Nickfromwales
    345
  1. A bit of self leveller in the gap and jobs a good un.
  2. Son of a bitch edit : these are warm white Couldnt find a cool white one. That was the problem as all the other LEDs in the room were cool. But, Seek and and ye shall find....
  3. Even the little push in pea sized 10 & 20w ones ?
  4. Tonight's responses are sponsored by 'Gower Gold', brewed right here in Swansea no less. Tres bien.
  5. Oh, and why have a lot of manufacturers still not realised that LED lighting is commonplace now? Can they please ditch the chuffing 20w streetlight yellow halogen lamps? . Stripped and re jigged the last one as the customer was fuming. Swapped the driver out and replaced the halogen lamp holders with 3w led modules from Maplin. 3 days of self levelling and not even a smile, 3 soldered joints and she was doing cartwheels . Ah well, can't win 'em all
  6. Having a remote panel with a link cable would be a very good idea. Plinth heaters do the same, so you don't have to bend over to switch them on, thus showing where one would park ones bike
  7. Where the 50mm ( deffo upsize for utility ) comes up,out of the void, simply fit a tee with a cleaning eye. Then you can get one of those flexible drain rod things down there if the wee beastie ever blocks. If it does, I'll come up and do it for free. . 50mm will guarantee you a good air break, allow almost anything to get down the pipe to the soil run, and have a much better 'accumulative crud redundancy' factor. With both the soil and the utility connections rising from under the void, you'll have no need to box in. "Winner, winner, chicken dinner".
  8. Just not the nicest looking job IMO that's all. Using an all solvent boss fitting, and all solvent joints in the 40mm is what I always do, and haven't lost a patient in 20 years. Bite the bullet and sling it all under the floor Fwiw, I always run 50mm under floors for showers, not 40mm. Am I reading right that it'll never be used?
  9. Oh, and I'd 100% be getting those feet down onto the slab for sure. . Edited to add : don't chew the 500mm out, just multi-tool out where each foot is . Bingo.
  10. The missing part you liked IS the one your missing The last one I did was offset with iirc a pair of single socket 45's, but 15's or 30's would do the same thing as its down to how much offset you require. You should be able to get the offset with one double socket fitting and one single socket fitting inserted into each other ( M&F ), or a pair of singles. Bit hard to say without being there holding a cold beer and pointing at it repeatedly.
  11. The latter, unless you can get a bossed socket in between the pan connector and the invert ?
  12. If that's 13 on the display, then it's likely not temperature. Got me stumped, but so have shoelaces.
  13. @ProDave Why the gripe about having joints under the floor? Your entire run will be part hidden / boxed / buried outside so why not have that branch under the floor and then rise behind the pan? You'd be able to boss into that with next to no boxing-in in the bathroom other than the rising vent stack. 110mm push fit / solvent soil fittings are extremely reliable and robust. I'd reconsider tbh, as it'll save you a lot of extra work to go in the empty void underneath.
  14. Shall I start a new thread about fitting lightning rods? ( only joking ?).
  15. @Bitpipe. Hugh, didn't you and herb share a similar design schematic? Could you pop it on if possible please? ??
  16. I'll have to drop the H then as I always thought it meant "Honest" Dave, we all know that's a great way of warming the water back up I guess that this statement is now the most important one so far then?
  17. Imho the risk of that back contamination is near zero. The scenario as Ive given above, which basically describes how this back flow contamination risk is born, incorporates a consideration to the volume of water needed to actually form such vacuum / siphoning and displays how hard it actually would be to put anyone OTHER than the householder at risk. If the shower handset went into the loo it would siphon about half a litre or a litre at the absolute most before the siphon ended and the backflow ceased. If, and I mean IF, the contaminated water got through the household pipework and into the network mains, and then got to the branch where the house was fed from then I'd go and buy a lottery ticket. With the NRV at the stopcock ( or in Dave's case multiples of NRV's ) stipulating that the shower handset shouldn't get into the loo because it could contaminate the network water is quite questionable. If the loo was constantly flushing and could maintain a siphon then MAYBE, but the odds of that 'perfect storm' scenario just don't seem to make this as big a risk as it's considered to be. Id rather consider the risk to the householder, which is imo the real one. .
  18. Ok, let's clear this up. Situation could be.... Little Timmy decides for whatever reason to put the shower head in the ensuite in the loo. He walks off and plays Minecraft, blissfully unaware that the shower wasn't fully turned off after its last use. Meanwhile.....a plumber turns up and greets mum downstairs. "I'm here to fit your new kitchen sink tap luv". He turns off the stopcock ( which has the non return valve above it ) and opens the kitchen sink taps to let the hot and cold drain down. He goes upstairs to open the taps in the master bathroom and heads back downstairs to fit the new tap ( unaware that there is an ensuite ). After fitting the new tap, the plumber ( good looking welsh guy most probably ) turns all the taps back off and turns the mains on. He tests for leaks ( Da iawn, wrth gwrs ? ) and collects his payment and leaves. Sounds ok .........? No. With the water turned off and the kitchen taps open a vacuum was created. That allowed water to be sucked ( syphoned ) through the partially open shower valve, into the shower hose, out of the toilet, and then into the entire cold water system. It then has time to contaminate the pipework for the time the plumber took to fit the new valve. Timmy then has to brush his teeth upstairs before bed and the water that first comes out of the tap may have been part of yesterday's evening meal. Mum then fills the kettle and that's not great either. Even worse she fills the ice cube tray at the same time and the American fridge pulls it all in too, to be dispensed for the rest of the evening. @ProDave, that tells you how much protection your 3-4 NRV's would provide in this situation. ZERO ! ? Admittedly, the above is absolute worst case scenario, but hopefully allows you all a slightly rough as toast scenario / example to help understand why that type of reg is in place .
  19. NOTE : The chat about electrical bonding and plastic pipe work is continued here :- ( Topic moved to allow this thread to stay on track ? )
  20. A very good point @Barney12 Might I ask that you start a new thread please? . Better than losing that in this thread and going too far off topic ?
  21. Just the wording "if the ashp cannot x y z" that was a bit misleading We'll get there I'm sure
  22. Get it changed immediately before your rights expire. . When they deliver the new one examine if closely for similar defects etc. If found, at least you'll have a BNIB unit which you could sell / return for refund ( if possible ). Dont fit it until your 100% happy with it. Deal with Stanley direct and explain your concerns, but only after you have the new unit in your possession. My mates hot tub had multiple failures so he fought for a replacement. It had to be craned over the house at his cost. After a load of grief off them he agreed to pay the new crane fees, begrudgingly. When they arrived with the hot tub the crane was set up in the street ready to go. He told the spa Co that he only had 15mns of crane hire left and the original tub was still being disconnected, so they agreed to crane the new one in immediately. As soon as it hit the ground and the crane was detached from the strapping he escorted the spa Co staff out of his home and told them any attempt to reenter would constitute trespass. He retained the original spa and told the company if they wanted it they would have to rearrange the crane at his convenience and that would only be when the new one was proven to be working properly. They never came back and never contacted him again. He sold the u/s one for spares to recover his time and losses. Took 7 of us to 'hedge hop' it over the neighbours gardens. Moral of the story, if they can get off the hook they usually will, so act sooner than later. .
  23. I think you mean that you will set the ashp to NOT go into DHW mode purposely? The cylinder will reheat via the cyl stat, regardless of what the instant is / isn't doing. I think that logic needs a revisit unless I've mis-understood you?
