Beau
Everything posted by Beau
ASHP - how noisy are they in reality
Beau replied to Walshie's topic in Air Source Heat Pumps (ASHP)
Not at all. I was very familiar with our old GSHP but haven't really got my head around this ASHP and its controls There are two controllers. One is now built into a cupboard as I was told I wouldn't need to touch it once up and running and the other does have an installer level section but I cant see anything about flow rates on it. -
It's built into the heat pump. According to the specs flow rates go from 540-1205 l/h. My gut feeling listening to it is it operates at one or the other and doesn't modulate between the two. -
I suspect your right but not sure what to do about it. This morning I came down and it was just audible like say a gas boiler in a neighbouring room. Now it's just stepped up more like I am in the room with a boiler even though is not cold outside and flow temps are low. Sometimes when its cold you get a two noises one is just rushing water in pipes but there is a second like a distant car is coming up our quiet country road but never gets here. I think the second noise is the heat pump running getting carried through the pipes. It's interesting that others say their systems are near silent as I had just put it down to the ASHPs needing high flow rates but maybe this is not the case. I did mention it early on to the installer but they just shrugged as though it was normal. On the water noise in the pipes I dont think I saw them deburr inside any of the pipes it was just pipe cutter then clamp. Could the burrs be causing turbulence and in turn the noise of rushing water? -
We live on Dartmoor. It's around 11C outside and been gusting 55 kmh. The house is only part renovated and we get poor solar gain due to having just two south facing windows and are very shaded from the east. -
Thanks SteamyTea Right now flow temp is down at 25c for an inside temp of 18C but the rads are still noisy. Its set up to only run from weather comp. Highest flow I have seen is 38C but I dont check it very often and dont yet have an app to easily see whats happening. No idea what the flow rates are as not sure where to find that info -
We have the Vaillant aroTHERM plus 7kW. Its not bad but a bit noisy when working hard. Also get an annoying resonance at times. If I press against the case it stops but haven't yet been able to trace the cause. The sound of the water flowing around the rads is quite intrusive especially on the first few rads in the system. I say all this but having gone from no heating system it was always going to be different and we live remotely so dont have any background noise to mask the noise the system makes. -
dMVHR suppliers list (not complete)
Beau replied to HughF's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We installed the BSK Zepher in utility/bathroom. Cant honestly say I can tell the difference in room temp between MVHR mode and continues extraction mode. Just going to instal the Greenwood DMEV units in the other places we were going to use DMVHRs and use the saved money on a bit of extra juice to run the heat pump. -
Microcement for kitchen worktops - any advice?
Beau replied to Vesa's topic in General Self Build & DIY Discussion
I've just got sent some colour samples from a microcement supplier. Been using them as coasters and they have proved hot coffee cup proof so far 😄 -
Installing shower with tile backer boards
Beau replied to tommyleestaples's topic in Wall Tiles & Tiling
I might look at setting the tray in under the backer board a bit. I recently installed a tray relying on the tiles for the overhand but trays are not always perfectly straight and true so it was a bit marginal. I added a shower sealing kit which has a tape which you bond to the backer and tray to get a good seal. Even that was a pain as the provided seal/glue didn't stick to the tray well. I used Jackoboard but will be going back to MS plasterboard and relying on the sealing kit to keep things dry for the next one. -
Anyone considered a compact tractor?
Beau replied to Drellingore's topic in General Self Build & DIY Discussion
We have a small farm and I have done major renovations on site. We have a compact-ish tractor which was handy for doing forklift work but clumsy. We now have a dedicated pivot steer loader which is massively better for doing forklift type work due to the control which is in part due to the hydrostatic drive. I've never been tempted to get a backhoe as again manoeuvrability is all for this sort of work. When I need a digger I hire one and did so with a pecker to break up the concrete in a barn we converted. Other times when doing groundworks I think having a good driver in their own JCB leaving you free to move and direct is better value as you get so much more done in a day. -
I'm only a self builder and have done bathrooms a few different ways. Last one I used Jackoboard and by the time I had sealed all the joints and penetrations there wasn't that much left uncovered with the sealant and there was enough in the pack to cover the whole area anyway! Next tiled bathroom I will be using moisture resistant plasterboard and sealant.
Plant Room Distance from ASHP - 25m too far?
Beau replied to SBMS's topic in Air Source Heat Pumps (ASHP)
Our Vallient has the circulation pump in the heat pump -
Sorry for endless questions but I am presuming screwing floorboards over it is alright? Just envisioning it getting crushed when screwing down especially on the ends with small contact point.
Dyslexic me not reading things right. I saw 50mm and thought depth even though you clearly state width I will have a look into them as I suspect isolating the floor boards from the joist would be very effective Something like this? https://www.affixit.co.uk/resilient-floor-tape.html?gad_source=1&gclid=Cj0KCQjwytS-BhCKARIsAMGJyzpTKk0V_IiQFt2eKMd07jjuHNF9DwWr-1wxHEwb4Xz4bYq08rtZz4IaArsTEALw_wcB#180=844
Hi Nick. It's carpet in the main bedroom and vinyl in the en-suit. It's already a low room so raising the floor much is not an option we would take. We are not paranoid about soundproofing just want it better than it has been which shouldn't be difficult as there hasn't been any sound proofing up to now.
Morning all. I'm about to start putting a bedroom and bathroom floor down in our renovation. It's directly over the kitchen which is the heart of the home. I'm wondering what to do to limit sound transfer through the floors. Is it best to maximise on acoustic insulation slab between the joists or would an acoustic underlay make a big difference? I'm not intending to touch the ceiling below on this round of works so resilient strip isn't an option. Thanks
We had an anhydrite screed. The advice at the time was leave to dry, sand/grind the surface to remove the surface fines and then prime. I used a diamond grinder on small angle grinder which made one heluva mess but worked. The primer was something I think called Ozin 260 but can check tomorrow if helpful as I think the old tub is still sitting about. Think it was only one coat. Anyway that was 18 years ago and tiles have never budged
Considering PIV
Beau replied to MortarThePoint's topic in Mechanical Ventilation with Heat Recovery (MVHR)
This is the route we are taking after your help on here. Extract from known wet areas and no risk of interstitial condensation. A friend has a PIV unit and I guess no heater as it was noticeably cold in the area it blows in. -
Is it time to start getting creative with kitchens?
Beau replied to Bancroft's topic in Kitchen Units & Worktops
Just another vote for lots of draws. I built quite a lot into our last kitchen but will be almost all draws in the next one. At the planning stages so interesting following this. As for 'Kettles/toasters/coffee makers/air fryers' I'm looking at a separate work area for these away from the main prep space. No way can I be bothered getting them all in an out of cupboards all the time. We got a combined microwave/airfryer which saves a bit of space -
How would you recreate this when using plasterboard?
Beau replied to Beau's topic in General Construction Issues
Reading more about I think you are right. I was overcomplicating things as ever haha I will see if my plasterer is happy to do this if I make up the wooden 'quirks' which seems to be the right term -
We are doing up an old place on a limited budget. In the ideal world we would be replastering all the walls with lime but we simply dont have the budget but we dont want to make the place characterless either. Can we recreate this relatively easily with pink and plasterboard? I'm a woodworker by trade so can make most things if needed. I'm presuming it's not just a of making some dowel and bonding it in on the corners.
Geberit in wall WC frame - instal height?
Beau replied to markharro's topic in Bathrooms, Ensuites & Wetrooms
We bought a 'comfort hight' pan and the top of the seat is 475mm high. We got it as we have some elderly parents who come to stay and thought it would be nice for them. They have still to visit and we dont really like the extra hight but either of us are tall
