Redbeard
Everything posted by Redbeard
Recommendations for solar thermal suppliers
Redbeard replied to ChrisSig's topic in Solar Thermal (ST)
Appreciate you may have meant other Regs, but B. regs and PD (or not, in some v limited circs) will, I think, still apply. Bldg Regs predominantly re structurals and HW storage (but you have that already), I assume. Ages and ages since I had anything to do with a ST install. -
Summerhouse- 4cm over height of 'permitted development
Redbeard replied to BLISSY's topic in Garages & Workshops
I think it's Planning (potential breach of PD conditions) that the OP is concerned about, not BC. -
Agree with @JohnMo and @ProDave. Do it now and you have 'right on your side'. Obviously if everything is tight to the ground you will have to be careful not to make anything soggy, but hopefully (if it's not a solid floor) you left some 'breathing space' anyway. -
Yes, lots more info and pics, please. How deep a reveal are they on? Is the leak all round? Is it concentrated at the top/sides/... where? Have you established that the leak is at the window-frame - timber frame joint? Could it be the opening lights somehow not sealing? Lots more please!
Forgive the Q if the answer is too obvious, but you say ''the gap between the screed and the external walls has been filled with expanding foam''. Was this air-tight foam? AIUI All air-tight foam is claimed to be air-tight (of course!) but not *all* exp foam is air-tight. I would not bother is *air-tight paint* over *air-tight tape* unless you feel some of the adhesion is less than 100%
Use lime if you can. If you want to use a fair bit of time just chop out the 'baggy' bits, fill with NHL 3.5 (or lime putty) 1: 3 with grit sand, and then re-skim the whole with 2 or 3:1 sand and lime putty (or NHL 3.5). A little more tricky on the L & P ceilings, where chopping bits out may dislodge the lot - but it may not. If you want to experiment a bit, as it does not have to be too strong, you could buy hydrated lime (available at most builders' merchants as it is sold as more of an admixture to sand/cement than as a 'use it alone' thing), soak it in a metal bucket or bin and make your own lime putty. As long as water stays on top of it it will remain usable - for years.
Foam gun lost propellant?
Redbeard replied to Sparrowhawk's topic in General Self Build & DIY Discussion
Youtube has gun-fettling videos. I have probably 5-10 guns waiting, and I have done a couple in the past. From memory it is a PITA, but it works. -
Good! Glad that's cleared up then!
Missing insulation in vaulted ceiling
Redbeard replied to d87francis's topic in Lofts, Dormers & Loft Conversions
When you say 'pitched warm roof' I think you are referring to PIR board fixed *inside*, under the rafters. Strictly a 'Warm Roof' is where the insulation is *on top of* the roof structure, just below the membrane and slates, thus all of the roof timbers are within the thermal envelope. Can you confirm that you mean the former (or that I am wrong in my supposition!)? Either way, pre-June 2022 (target 0.18W/m2K) you'd have just scraped through with 125mm, provided the 'timber fraction' (the part of the 'insulation layer' which is actually wood, not insulation) is not unusually big. As far access goes for the remedial work how deep are the rafters? Common practice since 2010 regs in retrofitting roof insulation to sloping ceilings has been to fill rafter depth minus 25mm, leaving a 25mm vent gap between the membrane and the insulation. BEIS Best Practice guidance now states 50mm as the ideal, so you might, if your rafters are less than 175 deep, find that you have to fit insulation under the rafters too (which is in any case good as a cloaking of the thermal bridge - if you don't do that then add up the width of your rafters to see how much 'full-depth wood' is in your insulation layer. Anyway, yes, ceilings down - no way you could do it properly without. If you try, and can slide the insulation in easily then it is too loose. Sounds like you have a really irritating issue, and I wish you luck with the remediation. -
Documents required for building control sign off
Redbeard replied to Moonshine's topic in Building Regulations
Sorry to hear that! For SAP you need a (Full) SAP assessor. I think you need to know what they mean by 'heating certificate', because I am not sure I do. Elec cert should be OK if your spark is a member of a self-cert scheme. Unvented Cylinder Benchmark Certificate - not sure who you get this from but I doubt it should be difficult. 'Any Other certificate...' - MVHR? Best of luck. -
Depends how much your roof void needed the 8. Would be a shame to use 2 and then find that you have a condensation problem in the roof void.
Flashing for Large Rooflight in Pitched roof
Redbeard replied to David99's topic in Skylights & Roof Windows
Not the Q, but I am intrigued as to how you will make a permanent, waterproof seal between the vertical glass and the roof glass. Will the roof glass meet the vertical glass via silicone, or will the frame of the roof glass be cleverly rebated so that the glass on each plane rebates into the frame? -
'Skeiling' = sloping part of ceiling. Otherwise known as combs or sloping soffits.
The Conor Threshold: the Lancashire version
Redbeard replied to ToughButterCup's topic in Rainwater, Guttering & SuDS
Will you be marketing the small ships? Can I put in an advance order? -
Is the ceiling already in? Or (hopefully) is the plasterboard still to go on? Have you any pics to show the issue? Membrane, lots of tape and some Passive Purple or similar? Of course stud walls make it more difficult, but unless everything is boarded up, that should not make it impossible. You'll just have to cut and tape around each stud (/top plate if applicable).
Fermacell Fine Surface Treatment, I think it is called. I have only ever used Fermacell once, for a part of IWI to a kitchen where we needed to hang potentially heavy-when-full cupboards on the wall. Instead of 25mm battens over PIR, then plasterboard, we used 25mm ply, then Fermacell, giving us 37mm (? - can't remember F'cell thickness) of hefty stuff (on v long screws) to screw cupbds to. We just had it skimmed in board finish, the same as the surrounding plasterboard.
14 hours ago, Temp said: ...and Sparrowhawk replied: My thought too. If you can hear it as you move, how much flex are you feeling in the floor? As per the OP's description The construction of the flooring is (bottom up): Concrete Plastic Membrane Plywood Laminate (glued down) The 'squidge' appears to be occurring between the concrete and the plastic immediately on top of it. I don't think there is any suggestion that the concrete is moving.
Question from Left Field... Do you have proof that the floor is insulated, as of course it should be? It still does not make great sense since, if it wasn't, the condensation would be on the *top-side *, not the underside, of the plastic, but I am trying to play Devil's advocate so that you ensure that all the variables, however unlikely, have been considered.
How is the knee wall fitted? If it was already there, then after carefully establishing that it was non-load-bearing I would have taken it out, insulated the entire sloping ceiling and then fixed the 'knee wall' (cupboard-front) through it to the (carefully-marked!) rafters. If you did that the wall is entirely 'on the warm side' of the insulation, with insulation above and a habitable room below, and there can be no thermal bridge, as I understand your description.
Both of these firms are in the wrong part(s) of the country but they might be able to signpost you to an 'industry contact': Green Building Store, Golcar and Solarcrest, Macclesfield. I note that GBS's approved installer list includes 2 in 'the South': https://www.greenbuildingstore.co.uk/mvhr-installers/ You might also try RetrofitWorks in London who may be able to give you a contact.
