Beau
Everything posted by Beau
Is Multi Pane still the preferred option on here? The shower enclosure will be 900x1400 so I would need one edge to edge joint on show if using panels. Other option I've glanced at is micro cement which I had never heard of until recently. Having just dismantled an old shower room I was taken aback by the quantity of none recyclable waste when tiles are used hence looking at other options Thanks
German kitchen brands - Nobilia, Bauformat or Leicht?
Beau replied to Indy's topic in Kitchen Units & Worktops
As a cabinet maker of 30+ years I can safely say their patter is tosh. Yes solid wood expands and shrinks across its width but thats why solid doors are usually frame and panel construction to avoid the problems associated with movement. Also doors and draw fronts expanding and shrinking a little bit wont matter as there are shadow gaps between them so they wont fowl. I'm not against the look of some of the German Kitchens. Quite like some of the Nolte ones myself. Also I agree with John as when you get under the skin most of them are made in very much the same way with similar materials. What matters most in my experience is a quality fit. A cheap well fitted kitchen will look better than an expensive poorly fitted one -
Thanks Onoff I like you taper the boards idea. Do you make a guide or just freehand cut your angle? I was intending to fully tape the joints I've done and if I get a 100mm wide roll I can bridge over the 50mm rafters completely eliminating any air leakage on the joints. No idea how well the foil tape holds up over time though if the boards shrink but it will be sandwiched between the next layer of PIR boards below the rafters. I always spray some water over surfaces before foaming Yes I was working on a 50mm air gap. No problems with ventilation as the roofing felt joints are pretty sloppy and we are in an exposed windy spot.
Thanks I did see that tape at a homebuilding show. Nice idea but as you say a tad expensive 🫣 "get it as tight as you can and inject some flexible expanding foam" is what I've been doing but I wasn't aware of this flexible foam so will track some down before doing the next part. Mind you if you only have a hairline crack its very difficult to get any in and looking at the foam it talks about flexing 25%. 25% of a nabby grabby bit is diddly squat! Might try Onoffs suggestion of a deliberate taper to leave room to properly get foam in if I can work out a neat way to cut a taper and hit my width marks With any luck problems there may have been with shrinking boards should have been ironed out but better safe than sorry.
4K ouch! We recently found an asbestos partition in our house. Did the removal ourselves but the specialist skip wasn't cheap. Think it was around £800 for the first tonne and £400 per tonne over that and we thought that was painful. All taken to Bridgewater to be buried.
Hi all. I just read something on here about PIR boards shrinking. This has got me a little concerned as I'm in the process of insulating between the rafters in a low bedroom. I dont have the hight to use lots of mineral wool on the sloping parts of the ceiling so how can I best mitigate any potential shrinkage? Thanks
Go for a battery machine if you afford too. Hedge trimmers sit about for ages between use and then often have fuel issues. Also petrol machines blow the fumes straight into your face when hedge trimming. I've gone for the pro Stihl as I already had that battery system and I'm sure lower spec machines would be fine. Run time is way longer than I can keep going
Recommend a shower tray please
Beau replied to Post and beam's topic in Bathrooms, Ensuites & Wetrooms
We fitted a Mira flight safe a few months back and really like. Just about to do an en suit and going to use the same again -
Kitchen appliances..... decision options
Beau replied to dan_cup's topic in Kitchen & Household Appliances
Just a warning about Liebherr. We got one of their fridges as it was supposed to be the most efficient. It's not very old and the door seal is cracking. Spoke with a repair guy and he said it was a common problem with Liebherr and they can be very expensive to change. Neff induction hob and oven which are 15+ years old and been faultless -
As mentioned above get a plug cutter. Dowels leave the end grain exposed so suck water in very easily so leads to premature rot unless using the most resilient species. I use a set similar to this which have no end of use over the years but OTT for just a one off job. Need a drill press for a perfect hole and plug https://www.axminstertools.com/8-piece-matching-plug-and-bit-set-8-15mm-700330?glCountry=GB&gad_source=1&gclid=CjwKCAiA5Ka9BhB5EiwA1ZVtvD1e1nguThTD55cQEHEB_9XKrL3An9IxG935-l_0ikggaKn0mWLd1hoC8GYQAvD_BwE
Correct way to install XPS insulation boards on top of plywood?
Beau replied to _Alex_'s topic in Wood & Laminate Flooring
Could you use a tile backer board XBS insulation like Jackoboard and just bond the herringbone straight to it? Ive only tiled onto it but would have thought with the right adhesive you could bond it to wood. Might be worth having a read of theirs and similar products specs -
As you are clued up on these can you see any obvious problem with this bundle? Only nervous as its cheaper than I expected 🙂 https://www.ebay.co.uk/itm/296685682787?_skw=geberit+wall+hung+toilet+frame&itmmeta=01JK8EKMECXEBCV8CR5HH046S8&hash=item4513d84063:g:N1UAAOSwqJpm4W9v&itmprp=enc%3AAQAJAAABAHoV3kP08IDx%2BKZ9MfhVJKlwJnobVTHF%2BBBT4d%2FM1P8G7jyhKvE0SA4rM9FOEMA5dN4UIJqKj6qtKLKvS3AJljm2t9S%2Bh8119dn1%2BZ0q7yOh9XYvYHngi1Jjn78Ai0ac6SQfPeVxWLl0HDCKsw%2F73Ph81WBqHTrpt9oXZRQRt5uFohHC0TLfKY1fBApl76TB9mvx9thsz4gM2ceeoDChH5u9FmVSUanbAiF1azlI7iF50wZjjoNvbpNgZqqYRIXI1S3zGcheav7b2AJK05u7vK4F8EnX0fAqy%2BvbLzzi6AgBlo5En7%2FYjAbeYZEIu%2BUvj2GLHmqq98gAFNmecv0K46E%3D|tkp%3ABk9SR6zHzo6aZQ
Fab Many thanks
Old thread but can you have a horizontal waste exit on these? Every diagram I can see shows a 90degree bend behind the pan going down or at right angles to the pan. Thanks
I see so do it on the wall. I had it in my head of making it up first but doing doing in 2 stages makes sense. To be fair I have just had a more reasonable quote than initial pricing so we will see. Thanks
Been a bit taken aback by the cost of insulated plasterboard in comparison with buying the materials separately. Would some low expansion foam work OK at bonding the PIR to the plasterboard? Thanks
Yes I was intending to use PIR between and below the rafters. Mineral wool above and between the ceiling joist as no presure on space there Thanks
Thanks Susie I've hunted around the internet for info and found others suggesting 50mm so I will go with that.
I will ask another way. How big a gap is advisable between the roofing felt and a PIR board on the underside of the rafters to allow ventilation?
One side of the room is vented to a lower loft and the other side has no vents at the eaves but zero evidence of damp issues. The rafters are 4x2 and I'm wondering if I can part insulate the gap between the rafters as well as under the rafters. The roof has a non breathable felt but plenty of air comes through the laps of the felt. I'm planning to just use mineral wool between and above the ceiling joist. Whats peoples thoughts?
Crack in a Rafter, do I need to worry about it?
Beau replied to LLL's topic in Roofing, Tiling & Slating
As said it's just a 'shake' or most probably heart shake. Very common when the board is cut near or includes what was the centre of the tree https://en.wikipedia.org/wiki/Shakes_(timber) -
Been trying to work out the difference between them. Looks like the CV 3 is much the same as the CV 2.1 but with an app or have I missed something?
Thanks John. Some great info there. How long have you been using these units?
