water via bore hole or storage tank.
MikeSharp01 replied to MikeSharp01's topic in General Plumbing
I forgot to add that not only would you save the waste water charge but also the fresh water charge so that adds up to £6.50 m3. That means that if you had 2 IBCs buried in the garden you would have £13 of liquid assets -
Correct. Sewage assumed to be the same m3 as mains water bought. I don't know if that applies everywhere. True for Southern at least so assume the same everywhere. I have put in the parallel plumbing to the three loos in case we choose to go that way. -
What I was thinking of was deleting the sewage treatment cost that is worked out as a proportion of the metered water. If I use grey water for the cisterns then the mains take will reduce and that's worth £3.70 per cubic meter of mains water not used. -
Given discussion elsewhere and cost it struck me that a bore hole might be a cheap option for grey water delivery to your toilets etc than using storage where you need a big hole. A bore hole would perhaps deliver water that needed no treatment for such a purpose. Anybody any experience of doing this?
OK- rather hijacked this thread hear so started a new topic.
Do you need an extraction licence or some such?
Congratulations and enjoy the onward journey.
+1 to that. We built our garden room as a model for the house as timber frame using the same techniques - I Joist etc, but with thinner insulation. However if you are going brick / block for the extension then perhaps raft is not such a good choice.
The chap we used was from Umbay. Energy & Design Services info@umbay.co.uk. The final invoice was only a couple of hundred. -
I will dig it out - I think I mentioned it here probably 6+ years ago. -
I worked my way through this on our build and in the end I chose to get a professional to do the calcs for me and then give me a full report which is a sort of guarantee that the design is sound. The cost was less than the licence as I recall and de-risked our journey through that bit of the design. -
Tell him after the scaffold is moved? -
That does not look good - relying on a couple of screws and not the top string and / or a hanger feels very wrong, send these images to the joist manufacturers and see if they are cool with it - I doubt they will be although the runs are relatively short and the steel frame is doing the vast majority of the work assuming the roof load is appropriately transferred to it and I am not sure it is here. If things are as wrong as I suspect you will need to work up a strategy to tackle your contractors on Monday. Others with much more experience will be along to help with that I suspect. -
Economics of DIY and Self Building
MikeSharp01 replied to Gus Potter's topic in General Self Build & DIY Discussion
Great word - assume it means busted? -
+1 doing this here.
Sizing ASHP according to heat loss calcs
MikeSharp01 replied to flanagaj's topic in Air Source Heat Pumps (ASHP)
Ah yes but will you also be showering and cooking at the same time? Anyway as you say just dump the electric showers and all will be well. Back to sizing the ASHP - you have all the data you need so looks to me like you need a 5kW unit. The one we are looking at is 6kW the modulates down to 1.8kW - according to the blurb, we have a heating load of of 1.2kW at -1oC (We are in Kent so not the -10oC of @JohnMo and @ProDave ) -
You cannot operate that much unless you have very large plant - in which case you should be on 3ph, on your own, assuming 1kW extraction plant and perhaps 1.2kW motor on the machine you are running your need is actually only 2.2kW so that's an example of the diversity that @ProDave was talking about. Only the background load of the place will run 24/7 so needs slicing off the top everything else will only run occasionally and rarely together. There must be a standard way of working out the diversity, somebody on here must have discussed it, or at least estimating it, e.g assume 75% of the 'equipment' running worst case doe that get you under the 100A?
