+1, if planning allows. @LD84, do you know a rebuild will be zero rated for VAT? Plus you're not putting good money after bad putting lipstick on a pig......for want of another phrase....
Eggshell as the base as it covers well in a single coat, so I should have clarified that was not the finish... oops! My point is about the amount of cutting-in that process saves you, down at the junction between the skirting and the flooring, which is a PITA if you've got nerves like mine lol.
Intumescent / acoustic yes?
I doubt it will be constructional at 20mm.
Yup. Have dealt with many like this over the years, and there's only a few who actually understand this. Clients often find OK architects vs great ones, but it's very refreshing when one of these unicorns is discovered.
- 17 replies
- ufh
- raft foundation
(and 3 more)
Any help? https://lewismetaldeck.com/our-solutions/flooring/
Flat Roof with Parapet detail - correct fall
Nickfromwales replied to Ay8452's topic in Roofing, Tiling & Slating
My alter ego lol. -
I'm not sure I'd want those under my membrane when they can't reliably take point pressure? Good if it's an inaccessible roof which you don't want to go up and carry out maintenance on frequently though. -
What are crickets on a flat roof? Crickets are triangular structures designed to divert water away from areas of a roof that may collect water. In residential roofing, we tend to think of chimneys as the prime example – chimney cricket. Here you would place a cricket behind the chimney in a triangular pattern so water doesn't collect behind it.1 Jul 2021 -
I do them so your perspective view as you enter the room doesn't 'see' any (or as few as is possible) of the filled joint. You should be looking at the running skirting and not the cut & scribed one, if that makes sense? If filled and painted, and caulked etc, then prob not a worry, but we've just done a bucket load of oak and I was quite adamant about that detail for that particular job. Paint the underside and face of each length of pine, with water based eggshell, with a 4" roller, before cutting and fitting. Makes paintwork and cutting in a doddle. Stay away from oil based "gloss" etc, as that's a load of repeat maintenance you can extend the frequency of if the paint doesn't yellow. Water based stuff dries really fast if it's not a cold space, so just have a painting day before the fitting day, and thank me later
Building walkway from 1st floor into garden
Nickfromwales replied to Leedschap's topic in Landscaping, Decking & Patios
Use galv box-section for the walkway and composite decking boards? You can have goalposts either side of the downstairs openings, just use round tube painted white to mimic downpipes and have the goal bar offset. A quirky design feature could be a P-shaped platform to absorb the wider end with a planter or something sat there, if you wanted to. -
Cold Flat Roof - walls on 4 sides
Nickfromwales replied to Chris Miles's topic in Building Regulations
My point was more about recourse as well as 'opinions' born of these various 'professionals'. Ultimately, who governs the governors.....? And how does Joe Public know who to ask / trust / rely upon.....? MI's and SE trump BCO. If the architect is tasked with designing to current b regs or above, then they are responsible for defects in their works via the PI insurance. -
You could have a 40mm 'tang' at the top of the plate, so it is a Z, and grind the top of the plate into the wall so it hangs, and then the mechanical fixings are more of a shore than a sheer connection, splitting the load between the two. I'd get that made in stainless vs galv, as I simply wouldn't want an ounce of corrosion to upset the longevity. Not a huge uplift in cost, as a steel plate would need to be fabricated and then sent away to be galvanised anyways. I'd use resin anchors rather than percussion or expansion fixings, with those left to fully cure before cranking down the nuts to send it home. Beware dissimilar metals making contact, and get the holes in the plate oversized to allow nylon sleeves to be used as inserts to keep the mild threaded bar away from the mild stainless steel; these two are not friends at all! Possibly look at using stainless threaded bar and nuts / washers, but check sheer strength and suitability. You could remove the render where the plate is affixed to further increase the purchase, and use a bond such as Sikaflex EBT behind the entirety of the plate to weather seal it and for further mechanical / bonded fixing. It's not a huge ask here tbh, but better safe than sorry, or better still to avoid doing it twice. -
The rain chain is cool. 👌. -
You can discharge the down pipe into a grated back gulley, to trap at least some of it, but most soakaways can cope with leaf litter as it does break down over time. -
Hi. If the neighbours don’t kick off to planning dept etc about it, then see the following. (If there’s any chance of annoying the neighbours with it then consider a glass balustrade). I would avoid penetrating the external leaf of the house as that’ll need to be made weathertight, plus it would be a cold bridge in the wall which isn’t great. Instead, I’d get a steel wall plate made and fix that into the wall, with a profile that allows for a good amount of mechanical fixings to be installed. Have a tongue protruding at the bottom of it, an L section, so your timbers can fix to it, and then your foundation the other end needs to be ‘concrete solid’ to prevent any movement of the finished structure away from the house. Is the length 3m? As said above, looked more like 4-5m total, eg when tucked into the foundation into the bank? -
Yup. MDF skirting sucks. Ok for architraves but anything getting whacked by hoovers etc, particularly on external corners, needs to be able to take the abuse.
Yup. Tight as. Do you know the trick for cutting the scribe? Eg you cut it with a mitre saw and then run the coping saw along the line? I use the mitre saw to cut up the vertical line first and stop short of the detail, as that gets a nice clean edge, but this method also allows you to correct an angle if you’re meeting up with a previous piece they’d not perfectly plumb.
I ran cables to 10 ground floor window reveals for a previous client. The 1st blind company rep was a fecking wet-wipe, and said that depending on blind type and other nonsense it "could be" a D/C low voltage motor or an A/C 230v. Given this info I ran an independent 3-core 1.0mm2 cable from each opening to the plant room, so each blind could be fed by whatever source the final chosen blind needed to be fed by. I could think of nothing worse than charging all that lot up for the rest of my days tbf, and my Ring doorbell is on borrowed time as even charging that (takes bloody forever) get right on my tits.
Hi. These suffer massively if there is untreated hard water, due to the multiples of small bore pipes running through the heat exchanger. Which model is it, and how many pipe connections do you have, and size? Have you tried running water backwards through to clear out any other possible debris? Are you checking from the immediate outlet, or from the output of a blending valve? You may be out of warranty if you have belayed getting the water softener in from the point of installation, tbh.
Stuff of nightmares..... A friend of mine rendered the outside of a bungalow, with a friend of a friend mixing for him. Got to the end of a long day, scratch-coated the 4 sides and seemed a productive day. When cleaning up my mate noticed a load of cement bags and asked why there were so many left over (assuming builders merchant over-delivered) only to find out he'd been laying on a very, VERY weak mix all day. Next day he went back to remove it all with a 4" scraper, but said labourer refused to come back and help for free as he'd "done his bit"......
What if the roof had excellent falls towards the scuppers, and the scuppers offered zero resistance to the flow of water, and then the scuppers had a fall designed in which promoted 'stuff' leaving at a rate of knots in an orderly fashion? Copious rainfall should, in theory, then be your caretaker. -
But really annoying when a bit of GAF could have reduced the pooling to zero? .....gravity and resistance would be key to a successfully discharged deluge of rain, regardless of whichever direction it was delivered from. Different physics and dynamics methinks. A turd leaves the bowl with the provision of energy created from the flushed water, with those forces being concentrated within the confines of the bowl and downstream 4" pipework, further assisted by gravity of the requisite falls. Flat roofs have a lesser amount of energy per m2 to call upon in the pursuit of getting 'random shite / other debris' from A-B, so when a roof is designed to almost get rain to B, it's got feck all chance of conveying anything else; this is even more of a problem when the journey has some of it going up steps / hills. Would need to be a hurricane, as the parapet walls deflect a lot of the wind in actuality. Nevertheless, when the wind subsides, the water will follow the path of least resistance; down the slopes, and into the outlets and downpipes, like a good little boy. If the roofer wasn't also a turd...... -
Very little gunk goes down an utility trap / sink tbh, so the issue is largely from food waste from the kitchen sink. A decent bottle trap will allow regular maintenance, if so ever necessary, which means I would say "no" to the benefit/downside squire. I have lived here for 19 years and have cleaned my kitchen sink trap out prob less than 3 times, and that's probably because of lollipop sticks not gunk/stink related issues. "People. stand united in the fight against gurgling traps!!!".
