Principal Designer (BR & CDM) - should it be the architect?
Nickfromwales replied to Gibdog's topic in Self Build Insurance
Are you qualified to be the PD? And also for Bregs? I have a colleague who fills in these positions for me when we get a turnkey new build project come in, and he has to be book-worming all the time to ensure he’s up to date with changes in legislation / law. A lot of people pretend to fill this role and hope that nothing goes wrong, which I see a worrying amount of self builders doing. Eyes wide shut seems to be a poor choice, but hey-ho. -
Ah. Defo use acoustic PB on the interior of outside walls, as a lot of nuisance noise gets through these PIR boards. I’d go for 15mm if you’re in a built up area / on a main road.
They didn’t insist on it, it’s standard b regs! Acoustic control between habitable rooms is the standard on every job that has stud walls internally. No need for acoustic control on external walls unless it’s to your own advantage. You only need FR plasterboard if you’re less than 1m from the boundary. If you’ve any steels which are behind the cosmetic PB + skim layer they will give the requisite 30 mins FR for the steel. Acoustic plasterboard on the inside face of all external walls is a good idea if you’re SIPs (timber walls with PIR) as they’re quite acoustically transparent vs masonry / concrete or blown cellulose structures. Odd make up for the roof? Why the combination of insulations? Batten the interior to have 400mm oc’s and 12.5mm everywhere will be fine, but at 600mm oc the ceilings should really be 15mm. Bathrooms need 400mm for the weight per m2, all other rooms are fine at 600mm.
Use solvent weld and fit a couple of T’s and cleaning eyes for routine ‘cleaning out of gunk’. Push fit is shart, compression bulky and ugly as feck, sorry! As for AAV’s: You only need one if the discharging water can occupy suffice pipe area on its way down / out to create a vacuum in its wake. That’s the main culprit for slurping and *gurgling wastes. If this is a ground floor kitchen discharging into a drain outside, it’ll defo not need an AAV. *Gurgling wastes at the kitchen sink are caused by those horrid combination sink traps where the appliance connects via a stubby spur. This means that the water discharges between the sink plug hole and the trap, so you get to hear every last slurp…. PLEASE, T off the waste pipe and install a washing machine trap, and connect the appliance(s) via one of those: As your pipe exits horizontally to outdoors you have a T instead of a bend, with a cleaning eye: This allows you to ‘rod’ into the sink and down to the outdoor drain. ”Minted lamb, sir”. 👌
Then you have plenty of options to route MVHR ducts, but the 2 companies you mention typically favour series run systems with galv distribution ducting, whereas I always use a radial setup with 92 or 75mm ducts; the aforementioned companies often specify systems which also require cross-talk and acoustic inline attenuators, which are a complete PITA to integrate into the fabric of a build. Would not be my first choice tbh, sorry.
Have you seen this type of product? https://www.advancedwater.co.uk/product/20m-microflex-25-2-3mm-insulated-underground-pipe-pack-md12525cpack20
Glulam ridge beams, posi-joists, full-fill with blown warmcell, and put the MVHR ducts in the joist voids on the warm side (mechanically fixed to the inside of the lower chord), and jobs a good 'un. Service battens in front of your AT membrane, and then you cables can run through there. I was going to say your architect seems to have run out of steam, but kudos to her if you're the one who's worn her down. We're all only human at the end of the day. I asked about this roof in your MVHR thread, I have my answer now lol. Where i designed and installed all the M&E for a client with an MBC TF PH build, I worked with MBC and the client (and their architect) to provoke some structural changes; to keep the bedrooms and open spaces vaulted etc, and then created a small attic over the ensuite to house the MVHR in a warm section that we dedicated to that cause. Got the MVHR out of the 'living space' without any real impact to the overall 'look'. I've done this more than a few times now, where the architect (and often the client also) do not appreciate how much room M&E equipment needs, and how bulk items can be lost into the fabric of the build with a bit of ingenuity and GIF. My USP is solving problems that others see as "too much like hard work", it's not really that hard tbh.
Can you upload whatever plans / drawings you have, to assist anyone here who could give said ballpark?
Which pumped shower is it? Some can be converted.
https://www.ceilingtilesuk.co.uk/product/mf5-furring-channel-top-hat-3600mm-mf-ceilings/?1&ft=true&utm_campaign=PMAXW-Shopping&gad_source=1&gad_campaignid=21670932886&gbraid=0AAAAADxRNNWI9JmkQ-Qpl9DkshjATYJ-U&gclid=CjwKCAjwl_XBBhAUEiwAWK2hzqSPXOY1GzYYPCyOeSp9yPUlQdr59EVk7yMhPyOjZN4A5M94PsGpzBoCq78QAvD_BwE
Sizing radiators for rooms
Nickfromwales replied to Joshua Graham's topic in Central Heating (Radiators)
The vessel inside the internal unit may just be an expansion vessel (EV). A buffer tank is a stand alone cylinder which is in addition to your EV’s and hot water cylinder. Have a look at the manufacturer’s installation guidelines, it should tell you there what system volume the OEM (factory) EV can cope with, so only add more if the upsized rads increase the water volume in excess of its current capacity. -
We’ll get you a Blue Peter badge when it’s done 👌
Patio Drainage - Suggestions Please
Nickfromwales replied to AdamW85's topic in Landscaping, Decking & Patios
Why not have the upper deck sloping back to the outside walls and put the ACO drain there where it doesn't dominate the eye-line? -
Yup. That's what most do, and its quick and easy vs all that woodwork! That's a whopper of a footing for those brick walls?
If you don’t do a BOQ (fully populated) then how are you going to construct a contract and to what parameters will the builder be bound by in its absence? Im doing a full QS / BOQ for every new build client as it forms the backbone of our arrangement; without it you’re just time and materials unless the ‘builder’ has given you chapter & verse in a fully itemised quotation with a pragmatic variation order agreement for additions and alterations. A MC isn’t duty bound to share costs with you, or go out to tender, they’d just say “it’s £750k to make that house you’ve just asked for” and they’d get the cheapest materials installed as cost-effectively as possible to maximise profit vs budget. I do open book MC / PC so the client sees all costs from 3rd party BFSC’s, and the PM costs are shown in ‘preliminary’s’ in the BOQ. Stage payments have any ambiguity removed via a full (correct) process, as the deliverables are all measured and pre-agreed; if they’ve not done 100% of stage 1 works then they don’t get that sum of money, only the % done. What about a retainer? How do you know what your budget is? And to clarify, your budget is how much it will cost, in absolute total, to build the aforementioned dwelling to the required standard, not what you have in the bank at the time . So many folk go over budget and time, as they’ve jumped in feet first with a blindfold on costs…..just crazy imo.
SuperFOIL SF19+ in an unheated loft space
Nickfromwales replied to MikeJH's topic in Heat Insulation
The foil will do the square root of zero. It will likely cause problems tbh. There is no quick fix, as above, the flooring needs coming out, at least 200mm of insulation, 300mm is plenty, (some say that after 300mm the weight of the top layers of insulation crushes the lowest layer rendering it ineffective), and board over. The most important thing is to leave a gap at the eaves so air can flow over the insulation, and it absolutely must NOT touch the felt / membrane of the roof. This needs particular care and attention, vs some numb-nuts pushing in as much as they can and asking for cash. -
You could use Illbruck fm330 (closed cell) foam. That's airtight and won't bridge damp / moisture, plus will help insulate the beam. I think just stopping airflow through there would be suffice, so the foam should be a good option imho.
Did you have the rads and UFH before, or are they new and were installed by the heat pump company?
Buffer Tank Hot when Heating Mode Turned Off
Nickfromwales replied to James1234's topic in Air Source Heat Pumps (ASHP)
Needs more questions asked, and some clarity on plumbing arrangements, but I think it simply needs a 2-port zone valve on the return to stop convection heating from the cylinder. It’s defo a buffer as it’s piped up as a 4-port setup. My guess is that heating flows through the buffer by design, when heating mode is selected, as does DHW primary flow. The thing I can’t see is the 3-port diverted valve that sends flow to each discipline individually. Can we have some better pics plz, show plumbing from different angles, all valves etc, insulation removed wherever possible? What temp is the buffer sat at when only DHW is on? Do you turn heating off on the ASHP control as well as on the 3rd party heating controls of the UFH setup? -
Oops I knocked something
Nickfromwales replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
If the pressure hasn't been topped up in a long time (or ever?) by the OP, then it defo doesn't have a leak!! Heating systems have a corrosion happening somewhere, a little over a long time, and this process creates nitrogen (iirc) gas which arrives at the automatic air vents, aka bottle vents, and that gets released as 'air'; there is where a little pressure goes over time. Even with inhibitors / chemical treatments, this happens over time. Other causes can be a tiny leak which happens when the system heats up, and the water just evaporates vs a drip being evident. Again, to be completely expected over the number of joints, system size etc. Relax . Topping this back up to 2 bar is ample....do NOT exceed this is the pressure relief valve(s) will be set to open and evacuate at 3 bar. Normal operating pressure for the majority of heating arrangements is 1.5 bar (filled / checked when the system is cold as heat causes the water to expand and that makes the reading rise / fall slightly). On the braided sliver flexi loop, do you have a black tap both ends or just one at one end? 90o to the pipe direction is fully off, and inline with the pipe is fully open, these are 1/4 turn taps a-la a washing machine tap. If both are closed, as they should be during normal service, then open one fully, then open the other VERY gradually until you hear water flowing. Watch the gauge as the pressure will then start to climb. Get to 1.5-2 bar and then close both taps (make sure you FULLY close them), and check again in 3-6 months. You can move the red needle to where the system pressure was set to, and then you can use that as a reference for how long and by how much the system depressurises. This is not a fault, and is routine maintenance of any sealed and pressurised heating system.
