MVHR installers or alternatives?
MikeSharp01 replied to Swampy's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Surely the thing about MVHR is that it is controlled ventilation, complimented by heat recovery, and so when combined with great airtightness, which has other benefits in addition, you are in control of the ventilation and the more of the heat that is recovered. You are brining air in and taking it out again in such a way, at such flow rates and in such places that draughts are not a thing, are not subject to the vagaries of the external wind direction / strength. Because it's all warmed so is less obtrusive because it is already mixed and not arriving through very effect venturis that increase its velocity and create discomfort. So it seems to me that, in such a scenario, draughts don't flow freely they flow in a highly controlled manor - it's not pure external air rushing past you to get into the place but air at room temperature flowing slowly past you in from the supply vents and out of the extract vents. It is also, however, clear that the recommendations around the Air Change (AC) volumes is a bit OTT as most people here seem to get by with a fraction of the recommended levels. I started out wondering if MVHR was for us but I have been convinced it is the best way forward and so just allowing air in and out in an uncontrolled fashion is not for us although it would be a lot cheaper at the outset without doubt. -
Problem with an S-PLAN motorised valve.
MikeSharp01 replied to MikeSharp01's topic in Boilers & Hot Water Tanks
Yes it feels right just to replace all of it. I won't be draining the system down, they will need to wait and get the plumber back for that. I will just run a couple more checks with the heating off later to see if I can hold the water back from cold. -
Yes I forced it closed with a spanner and wedged it, left it for a period of 30 minutes no change in temperature. -
The valve moves freely and you do feel a certain squishiness when you close it with a spanner. I have not managed to power up the head because I didn't want to disturb the settings, the hot water is set off. I can play a bit now as the heating has warmed up their house. There does not seem to be any other way for the water to flow so the valve must be letting by. I did notice that with the head on that the the manual lever di not seem to engage until almost the end of its travel but the head does drop onto the valve in the correct position. -
Friends of ours are having problems with their hot water over a period and they have had a plumber look at the problem, who said it was an issue for an electrician, they don't want to call a plumber today for obvious reasons, and so I said I would pop round and have a look at it. Its not a particularly odd one, basically the hot water tank is getting flow through the heating coil despite the call for hot water being off. So I looked at the S-PLAN valves and and noticed that that their electrician, under instruction from the plumber, had already fitted a new head to the hot water valve (A Honeywell 272848 normally closed valve) but they left the new valve body on the floor! Cutting a long story short I took the motorised head off the valve and forced the valve shut with a spanner and it looks like it still lets by so my question is: Do these valves let by when they are forcibly closed - I thought they were rubber balls so pushing past the end stop of the motor, without the motor attached, should close it but it does not appear to. So my diagnosis is that the valve body will need to be replaced but I wanted confirmation that forcing the valve shut can still result in flow getting through - has the ball fallen apart for instance?
Hi everyone! Planning a bungalow conversion near Guildford area
MikeSharp01 replied to Bob88's topic in Introduce Yourself
Don't listen to him, nobody uses bulldozers any more! Welcome to THE forum for people like us. -
Welcome @markg123 to THE forum for people like us.
Far too small - 4mm is minimum and 6mm prob better for run lengths.
We have two Tundishes (Only one un-trapped version in the picture but two new trapped versions have arrived today and will be fitted tomorrow). I have roughly plumbed them to arrive at what I think of as a good layout, see pic. (The plastic is just to get the dimensions right it will all be copper.) I have / would like to join the control group overpressure relief flow and that for the heating circuit overpressure together to one Tundish. It will be easy to workout which is flowing as they are on different circuits and the relief pressures differ significantly. The other Tundish will be exclusive to the Pressure / Temperature relief on the tank. Both then drop in 22mm to 28mm copper and then be routed to the drain in 28mm JG Speedfit plastic pipe. The runs to both Tundishes are less than 600mm the copper and JG pipe are both proof against the max output temperatures. I still need to figure out how to get from 28mm - to something I can connect to the soil pipe. so any thoughts on that gratefully accepted.
I was thinking about this on Thursday when I realised that our system volume is only enough when the Underfloor Heating (UFH) is in the loop when its just running through the domestic hot Water (DHW) tank the volume is a lot less. However I also feel that as far as the DHW tank is concerned the heat transfer is roughly reversable, I guess entropy and a few other factors will have a part to play, so the hot water in the tank will give its heat up to the circulating HP circuit and so all will be well. I dimly recall working out that we might need ~0.8kWh for a defrost, if all that comes from the Tank - because the other volume in the system during a DHW cycle is only around 31l (Including the tank coil) we would see a drop in water temperature of a few degrees which may or may not be a worry depending. (To use that side the heat pump will be in DHW mode so a set point is engaged somewhere and defrosts could result in it getting in loop trying to reach set point while being knocked back by defrost cycles). When the slab is in the loop and based on the same assumptions as for the tank defrost the temperature drop is a fraction of a degree across the slab, the systems volume then is around 60l, the slab is 60T of concrete and there is no close in setpoint to worry about.
Sum it up in one sentence then... Go on.
MikeSharp01 replied to ToughButterCup's topic in General Self Build & DIY Discussion
Depends which end of the telescope you are looking down so either a great way to while away a decade and spend loads and loads of cash or a tiny thing not remotely likely to be a problem and still a very long way off. -
What does this architectural symbol mean?
MikeSharp01 replied to Tony L's topic in Surveyors & Architects
The wisdom of crowds - used in ensemble method AI models (random forests) so yet another example of an old idea (Aristotle understood it) getting a new lease of life as part of AI, along with Bayes Theorem (1761) and the Neural Network itself really stemming from the 1950s development of the perceptron. -
Bit of fun - Spot the mistake - or perhaps there isn't one!
MikeSharp01 replied to MikeSharp01's topic in General Plumbing
Yep - you get today's prize. The drawing is crap, makes you wonder how good this stuff is. Your right I will be running mine at 1.5 bar - enough to meet the spec of the heat meter but no so much as to blow the socks off. -
The heat pump install proceeds at pace, well two steps forward and one back mostly. Todays one back is this filling loop I got from the plumbers merchant. Allegedly it is automatic, you dial up the pressure you want, open the valves and once it has done its business you close the valves. See if you can see anything wrong with the instructions and the parts as supplied.
So to today's questions on our ASHP install.
Yes that makes sense. So "b. be a separate branch pipe with no sanitary appliances connected to it;" means (not implies) the D2 pipe is a branch pipe itself? Hope that helps @Nickfromwales -
Spent the day working through Failure Modes and Effects Analysis (FMEA) of our ASHP system. I have hit on one which has me wondering if I have missed something. When the ASHP goes to heat the Domestic Hot Water (DHW) it provides a voltage to the changeover valve in the house that switches the ASHP flow from the Under Floor Heating (UFH) circuit to the DHW heating circuit. All well and good except that there is no feedback to the ASHP, that I can spot, that confirms the valve has actually moved and the the circulation is now running round the DHW circuit. In the situation where it fails to change over we will get the much hotter water, normally reserved for heating the DHW, flowing into our UFH which as a strict upper limit on the floor surface because of the floor coverings. There is a temperature probe feeding the DHW cylinder temperature back to the ASHP but the lag on that could be significant even supposing the ASHP has a mechanism for detecting that there is no rise in temperature of the DHW despite it apparently delivering 55oC water to the cylinder. This seems like an oversight to me, have I missed something or am I expected to provide an external solution - any thoughts or observations?
I did think about installing the TMV directly above the tank outlet but decided it made everything more messy so its just at the edge of the tank. Not many but if it saves me having too much heat loss into the Utility room, where all this kit resides, I might just create a loop as you suggest. Sorry not clear what you mean, you can get my pump onto the Schrader valves of both vessels as they are placed in the picture, the view angle makes it look like they are very close together or are you referring to something else? There is no room below the large vessel for one of those service valves but I could put the valve to one side or possibly lift both vessels up but the upper one will start to interfere with the hot and cold water manifolds which will be above it. Alternatively I could mount the large vessel horizontally if that is allowed? -
Does that not gain say what @SimonD says he always fits by way of a service valve. -
Oh - I was hoping to go into the main soil stack, center in image, in the corner of the room but if not I can round a bit and use the branch stack, right of center, which has nothing attached. -
No secondary circulation but need the TMV if I top up the UVC to 80+ with excess PV. -
Yes it's in a cupboard.
