Redbeard
Everything posted by Redbeard
Is this it? https://www.ukseptictanks.co.uk/ecoflo-nonelectric-sewage-treatment-6
Golden opportunity to sort out the basics - insulation, air-tightness and heating - while you are going to endure inconvenience anyway. Welcome and all the best with it.
Hello. It all depends (perhaps among other things) on the foundations. If the foundation was calculated quite tightly for a single storey then no, you probably cannot add a 2nd storey without underpinning (reinforcing the foundation). Underpinning is generally (arguably should be) done by specialists, so in some circumstances taking down and rebuilding (and maybe taking the chance to get Planning for a bigger extension) might be not much more expensive. Oh, and hold on, it's at the front. I am not particularly well-versed in Planning, but there may be more limitations on the front elevation than others. Hopefully someone else will chip in on this one.
Kitchen floor tiles got me thinking generally. Have you had an asbestos survey/are you used to looking for it? No wish to teach anyone to suck eggs. If you haven't come across it much before can I suggest HSE, and particularly their 'Asbestos Essentials' as bedtime reading? Looks like fun generally, though!
Fabric and ventilation heat loss calculator
Redbeard replied to Jeremy Harris's topic in Heat Insulation
This:(https://warmafloor.co.uk/support-centre/u-values/#:~:text=U-Values of uninsulated ground floor&text=In order to meet the,by the addition of insulation.) has a useful 'ready reckoner' based on the IP3/90 Information Paper. This (https://www.gov.scot/binaries/content/documents/govscot/publications/advice-and-guidance/2020/02/tables-of-u-values-and-thermal-conductivity/documents/6-c---u-values-of-ground-floors-and-basements/6-c---u-values-of-ground-floors-and-basements/govscot%3Adocument/6.C%2B-%2BU-values%2Bof%2Bground%2Bfloors%2Band%2Bbasements%2B%2B.pdf) from Scottish Gov't, usefully separates out solid and suspended floors which the other one does not.- 204 replies
- heat loss
- ventilation
(and 4 more)
It couldn't be a second pump, a 'secondary return' for the domestic HW cylinder, could it? Is there only one pump, or is it a combi boiler? If so, ignore my suggestion.
I think if it were me I might be getting ball-park prices from local GRP/EPDM flat roofing contractors with a view to offering the neighbour a 'sweetener' which could lie somewhere between a percentage of the estimated cost of re-roofing their exg extension on the exg deck and the full cost of re-building their roof to become a Warm Roof (like yours might become, clearances permitting - I'm thinking windows, flues, whatever).
Welcome! I assume those are not in priority order, but if they were intended to be I would switch 1 and 2 and fit in the current 3 and 4 around 1 and 2 (or 2 and 1!). Sounds like a good blank canvas. Will you be able to do all works while it is empty, or do you need to live there during works? Are you planning EWI? Edit: Just seen your thread re EWI. Cancel above Q!
How old is the house? Victorian houses often had wooden dowels instead of angle beads. If you chop a little bit out of the corner and insert a dowel you can then re-skim the reveal up to the dowel. If you want 'chunky', broom-sticks are cheap!
Make sure you use *Airtight* foam. Illbruck FM330 is what I use, but Soudal (and probably others) do one too. Not all foam is air-tight.
You've probably looked all this up, but the Green Building Co (Greenbuildingstore.co.uk) has used Diathonite a bit, but internally if memory serves me correctly. Apparently v good for air-tightness. Can also be used for EWI, as you say. https://luneretrofit.com/ had it spray-applied externally a few years back.
Yes, but you mitigate that by returning onto the relevant wall (internal or party). Typical return is min 400mm-ish
If it is something like Intello, which is an intelligent VCL *and* an a/t layer, yes, don't tape, but a/t is not necessarily vapour-tight, so if it's a run-of-the-mill a/t layer you arguably need a VCL too. (which may be the taped jts, but I would use air- (and vapour-) tight tape, not foil tape. 1. For improved adhesion and 2. particularly at corners, foil tape can tear, and then it is not a VCL anymore.
I think I would still err towards rigid wood-fibre, and getting rid of as much of the sand/cement as you can, and me being me, I'd lime parge-coat first and go with the shape of the wall. I think right-angles are over-rated, but of course you do not have to agree! Quick comment on the VCL. I am, and others who feel the same are, regarded as pernickety for this, but I take the view that where the 2 boards butt there is no VCL, since they rarely go 100% tight to each other. In scenario 2 you can tape the 50mm as VCL and then the 10mm on top matters little if it is not 100% tight at the joints. This (https://www.gov.uk/government/publications/retrofit-internal-wall-insulation-best-practice) is the Gov't's Best Practice advice, introduced so 'quietly' a year or two ago that many people I know have never heard of it! It states that vapour-closed insulants should *only* be used if there is a fully-ventilated min. 25mm cavity behind. This could mean 4 air-bricks per wall per room if there is not connection from one storey to the next. Imagine that on 450mm rubble-filled walls! It would appear that the insulation merchants have not heard of this, and I am not sure about the manuf'rs either. You can certainly find plenty of unventilated/hard-to-the-wall solutions online. Edit: Just noted the bit re mechanical fixings being tricky. Yep, that makes rigid wood-fibre hard. Studwork, flexi WF and 20mm rigid WF as plaster carrier? Too thick perhaps.
Roof ventilation help condensation and mould
Redbeard replied to Looba45's topic in Roofing, Tiling & Slating
Is there a leak in the extractor fan duct, or around its exit through the bathroom ceiling (i.e. are you feeding water vapour into the eaves void? In terms of 'quality' of ventilation I much prefer eaves ventilation (preferably about 25mm) across the whole width of the roof on both sides, so that you have excellent cross ventilation. In most of the situations I come across with a roof moisture problem where a few tile vents have been used, the problem continues, suggesting that whatever number of tile vents you think of putting in, it's often not enough. Add to that the fact that they tend to start say 900mm above the gutter, and that leaves the water vapour 'un-purged' from the bottom of the triangle. -
Airtightness tips for dormer loft conversion
Redbeard replied to ectoplasmosis's topic in Heat Insulation
Are you looking at A/T membrane inboard of the PIR? Do you have a wind-tightness membrane externally? For internal A/T membrane I would (and did) use Intello. Not cheap but seems to do the business. -
Removed
@Jilly, this was not my understanding. The OP said, in the OP, "our ground loop to run our Geothermal pump has failed". Have I missed something?
Soakaway and compost toilet? The uphill Poop Transport System does not sound cheap.
If it's less than 15 degrees it does not comply with the manuf'r's requirements. Did you have the work done, or a previous owner?
Look for local loft conversions in progress and scrutinise the skips.
OK, I'll be the first! I am not sure what your problem is. Can you elaborate? You have drawings so you have an idea of the size. As far as I can see you just need to build to that point, check the 'real' measurements and cut and install your triangle to prepared fixing points. Is it the choice of board, the cutting of the star itself, the exact measurement, or A N Other thing upon which you need advice? One thing I'd want to know is what the cut edges of the board would look after machining. It's no good getting a self-coloured board that then requires a bit of ('matching'?) paint slapped on when it's cut.
