Nickfromwales
    346
  1. All I hear of is neighbours being assholes, happens lots of times, sadly. Green-eyed monsters or just utterly miserable bastards each one of them. For some, death is a convenient end, but, ultimately, the only end that would ever be arrived at for peace to be restored. These think that perpetuating misery as a pastime is acceptable. What’s wrong with just getting along?
  2. Correct. In the summer your heating will all be in the summer / off position, so I don’t get why your system would come on, to heat anything? Summer sees the ASHP > UVC directly, and the buffer remains isolated and dedicated to the heating primary circuit only.
  3. You wouldn’t have the ASHP firing without demand downstream of the buffer?! Call for heat would fire both the primary ( ASHP ) and secondary ( pump at buffer > manifold if required ) simultaneously, and when the buffer gets heated to the set point of its stat the ASHP will rest, but the UFH will still continue to pull heat from that body of water ( buffer volume ) until the buffer stat kicks in again, and repeat. Call for heat goes away, everything goes to sleep. Simples.
  4. If it wasn’t, the boiler wouldn’t fire. There’s no “exploring” a buffer, just a buying one, and-a fitting one. The UFH won’t ever work correctly if you want it to run independently, and it’s completely reliant on buffering via the rads atm.
  5. It only needs to be teed in immediately before the stack goes from horizontal to vertical ( drop ). This doesn’t need to be upstream, as any length of horizontal pipework will introduce a natural air break ( where the air flows up and over the body of water ) and the issue only becomes an issue after the pellet of water has started to fall rapidly south, creating behind it a vacuum. It is that vacuum which causes the air / water to be sucked out of anything with less resistance ( so a basin or shallow shower trap vs the toilet bowl ) in the absence of an AAV. If it was sufficient, nobody would be paying twice the price for twice the AAV I come up with plenty of good ideas / cheats / hacks ( as the kids call them nowadays ) and none of the get off the ground unless the BCO is happy. Ultimately, fit what you wish, and demonstrate it functioning to your BCO. If they’re happy it matters not a jot what I say, or anyone else on da ’net. 👊. Most BCO’s say to me “if the internal stuff ain’t right, they’ll be calling you back, not me” then they shrug their shoulders and walk off to look at drains.
  6. Literally, the lowest denominator.
  7. Did they have true geothermal or the geothermal intake for ventilation? https://www.gogeothermal.co.uk/products/mvhr-awadukt/awadukt
  8. Water dripping / leaking, or evidence of it doing so but evaporating before it gets to form a drip. Well aware of this, and agree it's a last resort. But if it's a joint under a floorboard etc then this is the way to cure it without pulling the house apart. No apparent or obvious leaks / drips yet reported by the OP so I rules out the obvious.
  9. My advice would be..... "stop staring at your hot water cylinder you saddo!" There. Problem solved.
  10. That's because even Bernard Manning covers his ears when you get going
  11. Yup. Those are the weapons of ( my ) choice. Best to remember that if you’re looking for good results, you should really be looking at kit which is PH approved / compliant.
  12. Shows are every other night, and twice on the weekend.
  13. Velfac prob next rung up the ladder tbh. Give Simon Chadwick of SMC a ring on 07862 737026 and ask him for prices / recommendations if you like. Mention my username and he will look after you. Great guy, and currently supporting my company with a PH project. Came highly recommended from Velfac / Rational head office, but installs, or will supply/install, most makes of doors and windows at your request.
  14. bends formed in the duct, or mechanical bends?
  15. I think, ( judging by the house we're currently re-installing the badly fitted PH windows and doors back into ), they are Rational. GBS also use Ideal Combi a lot too.
  16. Choose where you'd want absolute silence ( yes, ideally everywhere ) and run 2x 92mm ducts. Consider which rooms would be adversely impacted by the increased airflow & audibility, when the system is boosting, and plan around that.
  17. In lesser quantities then in-house 'pardons', apparently.
  18. PMSL. That typo is staying for all eternity. ffs 🤣 I shall call on an expert.......AH!, here's one. Yup. And then help yourself to as much cheese as you like whilst waiting for the system to warm up again.
  19. Might be a good idea to turn the 2 isolation taps off first....LOL. Turn the 2 isolation taps 1/4 turn to the off position, firmly shut, and get an old towel at the ready. Under the mag filter should be a drain off ( maybe not but have a look ). After turning off, and hopefully draining vis the sump, unscrew the lid and remove. Withdraw the magnet from the assembly and clean the plastic shaft of debris. Keep the magnet away from anything you like / is sensitive to magnetic fields ( like your wallet / cards etc ). Reinsert the magnet into the lid / pot aperture and put it safely to one side. With the filter now empty, reinstall the mag / internals as you found them, and fill up the vessel with the leak sealer chemical, until full to the brim. Screw the lid on until as hand tight as you can, and then give it a final 1/4 turn or less with the filter spanner. Reopen the Stilton vales and run the heating. DO NOT vent the filter as you'll just let the chemical out. Run the heating for 4 hours and then repeat so you can get the rest of the chemical in ( as you can't get a full 1L in in one go ). Happy days.
  20. I’ll get my coat. 😭
  21. To add: With your floors, you will of course not be able to fully fill the spaces. but you’ll be able to install 50-60mm of fixed rigid PIR without issue. Use the highest performing product you can. If you wish to go further, then you can remove the floorboards and put strips of 20mm Compacfoam on top of each joist, to arrest the repeat cold bridging. Then use 75mm rigid insulation, with the top of that being left flush with the too of the Compacfoam. That will leave you a 45mm void underneath, where each supporting pier is, for through ventilation.
  22. I can’t show you mine, I took one look, swore several times, and put the boards back down. Mine will get completely dug out, insulated, concreted with mesh and UFH pipes, and the internal walls rebuilt. I’ve worked in the construction industry for 3 decades so am speaking about your job from experience. If each of your gaps between joists were the ventilated spaces, you’d need an air brick for each void, so the house would collapse. Your air bricks will feed down into the void / underbelly and in-filling between the joists will be perfectly fine, as long as the insulation doesn’t completely foul the air bricks and their path to the remainder of the ventilated void.
  23. Any MCS job will immediately go onto permanent record with the MCS. They’ll just type in your address and say yup or nope. End of. If you can prove your AC coupled equipment is on the approved list ( so could be MCS approved ) then they should just let you get paid for export, afaic.
  24. The gaps UNDER the joists forms your ventilated space, and not the gaps in between them
