Ideal drainage pipe gradient advice needed.
Nickfromwales replied to SteeVeeDee's topic in Waste & Sewerage
Understood, just is the opposite of mine, with ~35 years on the coal face. I can still taste the damn coal -
Cylinder suitable for future ASHP
Nickfromwales replied to KOS's topic in Air Source Heat Pumps (ASHP)
That's strange, I specifically remember telling him you lived in Belgium. -
You could just make the battens a bit thicker to increase the gap behind the cladding?
Underfloor ventilation for hob extractor on Island
Nickfromwales replied to paro's topic in Ventilation
Anything sucking air in from outside will pull the smoke/BBQ smells etc into the house. That includes trickle vents, PIV, MVHR anything. Trickle vents are required any time you drop below 3ACH, eg if you have not installed trickle vents/have made your home reasonably airtight or completely airtight to PH standards etc; and are then subject to choking on your own output overnight in the bedrooms, and wafting the stench out of a window after other activities, etc. For one client in the sticks, same scenario, I just put a timer contactor on to the A/C power supply to the MVHR unit to give them a 1-2 hour hit of no incoming air from atmosphere (time delay user-definable), and obvs explained that the vegan curry better 'stay in' until the MVHR system comes back on etc. -
Your BCO makes little sense.....not surprised as so few actually do when it comes to ventilation. Serious lack of education here or 'gettting with the times' . Trickle vents being omitted is fine, but then you need MVHR to provide fresh air to each habitable space, and extracts to all other wet/stinky areas. Any type of ventilation system that doesn't recover heat is just perverse AFAIC, who wants a system on 24/7/365 that blows cold air from outside into all the bedrooms and living spaces all day and night in the winter.....feck that. If you spoke to a ventilation system provider, worth their weight, then they'd tell you under no circumstances should that recirculation system be subject to all the cooking stream/grease etc as it will kill it off at a rapid rate of knots. You defo need to extract the grease etc at source, with a powerful local recirculating cooker hood, and leave the MVHR to change the cleanest possible air in the house, boosting when applicable. Recirculation alone isn't sufficient, unless you have mechanical ventilation. Bloody great help when some professional gives you just 'some' or worse/wrong information, when you are beholden to them..... -
Yup. A good time to charge the domestic battery, as well as the one on 4 wheels, and the DHW, and batch heat the slab, and run the washing machine and TD.....doubt they give 2 hoots tbf. -
I've always had S&C screeds put down by my excellent screeder, and I only ever seal them if we're tiling or bonding a floor down. There is little to no dust associated with a S&C screed, usually anything on the surface is from cutting plasterboards etc on site (dust/debris) which you can manage with a good vacuum. If the laminate is a floating floor, I'd not waste the time/money tbh.
I promise you it'll be a waste of time and effort, as banking for space heating needs to be on a MUCH bigger scale/volume, like 1000L-1500L minimum, to make any sense. -
Yes, I'd improve that with a cut timber, birds-mouthed to accept the purlin so the flat side of the timber rested on the final laid course of brickwork, but I expect this has been there for multiples of decades without a single issue.....
Being a pyramid roof, linear movement is unlikely. Most purlin struts I've seen have been a max 100mm wide timber, sat on a single skin masonry wall. Next to zero dynamic movement here other than wind-shear, so doubt it's an issue.
I can put you in contact with a chap who provides multi-disciplinary trades to my company, based in Sheffield, if you want? He would know a good roofer most likely. PM me if you would like his contact details.
As we continue to preach here, you need a good foundation!
- 22 replies
- wasp killer
- wasps
(and 2 more)
The wasp hitman, lol. Loving the artwork
- 22 replies
- wasp killer
- wasps
(and 2 more)
Grohe Concealed Cistern - Very very slow weep into pan
Nickfromwales replied to steveoelliott's topic in General Plumbing
That is a thing, but usually caused by the flush pipe not running downhill, eg it wasn't cut short enough so there is a trap of water that then sits in the horizontal bit between the bend and the pan. Agreed, and will be the decider. Don't forget that for this to be a true test you need the cistern full of water, so there's weight on the seal, so don't empty it and isolate the feed. -
If propping from the underside, there would (should) be zero disruption to upstairs life. Sounds like you need folk who make solutions instead of problems....
130mm prep under the main tile sounds ok to me, but it's a complete unknown tbh as the underlaying ground will dictate if this should have been tiled over a concrete slab, or just whacked sub-base, or other. Laying the perimeter ribbon tile on to mud doesn't sound like it'll last one winter tbh.... I would have expected the sub base to extend out past the ribbon, by a good 200mm or more, and then a sand and cement haunch to be used to tie in with the same wet course of bed used to set the tiles in (so these were one wet mix vs two sat alongside each other). I think I'd be asking for this to be done again, peeling the turf back to do so, but it depends what you agreed or didn't agree with the landscapers.
Anyone used pitched roof windows on a flat roof?
Nickfromwales replied to AdTee's topic in Skylights & Roof Windows
Just meet the manufacturers installation criteria and you're good to go? Nothing stopping you at all. Standard 'flat' non-openers are simple and robust, but tbh you'll prob want at least 1 to be openable. Not sure how the light would travel through multiples of sloped units vs one big central lantern, but that's your choice of course. Also consider lighting plans and how this arrangement would affect that. -
So few people get this..... IMHO excess (potential export) should go to an immersion via a suitable diversion controller so it can be fed in proportionately, if you don't have a battery. If you have a battery then the whole game changes, and using the HP (routinely and strategically) from self-generated electricity becomes a 'thing'. Batch heating an insulated raft foundation is best, done overnight and in pockets of off-peak TOU windows, but folk with thinner emitters (screed over insulation or rads) will suffer a bit less efficiency here due to near zero 'storage heating', such is life; you have to pay something for heating so this isn't exactly news. As far as DHW goes, I am an advocate of putting in a bigger cylinder so it can be heated from an HP at a cooler (better COP) flow temp, and still have huge additional heat energy capacity for when it's winter and the PV has go ta-ta. Then you can 'super' heat it via the immersion to say 75-80oC, once overnight, and then that will have enough to get you through the day (assuming at least one more off-peak window during the day, which you'd then use to top up again if so necessary). Advice for this will change according to the available tariffs of course, so it is quite difficult to plan to cover all eventualities as some are variables. Go large is the one that is the wisest choice, for future-proofing, AFAIC. -
Intumescent paint over blackjack.
Nickfromwales replied to paro's topic in RSJs, Lintels & Steelwork
Make life simpler.....as once they're in and life has moved on you likely won't ever give 2 hoots whether they were 100mm either way . Too many people I work for seem to get lost in the minute detail, and forget they've a home to build and move in to; the sands in the hour glass don't stop either, and time is always money. Simplify, move forward, go to pub. -
Purlin, or purlin struts have to sit on something that connects the roof to the founds? This is normal.
@LSB Spammers and hackers love personal details, please use the PM system for that Mods.
Ah, pyramid roof no gable end wall....? First pic I saw up top, I thought was a gable. Still doable with some steelwork or a bloody good chippy, assuming a dual cylinder platform could be formed to sit on the masonry wall. Depends on how badly you want the accumulator, as the minimum I'd recommend without pumps is a 300L. To be honest, these are the kinds of jobs I used to love doing, especially when someone told me it can't be done .
Just trying to work out if it's quicker, and easier, and a better job to prop the 1st floor up and just drop that wall so you can do the job properly?
Nope, that’s completely wrong information, sorry. UG stuff is near idiot proof and extremely robust, and as it’s not got UV getting to it has the resultant longevity. Plastic soil stacks rising externally have been fine for 30+ years in direct sunlight. Not sure where you’re getting your information from, but it’s duff. 🫤 -
Wiring an outdoor switch....basic question
Nickfromwales replied to saveasteading's topic in Power Circuits
Yup, just get the end as thin as possible, and use that as a ‘leader’. Otherwise you’ve the combined thickness of the whole cable dia, plus the thickness of the rod taped to its side.
