Feels like there is risk either way. My analysis runs thus: A pre app and a full app are treated differently in my experience. Some things are fixed - boundary distances etc and going past them is difficult. The pre app is an opportunity for the planners to manage you into their preferred box - once you have a full app they are obliged to process that against the local plan etc and would want to be almost sure that they would win an appeal if you went to one. So the premise is you would likely get a bit more than they would encourage at pre app but won't let you bust any of the fixed / local plan points unless they feel they might lose an appeal. The 1200sqft version sounds like it overcomes the main objections so should go though but is is not what you really wanted so you risk getting that permission and not being happy with the house. The perhaps 1400sqft version does not address all the issues but might squeeze through on grounds of such things housing targets, the planners not being sure they would win on appeal and it being a good day in the planning office. Putting two in at once could both muddy the waters as @Pocster says and have the effect of encouraging the planners to go for the smaller house as it more closely matches their 'rules'. You can still appeal on either if you put both in however. On the whole, if it were me, I would put in the slightly bigger one making sure the majority of the red lines highlighted in the pre app are addressed fully / carefully and the remainder are as minimised as your team can do - looking to max your appeal winning opportunity and so give the council more reason to let it through and so avoid losing an appeal. This outcome is more like the house you want and you can always revert to the 1200 model if knocked back and not confident of winning on appeal. I appreciate that your outline planning permission deadline is approaching and that this adds another dimension but getting one planning cycle in before October, without going to appeal, is more than possible.
Oops I knocked something
MikeSharp01 replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
Reading this thread I would agree. You can check the probe with a cup of boiling water, allowed to cool for a few minutes and a kitchen thermometer it looks to be a DS18B20 or some such and to be on the safe side put the kitchen thermometer and the probe under the cup (not in the water). If the ASHP reads the same (roughly) as the kitchen thermometer under the cup then all is well and you can crack that bottle of Merlot you have been looking forward to all day. -
Who are you quoting, reference / citation needed!
First sketch of new house project
MikeSharp01 replied to Crofter's topic in New House & Self Build Design
Bed 1 downstairs indicates that you want to be ready for older age - if so do the CBD / WC swap make the WC a bit bigger, make it a wet room and Jack & Jill it with the Bedroom. -
Well essentially because I want 2 pipes going up the wall and 3 pipes going down so I thought this was quite elegant in its way, the ball valves are full bore and fast to operate.
- 5 replies
- plumbing design
- manifolds
I have come up with a manifold (I need 2 one for hot and one for cold) that is fabricated from soldered copper. Before I put them into manufacture I thought I would seek the collective wisdom's view on the idea - what have I missed / got wrong / forgotten. It has single 22mm inlet two main runs leading to 15mm outputs with a central balancing support run. We have good water pressure, 3 Bar at this point and very good flow. See image below and let.
- 5 replies
- plumbing design
- manifolds
We have Norrsken and air tightness is perfect- we scored 0.2 on PH basis with only the locks leaking a bit so we put the keys in for the air test and even without them blocked I don't suppose there would have been a measurable difference but the whistling was annoying before we blocked them.
What steps to take next after PP grant?
MikeSharp01 replied to flanagaj's topic in General Self Build & DIY Discussion
DO THIS FIRST DO NOT START ON SITE - NOTHING GET THE CIL EXEMPTION IN FIRST. -
Sadly this appears NOT to be reasonable but sadly it seems to be par for the course. We have had quite a few discussions about this on here and the conclusion is usually the same. Anecdotally the grant just adds to the normal, whatever that is, price. You do need to remember that there is a thing called supply and demand which brings a few more challenges. Firstly high demand often brings a lot of sub standard supply - so we see a lot of expensive but poor quality as companies bundle into the vacuum. So finding a reliable installer adds to one's angst. Secondly because a "proper" (note the quote marks) install needs MCS approval which drags in over specification which amplifies the issue above so increasing costs. You do have some options. For a saving on an MCS install seek out an umbrella scheme- which allows you to do a load of the work and the MCS installer just does the design and commissioning drawing down the grant for you. Alternatively do it all yourself with some advice on here to help you size the pump a local plumber and electrician to wire it all up. It will need planning permission to go this route.
onshape is very good, free - as long as you don't mind your drawings being public. and although a bit more complex than sketchup it is full featured.
We have just bitten the bullet and put an ensuite wet room off the snug area, which also serves as an accessible WC.
Will do, when they finally tie down the spec, as things stand it keeps coming and going from their web site, something to do with MCS certification.
The one we are looking at has a Panasonic DC Inverter Compressor - which is the real heart of the machine I guess.
The ASHP we are looking at says the COPs up to 5.56 is that the limit should I be looking for one that get up to 8 or is the quote from the manufacturer based on some output value?
Drivers, drivers everywhere - isn't there a better way?
MikeSharp01 replied to Benpointer's topic in Lighting
Some of them yes. Look out for the logo on the box. -
Not if you use the right approach (Trailing edge / phase-cut) suitably choked surely! -
Look at the Whitewing driver units for either LV LED or 240V LED, we have one, not yet commissioned, controls 16 channels of 240 LED lights DMX controlled and fully dimmable, all in a single DIN rail mounting unit about 200mm x 120mm. Here is one we have: https://whitewing.co.uk/acdim.html I think others on here have these as well. -
Advice on how water heating
Its a long story, we have 1600mm x 600mm x 600 and this is directly below the MVHR unit. At this point the house is single story and it is close to the outer wall so everything is tight. The original plan was a Sunamp unit where we are now thinking we will put the UVC the Sunamp being much lower. However given the tribulations with the Sunamp units we have chosen to go for a UVC instead run from the heat pump but also chargeable via cheap electricity (Octopus agile / solar PV). So the space is limited by the original plan. We can get a Telford tempest (200l) in there, just but only if we can turn directly out of the top of the unit. Their 170 & 150 units fit with plenty of head room. There is only two of us and the house is just two bedrooms, two bathrooms, albeit spread of 153m2. -
Is that not a G3 / MCS requirement - 100mm clear run of pipe straight out of the top! (I was told this was a requirement by one of the possible suppliers we investigated for our system.) -
Had a look at the Telford Tempest, 200l we are only a two bedroom home so that should be OK and I am confident we cannot fit 300l into the space we have. Although if I could do away with 100mm of straight pipe from the outlet we could go 100mm higher but max Diameter I 600mm. -
I have been looking for a 200l cylinder, we only need about 150l, and I have not found on that has a coil that big, I have found one with 1.9m2 if you connect both the main and secondary coils in series.
