The extra length on the ASHP pipe 'could' be offset by bringing them indoors earlier, I guess, so they're in the heated envelope, but we're really down to a few brass tacks then and I'd rather not have the inconvenience of these pipes traversing the house interior tbh. Somethings gotta give! I have, for a project in Graven Hill, run the ashp pipes through the slab insulation (atop the lower 100mm PIR slab, then capped by another 100mm layer, then 100mm polished concrete (with UFH & mesh)) so that the losses are minimised, as the delta between the pipes and their immediate surroundings are no longer so adverse. That could be possible for you without too much effort methinks; just use 2x28mm Hep2o runs and ditch the underground duo pipe then.
Running hep2O in insulation below screed?
Nickfromwales replied to daunker's topic in General Plumbing
I was sure you just couldn't have joints buried? You'd not be pulling copper out and pulling new in? -
Crane option should result in less damage / death. Really poor place to take a risk on items from chuffing Aliexpress ?! đ¤Śââď¸đ Doubt they have been through much quality control or rigorous testingâŚ..đ If one of those drops on to someone theyâre Donald Ducked.
Either option but if the coupler is on then another damage mitigation policy imo. The sand shutter option is ridiculously cheap, quick, effective and simple. Couple of pays with the back of the shovel to compact as you go, and the concrete just bounces back away from it. Henry has been a soldier over the years, no task has beaten him yet. Same one for 20 years, just has had 40 new hoses and 6 new main units lol.
Another âhigh tempâ split methinks. 70°C is beyond most monoblocks.
The fully compact / modular boxes are all âgasâ powered I suspect, thatâs how they can make it physically smaller. The conversion happens once not twice then as energy is released direct to the heat exchanger in the cylinder vs 2x conversions gas > wet then wet > wet.
Thatâs a split unit, with gas lines between the internal and external units. Needs an F-gas installer. Not a horrible option but looks to then become an expensive install! Prob just doubled your installed cost there vs buying boxes and connecting via a local âbut competentâ plumber. Canât see much info about DHW (recovery times etc) other than itâs a 200L tank, but Iâm not trying too hard today lol. Iâd also want to know how noisy the outdoor unit gets when doing DHW. The monoblock Aquerea Iâve just fired up is crazy quiet when going full chat to heat 400L of DHW from standstill for the 1st time. âPanasonic All in One air to water heat pumps should be installed by a qualified installer and preferably an approved Panasonic heat pumps engineer To purchase this heat pump, we will require the installers details and currant F-Gas number before it is dispatchedâ
Iâve just done a Panasonic monoblock with its own integral pump, so no need for another pump other than the one on the manifold. Some will say to have a pumpless and blending-valveless manifold and fire that off the ASHP pump, with ASHP flow temp as your UFH flow temp which is a little less user friendly an option, imho, but doable. Pre plumbed cylinders will have all the generic stuff on there for a standard S or Y plan arrangement. Plug and play, but a more cumbersome lump in one place; has a much bigger diameter for both physical size and also access / service / maintenance etc so not sympathetic with it hiding in a utility cupboard. . Cost goes up too, and not sure about slimline options there either(?). Donât have the ASHP pipe rise out of the slab until they are in the plant space!!!! Terrible idea to bring them out early, so go kneel on some pencils until youâve removed that silly thought from your mind đ I use 2 port valves as theyâre easier to swap out and you lose one service not both if it snuffs it. 3-ports (diverter valve not mid-position) I only now use if itâs a thermal store with DHW priority as the wiring is standardised and I like these to be generic. Most heat pumps service a 2x 2-port setup out of the box.
Bathroom Layout - Too Narrow?
Nickfromwales replied to richo106's topic in Bathrooms, Ensuites & Wetrooms
If the adjoining room is habitable (bedroom) then your BCO may or may not spot the breach of acoustic control. These habitable spaces should be separated by a full, insulation laden, stud wall of 100mm to comply; subject to the BCO giving a toss or not basically so youâll need to flip a coin and see who you get. On the last one like this I stuffed the WC frame and associated annoying voids with acoustic batts manually, and then built a 3â stud wall behind the 4â one that the WC frame and cistern went into, to bring it back to compliance (at the request of the client, after I made him aware of the consequences of breaching that acoustic divider). 645 is plenty, agreed. Youâll be surprised to know that the average UK bathroom was the size of a double bed. Iâd keep the shower head and riser rail on the end though, with the control valve on the side at the 2/3 marker; easy to reach when showering and before getting in. The real estate between the end and the last 1/3 should be preserved for lathering up out of the spray but just away from the opening. For anything shorter than 1400 you should have a slider really vs an opening afaic. Defo a great choice vs a modular shower tray imho. Flush tiled floors in the shower area just look soooo much better / more âexpensiveâ tbf. Youâll be into tanking then so would need to plan accordingly. @richo106, the only issue youâll have is foot space to dry off in after a bath, so I would take the basin down to within 100mm of the bath, move WC to suit, and create some towelling off area which I think will be of much more long term benefit than having nice big gaps that choke to circulation space up. Consider niches for the shower area, somewhere for goops & goos, and maybe bring the bath 50mm away from the wall to create a ledge and exaggerated window âshelfâ for same goops there. Just imagine how you will manage without those bits of storage for everything you currently have to hand and then realise the importance of not forgetting to allow for it. -
Just cut a dozen or more (x) depth PIR chairs to sit on the DPM or rebar and then place a piece of 100mm PIR or EPS on top of them the size of the area plus maybe 50mm extra in each direction. If over rebar, fit concrete mars bars directly under where your PIR chairs will go to stop the deflection when you add ballast. Wrap a bin liner around the soil pipe, then foam around that as much as you need to. That needs to be done so as to prevent concrete getting to or into the pipe, so do that well! A coupler and blanking plug is the best option, but youâll need to get the pipe cut quite low for that. Easily doable with a multi-tool and some patience. Place a load of concrete blocks or sand bags / other ballast on top of the 100mm sheet and get on with the pour; this will give a âperfectâ result. Hack it all out 24hrs after the pour when the concrete is still âgreenâ and thatâll allow you to easily undertake any further chasing out necessary to fit the tray / former / waste & pipework etc. There are loads of ways to over-engineer this btw, and the last load of these Iâve done have been ludicrously complex and time-consumingâŚ..(not). Just get a load of sharp sand and shovel it in to blind off the area and shovel / Henry hoover it all back out the next day or so. Takes appx 10 mins to shovel in, 20 mins to remove, perfect results every damn time. . Bench the sand like making a sandcastle and go 75mm bigger x&y, have it around 50mm higher than TOC, and tell the concrete guys to go easy there so as to not disturb it. I ask them to stop short as it doesnât matter, and later I back fill with cementitious leveller or a builders screed with fibres, depending on rebar or not. âKISSâ, folks. Works a charm. Tools required = 1x sand and 1x shovel. đ.
Great comments from the new neighbours, plus a happy 9 year old to boot âşď¸. Great work, and phase 1 complete. Keep your chin up, itâll be well worth it in the end. đŤĄđđ
Or just say my name three times @KJL, are you referring to the clip rails or the individual clips? If the latter, theyâre just 16mm ânail clipsâ from any decent merchant and come in bags or boxes of 100. https://amzn.eu/d/amdxnLI đ That job had posi joists at 400mm not 600mm, and were designed at the pre-construction phase for the weight of the screed. It was Cemfloor cementitious liquid screed. Itâs very solid underfoot now, but still not âconcrete solidâ.
Rebar suppliers that can do 90mm h10 links?
Nickfromwales replied to WannabeBob's topic in General Structural Issues
You'd both be lucky to have me....ffs -
ÂŁ20 is ÂŁ20 -
A lot of partial water changes will be necessary to keep this anywhere near healthy and stable tbh. If youâve a heat pump > UVC then just dumping that into the âpoolâ would be the easiest and reasonably efficient way of just knocking the chill off the water. Having this heated is going to be a big uplift in cost to maintain, so prob best to set your expectations accordingly. As đ but with the caveat that we see value in doing what puts a smile on our kids faces. If any of this is offset by off peak electricity or micro-generation then I could live with it tbh. If it was mine, Iâd have a blended valve with a timer and solenoid for filling, with a dedicated outside tap and a hose to the pool. Then Iâd partially empty it each evening when in use and then maybe overheat heat it from midnight - 05:00. That would be in conjunction with a good cover on and a good quality local pump and filter being on and regularly cleaned. Otherwise this will quickly become a vat of unhealthy (invisibly so) goop which my kids would be told to avoid. I fitted a 19â x 5â above ground heated pool for a client, tiered garden which we reduced at the end so the pool was 4â below ground and wrapped by a deck, was a nice thing to have if you could afford it. I put up a dedicated âshedâ for the boiler and pump house and sand / cartridge filter etc etc and the cost was thousands to get this all right. Unfortunately youâre either dedicating your life and time to this with a big investment in infrastructure, or just emptying and filling with potable (already mildly chlorinated) water prior to use, on demand, and sucking up the cost to provide the heat and the water. Any heated, maintained pool is a money pit and is hugely time / attention hungry. Hot tub owners are one of 2 people; lazy smelly buggers who donât care and keep adding more chemicals, or immaculate and particular folk who keep the unit spotless, clean, and healthy, and pay the price and have the time. Oh, and with kids, Iâd NEVER entertain putting an electric heater into the poolâŚ.. The only place for a certified inline electric heater is on the return of the pumped filtered loop, but then youâd just bite the bullet and use a cheap pool ASHP so the running costs were 1:3 / 1:4 which isnât too bad. Again, used pre 05:00 to do the bulk of the heavy lifting to further reduce costs. @SteamyTea how long would the temp need to be at 45°C (or more?) to do a legionella purge for the 3.5m x 1m pool volume?
How to not get ripped off and secure the best prices?
Nickfromwales replied to flanagaj's topic in Building Materials
If you leave the unwanted text and hit refresh on the browser youâll return to an empty text editor box. When you click on it to make the comment again youâll see the text reappear and an option to restore that text or âclear editorâ, so click on clear and the text will all disappear đ. -
Underground waste. What brands are people using?
Nickfromwales replied to flanagaj's topic in Waste & Sewerage
Yup. For stuff which you cannot go back to, it is sensible to only use quality, industry standard stuff every time. -
I think that would be a "yes", as there has. Just another BS government 'initiative', with MCS being equally as w4nk as the FIT, et-al. And we vote for these people......... (well, not me anyways).
Pan a sonic. #subliminalmessage Cylinders2go for UVC. Fired up another Panasonic today, still very happy with how quiet and cost-effective these are for a simple install. And cool capable straight out of the box.
Internal wall connection to ICF
Nickfromwales replied to metalgear2k2's topic in Insulated Concrete Formwork (ICF)
Time to discover timber methinks, all you masonry addicts! Even load-bearing walls can be done well in timberâŚ.. why make life any harder than it already is? đđ -
how long before tiling over new 75mm screed
Nickfromwales replied to Post and beam's topic in Floor Tiles & Tiling
Went to get his hair done and a manicure! đ obvs. đ -
Have thermal stores had their day?
Nickfromwales replied to Workerbee's topic in Boilers & Hot Water Tanks
Open vented? -
How to mount an external door when using an insulated slab?
Nickfromwales replied to zzPaulzz's topic in Timber Frame
Cut back the XPS and set Compacfoam in. I did this with a 4.9m slider, and set the Compacfoam in with flexible tile adhesive so I could tap it gently to level and set the required depth with great accuracy. This isnât about point loading, so doesnât need such drastic work-arounds tbh.- 11 replies
- foundation
- passivhaus
