Redbeard
Everything posted by Redbeard
Cardboard shims/furring strips for studwork
Redbeard replied to markharro's topic in General Joinery
Packers for slightly-out-of-line studwork, I had assumed. -
Bu**er! That was my favourite! Hope you find it.
Architect & Planning cost confusion
Redbeard replied to Ryan Turner's topic in Surveyors & Architects
I think last time I did a B. Regs app with more than one element the cheapest one was halved in price, so in your case it could be £809 + £275.50. I think I would be tempted to do it on a Building Notice (Simple Bldg Regs app with a brief descr of works and no other detail) rather than Full Plans, but then I'd be building it myself. Depends on the degree of complexity and how much you trust your builder. Planning looks like it ought to be really simple, I *think*. You could draw that, and thus do the Plg app, yourself, perhaps. Re struct eng'r I suppose you'll at least be changing lintels, if not roof timbers, so yes, you need them, I think. -
I would have said mortar, had I not assumed that you were looking for a very quick fix.
I take your point, but if you look at it in the context of a whole-house plan enacted over a very long period (possibly finished by the person(s) after you), there's still logic in getting the best you can from each element that you do 'enact'. I fully expect my refurbishment to be finished sometime after I am dead! Depending on how much work you are doing yourself the actual 'spend' could be as little as the cost of an extra 50mm. Agree also with 50, not 25mm upstand at perimeter.
You are asking for comments on the TF, but may I ask about the floor? What U value do you get with 100mm PIR? Could you fit 150 in (or even greater thickness and use graphite EPS instead of PIR)? Will you have under-floor heating? If so others will be along to highlight the greater delta T (and therefore the justification for more insulation).
Epoxy, or CT1, which my former colleague claims will stick more-or-less anything to anything! I don't know anything about Soudal Plasterboard Adhesive but wonder if an adhesive made for a dry indoor environment would do well in a wet outside one... (Happy to be proved too sceptical)
Agree with the comments above. I am sure there's more to the process so far than I read, but it sounds like *you* have come up with a compromise so that *they* can get PP. Not sure where the 'balance of power' is there, and agree with others that you should at least look at the issue of future sale now, before development, whatever the 'inducements', even if your ultimate conclusion that it will sell with no probs. It sound like not a fun position to be in - literally - and I wish you luck with the outcome.
Improving living conditions in my mum's damp and humid small bungalow
Redbeard replied to minty's topic in Ventilation
The plastic is a Vapour control layer (VCL) which is designed to stop 'interstitial condensation (water vapour condensing out in the insulated wall 'sandwich). Unless you are planning to change completely the 'moisture behaviour' of your Mum's house no, you do not necessarily need to remove it, but if you are adding more insulation internally you might, as you would then install a VCL on the 'warm side' (just behind the plasterboard) of that new insulation. Edit: Was typing while @Crofter typed. -
PIV = Positive Input Ventilation, as described by Andehh -
ST = Buildhub member @SteamyTea dMVHR. Decentralised mechanical ventilation with heat recovery. Decentralised because he's not talking about 'full monty' MVHR systems which have a central heat exchange unit. dMEV (decentralised mechanical extract ventilation) involves using specifically-designed fans in wet areas (bathrooms and kitchens) which run permanently at very low wattage (perhaps less than 2 Watts). They also have an over-ride (pull-cord or - my preference - humidistat) which kicks the fan in when things get too steamy. They rely on having open vents (often 'trickle vents in the window frames) in all the 'dry' rooms, so that the extract from the wet rooms causes supply air (from outside and usually more dry) to flow in. It's very simple with no complicated 'control interfaces. CV2 is simply the model number of the 'Greenwood (manufacturer) Unity dMEV fans I have bought. -
Agree with ST's dMVHR suggestion, but if you want to go a bit cheaper and forego the HR, decentralised mechanical extract ventilation (dMEV) may be an idea. Some have spoken of it highly on here and I have 3 Greenwood Unity CV2 units waiting to go in. -
I realise these 2 are not using GSHP, but I was answering your 1st post, not your 2nd. Both these use(d) solar thermal. Simple trickle at CAT and, I think, evac tubes in Tony's House. I think he is a member here so he might pop in to the discussion.
Tony Cowling also has ISHS, I think. He described it in a recent AECB webinar. http://tonyshouse.readinguk.org/
Centre for Alternative Technology in Machynlleth did. The basis was experimental (and cheap, I guess!), so it (water-trickle solar roof over black-painted crinkly tin feeding a 100,000 litre - IIRC -thermal store which ultimately leaked) proved the concept very well. The store was a big hole lined with huge EPS blocks and lined with pond-liner. I believe the issue was that the liner used to extrude into gaps between blocks and pop! I believe the short-lived Earth Centre at Conisborough had an inter-seasonal heat store too, but I am not sure how well that worked.
1930s house: some render cracking may (or may not) be indicative of wall-tie failure/degeneration. Lots of firms out there, but does anyone have any recommendations from real-life experience in this (S. Yorks/N. Derbyshire) area? In the past I'd have done it myself but not feasible now. Thanks in anticipation.
So are you allowed to use expanding foam or not?
Redbeard replied to CalvinHobbes's topic in Windows & Glazing
There's a great difference between using a bit of air-tight foam for specific purposes such as air-tightness round windows and joist ends and foaming up a whole roof. I think it's the latter application that upsets Bldg Soc's rather than the very reasonable use of small amounts for small applications (though I could be wrong and they may be more twitchy than I thought!) -
I had originally taken that as 'walls with a 4" cavity'. I suppose it could also mean ' 2 skins of 4(and a bit?) inch brickwork, with a cavity (width unspecified)'. What age is the house? I don't *think* I have ever come across a 4" unfilled cavity. They tend to be around 2" or even less. (I accept that anomalies exist. If you do have a 4" cavity then with graphite EPS bonded beads blown in you could possibly achieve a U value (unadjusted for (e.g) bridging at cavity closures etc.) of under 0.27W/m2K, which is none too shabby.
Hello! Can we assume that the exg masonry is rendered?
How to fill / seal gaps between skirting and hard floor?
Redbeard replied to embra's topic in Decorating
Hmm. Exactly what I was going to ask. I have used it a lot, but always hidden, so I have never tried to paint it. Anyone tried painting Orcon F? -
Ventilation... 'Breathing Wall'
Garage door posting has gone at the bottom
Redbeard replied to EmilyT's topic in Garage & Cellar Conversions
As @joe90 says, what you do may depend on whether the mechanism extends down that far and is fixed to that part. If it is not, how about trying to get hold of some 'plastic lumber' (think some park bench seats) and scarfing that in? Wood-rot problem gone, and I for one will probably be dead before the 'plastic weevils' (take that either way) have done their stufff. -
Internal wall insulation - bedrooms / solid stone walls
Redbeard replied to RichardL's topic in Heat Insulation
I like to use rigid wood-fibre on a lime parge (air-tightness) coat. It's fairly DIY if you are quite handy and good at attention to detail.
