That's why we're here .
So, where were we?
FYI. I shall remove the edit tags tomorrow so the thread is clear of any such history.
A polite notice from @BuildHub It was decided that this thread would be locked for a cooling off period as things got a little personal. I have, as a site moderator, edited the content according to site etiquette and forum rules. Anyone who has commented in this very helpful and informative debate can now please check their OWN posts for my editing. You will each find I have marked and identified the edited posts so if there is no marker, it has not been touched. UNDER NO CIRCUMSTANCES IS ANY MEMBER TO DISPUTE THESE EDITS ON THE OPEN FORUM. Any genuine discrepancies can be corrected immediately. Please contact me directly PRIOR to making any amendments and I will accommodate / facilitate the requests accordingly. This is to ensure any edit / amendment doesn't make the thread non-sensical. Let's keep a good forum great ? "Have a nice day y'all"? @BuildHub
Single and Double Pole RCBOs
Nickfromwales replied to Ferdinand's topic in Consumer Units, RCDs, MCBOs
You've got minutes to live- 56 replies
- rcbo
- single pole
(and 3 more)
@Gorlando Best to start a new topic in 'house design' so this exchange doesn't get lost . Cheers.
Hi and welcome to the forum .
Curious neighbours
Nickfromwales replied to curlewhouse's topic in General Self Build & DIY Discussion
Seeing if the £2.6k down draught extractor actually works !? -
Geberit to MVHR extraction
Nickfromwales replied to Auchlossen's topic in Bathrooms, Ensuites & Wetrooms
Not suction . Sufficient airflow through the duct under flush 'flowing' condition. E.g. The equivalent air in to match the volume of water dropping. Can that happily be pulled through the duct IF that's the path it chooses to use to relieve the deficit.? -
At the stated 25a breaker rating there may well be shunt resistance allowed in that. 1.5mm2 is good for 18a nominal so 2.5mm2 would be the minimum. C curve breaker is prob best too. The cable needs to exceed the current rating of the breaker so, if 25a, then 2.5mm2 is very close. That's shows an estimated 5750w peak threshold, but they've obviously allowed some headroom. Is the 3700w stated as running or peak ( shunt ) ? Remember that you should allow for over current as well as a short circuit. That's why I'd use 4mm. ?
That isn't cheating that's a good way out. FYI if your ever half inch short , a straight coupler and an M&F 90 into that will gain you the missing length. -
I was going to brew some fresh coffee and keep at you, but just remembered I'm up at 6 to load the kids brekky into the catapult ? Nos Da!
What about with any mcb loaded board? Same thing Multi-RCD units still wipe out numerous circuits in one go. Can't really agree with that PoV TBH as I think they're a vast improvement. True circuit isolation can easily be achieved by knocking the isolator off imo, plus anyone messing around with this should examine the rcbo type before undertaking any work anyhoo. This could go on a bit
4mm if it were me. SY all the way for ease and uniformity.
Simple Pressure Tester, any recommendations?
Nickfromwales replied to TerryE's topic in General Plumbing
I did. She didn't give two hoots -
Spill the beans Harold. ? I don't see the advantage of DP TBH.
Thanks. My mate says hi.
Ah! Ok, Same room = oky-doky. Seems good to go. ? U/S sockets on a ring is plenty good enough TBH. Just going radial in mine so I can knock rooms off individually. Cable runs are a breeze too that way.
Yup. Doing my bedrooms all on radials. Work in progress . @Onoff will know what I mean. ?
A, er, friend of mine wanted to know what a Tony Tray is? Thought id ask, being a good mate and that
Internorm 'night vent' what is it?
Nickfromwales replied to readiescards's topic in Windows & Glazing
Often referred to as "night-latch" where it's partially open but the locks are still fully operational / secure. -
Anyone actually know what brownie points are? -
That should get you some brownie points . -
This with a non-return valve so it stays dry. .
