Beau
Everything posted by Beau
  1. It's all internal in a utility room except the ground loops. It's an IVT Greenline C6 I guess it does make a noise but its the noise of a circulation pump which seems to sort of blend in. The ASHP varies a lot but is a bit intrusive if you are outside when its working hard. Mind you most of us will not be outside on a cold winters day haha. Also its sized more for when our place is finished so is working harder than it will need to when I'm done. We also get a noise from the water running through the rads which we never had with the GSHP combined with UFH. It maybe a design issue but its quite an obvious noise
  2. We have had a GSHP in our barn for 18 years with UFH and have just installed an ASHP in the farmhouse. The GSHP is much quieter for sure but the ASHP is not especially noisy but quite noticeable in our quiet rural location when it's working hard (Vaillant Arotherm 7). The farmhouse is only part insulated, has EWI, yet to receive loft insulation, no floor insulation, rads, and in spite of these things the ASHP has managed to heat it at a COP of over 4 since installation last autumn according to its stats. No problems keeping it warm thats for sure. A new build with all its insulation should be a doddle to heat with an ASHP
  3. I didn't know that. Every days a school day as they say Many thanks
  4. Thanks Nick Yes, that's probably my only easy option. I did presume they were OK to cut down in length but dont want to mess with parts until I'm committed to a plan of attack. The 90 in the second picture is on 90mm pipe. Do you think it would be better to use that or swop to 110mm as soon as I'm through the Gerberit frame? I wondered if the extra flow through the smaller pipe so close to the pan might be beneficial at preventing blockages
  5. Thanks for the suggestions. Just as I thought I had a plan I discovered that any fitting for 110mm pipe won't fit through the Gerberit Duo frame. It comes with a 90 and a straight connectors but seems angles are not an option. Probably going back to plan A and get the 110mm soil pipe parallel-ish with the wall and have a straight connector out the pan (which fits the frame) going to a 90 onto the 110 soil pipe. Hopefully there is enough wiggle room in all the those joints to line thing up properly. Picture attached "I think rats are a consideration if this is ground or basement level though." Thanks for the warning. Its a working farm with loads of hollows in the rubble filled walls. There is a risk of rodents so a flexible connector now has an extra black mark by it haha Nothing's ever easy is it!
  6. I'm putting in a new WC. I've drilled nearly a meter through the wall to get the 110mm waste out in the right place outside so I really don't want to move the soil pipe. It's a wall hung WC and we would like the stud It's mounted on to be around the line of the yellow level but it can go back or forwards a bit and the pan approximately where the hawk is. What I'm undecided on is how best to do the waste. My original plan was to have a 45 to get it to run parallel with the back wall and then a 90 to go to the back of the pan. Then I thought why not just have a 45 pan connector straight onto the pipe in the picture but I don't think I would have enough flexibility in a single joint as the natural angle is nearer 55 degrees. I'm presuming flexible connectors are just asking for trouble? What do you think?
  7. OK I'll bite. I don't know the reasons but cables can make a major difference to the sound on a decent hifi system. Many moons ago I got to do a barter with friend who was working as a hifi reviewer for the magazines. He needed some wood work and in exchange I got to try out and keep some hifi equipment. We were nearly done and he then asked about my speaker cables. I was using QED 200 strand which was considered an OK budget cable at the time. He went up into the loft and handed me 3 hefty coils of speaker cable and I was sent off to compare them and report back as he always valued a second opinion. All were Audioquest and of a similar thickness and length. I would play the same track over and over while swopping cables. The first two I tried were better than mine and slightly different from one another but nothing dramatic. The third one I tried was a step change (Audioquest Hyperlitz for anyone who is interested) Everything sounded more open and simply more musical. It made as much difference as a major upgrade to an amp or the speakers. Turned out it was the most expensive at £95 per metre and I had 2x 7.5 lengths of it which I was allowed to keep. I ended up with cables, a pre amp and some amazing if eclectic speakers in exchange for building some garage doors and a chair. I think was the winner in that barter not that I think he had to pay for any of the gear. When he wrote favourable reviews they didn't always ask for the equipment to be returned. Also don't neglect your room. When we moved into the barn I set up this same hifi system and it sounded completely different and in a BAD way. It became way to bright and in your face due to all the flat reflective surfaces, tiles not carpet and general lack off stuff to break up and absorb sound waves.
  8. What are you looking for from an alternative? Douglas fir and larch should be as cheap as you are going to get per m2
  9. I was just chatting with our sparky about this as I was laying in some cables last week. My question was did I need to clip the cables or was it OK to lay the cables over the insulation. He was happy with them laid on top of the insulation. I suspect that if they were laid on the plaster board with insulation over the top they could heat up up lessening their current carrying capacity.
  10. The problem is I've have been spoilt with a decent hifi system. If I just chuck in some basic surround sound gear I think my inner hifi snob would rear it's ugly head 🤣 I'm so out of touch as last time I looked at surround gear it was 5.1 haha. Denon used to make a surround amp that just did 3 channel and used your regular system for the front which is the rout I would have taken. This doesn't seem to be a thing any more.
  11. Hmmm now you have me worried as I thought it was something you could DIY, the manufacturer sells it as such. I'm not a plasterer but can do a decent job dry lining but not with pink. The process sounded time consuming but not as much of an art as applying pink. Also it claims to be fully waterproof. Are they overselling it and have I got these things wrong?
  12. Following this with interest but quickly coming to the conclusion its very expensive and pretty complicated with so many speakers required. Will now probably stick with a good stereo and treat ourselves to a subwoofer. Good luck with your project Pocster
  13. I've nearly settled on using micro cement for the walls on our shower cubical. I've never used the stuff before but on paper like the simplicity, no grout and cost. Looking at the installation advice I should use WR plasterboard sealed onto the shower tray, skimmed and then the micro cement. I was wondering if any of you have any comment good or bad about the stuff and the backing before I commit to this plan. Thanks
  14. Yet to sort our TV room but do many films make good use of surround sound? I only ask as when we do go to the cinema (not often) there is the odd effect but most of the soundscape appears to be just regular stereo. I was just planning to stick with a good stereo hifi but wondering if we are missing out and we should plan for a full surround system.
  15. We installed an induction hob in our barn conversion probably 15 years ago. As others have said it's lovely to cook on but touch controls can be a pain especially when you want to turn something down in a rush as it about to boil over. Recently moved into the old farmhouse and the first thing we did was rip out the LPG AGA which as to be the most inefficient and just all round dreadful cooker ever invented. Over 2K a year in bulk tank LPG to heat one room, the hot water and cook. Picked up a SH, faulty Falcon range cooker with induction hob. Not a cheap fix but ended up a third the price of a new one. Knobs for controls and no turning itself off when you boil something over so now it's our favourite cooker ever
  16. 14.5K here after the grant for Vaillant aroTherm plus 7kW, hot tank, 11 rads and all plumbing. I'm sure they made a hansom profit but unless you are ballsy enough to design and do it yourself they have you by the short and curly's.
  17. So shrinking treads is quite possible the cause. As above I would see if it will press back or use a sacrificial piece of spare wood held over the nosing and give it a good thump with a hammer and hopefully it will push it back. I would test fist to see if it will move and if yes then run some glue in and tap/clamp back into position. Another way might be to screw and plug from the front of the nosing to pull it together as clamping maybe tricky. If it wont move wait until everything is fully dry and fill the crack either with epoxy if you think it needs reinforcing or just a coloured filler if not needing to be structural.
  18. The Burley small stove works well IME. Not sure if they have a closed combustion option though
  19. Are the stairs new and have the treads been glued into the stringer? First thought is if they have and the tread then shrinks with this dry weather some cracks will occur
  20. Thanks John. They were opposed to Velux at the time due to the thicker visible frames but I see them being used on other builds locally now so will now take a closer look at them and the sizes. Hoping to avoid too much roof restructuring work
  21. We did our barn conversion nearly 20 years ago. The planners (Dartmoor National Park) were strict about types of conservation roof-lights so we went with the ones they liked (The Rooflight Company). They are steel and get terrible condensation and are now rusting quite badly. Do all rooflights suffer in this way or can I get conservation rooflights that last longer? Alternatively I can do my best to remove all the rust and give them a good dose of Hammerite paint to buy us a few more years. Thanks
  22. We had an anhydrite liquid screed and tiled straight on to it. I did have to grind the top and prime it but no decoupling membrane which sounds weird as surly you need the tiles bonded to the floor anyway
  23. This is how I've narrowed down the disposable masks to use. I make charcoal as well and charcoal dust creeping inside a mask is very easy to spot
  24. I either use the 3M Aura with valve or the Mouldex ones which are more pricey but hold their shape better. What matters most is that whatever you buy fits you. We all have different shaped faces so no point having the best filter system only to have all the air get in around the side. Been taking down lath and plaster ceilings recently and both these masks were up to job for me
  25. Thanks. I will try and dig out the details
