Temp
    43
Everything posted by Temp
  1. @MrPotts Is it possible to fit smaller jets to reduce boiler power? Not sure about gas boilers but that helped my oil boiler.
  2. Pump over requires water to be drawn down the feed from the header and back up the overflow to the header. This needs either a pressure or temperature difference between these two pipes. So I would be looking at connecting them both to the same T in the CH loop (if that's allowed) to keep the temperature and pressure the same (at least at that point). Perhaps run them up to the tank adjacent to each other wrapped in same insulation to try and keep them the same temperature as much as possible.
  3. Sorry if I missed anything but I think pump over introduces oxygen into the water increasing corrosion. Much like a bubbler in a fish tank.
  4. Planning Permission and Building Control Approval are two different things... Planning Permission I know an extension to the side between your house and the footpath (a highway) needs Planning Permission but I don't think an outbuilding in the same place does. At least not according to my read of this (Section E refers to outbuildings).. https://www.gov.uk/government/publications/permitted-development-rights-for-householders-technical-guidance/permitted-development-rights-for-householders-technical-guidance#class-e-buildings-etc If it did need Planning Permission then after 4 years you should be able to get a Certificate on the grounds that Enforcement action can no longer be taken. Be prepared to prove when it was finished (receipts, aerial photos?) Building Control Approval As its over 15sqm and within 1m of the boundary (and possibly for other reasons) I think Building Control Approval was required. Previously Building Control only had 2 (?) years to take action. However I believe on 1 October 2023 this time limit was extended to 10 years in England and Wales. What would I do.. I think I would Let sleeping dogs lie. When/if asked you need to answer truthfully but that need not mean loss of a sale. I would answer something like: The purchaser should make their own checks but I believe the outbuilding complies with Permitted Development rules (Section E Outbuildings). Building Control Approval was not applied for. Depending on what paperwork you have for the electrics mention that.
  5. Has anyone seen lever locks designed to replace interior door latches without needing surgery to the doors? I know lockable knobs exist (with a key in the centre) but all the lever locks seem to need a separate keyhole and the mechanism changed to add a bolt? PS I mean lockable from outside with a key not a privacy latch.
  6. Given no cracks in the foundations I think that's the most likely theory. Do the cracks even go down to the foundations? Another possibility might be issues with the mortar. Laying bricks when too cold? Does it seem hard or can it be raked out too easily? Not sure what to recommend. I suppose you could remove cracked bricks and replace.
  7. You can judge how secure a lock is by the length of the video. Very few of his videos are more than 3-5 min. Any time he gets out a wave rake you know it's really bad.
  8. When choosing a lock its worth checking what the Lock Picking Lawyer on YouTube thinks of it. Or your house might be as secure as this...
  9. Sadly all too believable. I reckon they hope to be long gone before problems show up. Anyone considering having a driveway or paving done should seek advice here. The Paving Expert web site is also good (see the index).
  10. We have B+B first floor. Layout has all bathrooms along one side of the house. Pipes from shower trays run in the insulation and screed for the UFH. No plynths needed. Low but not ultra low profile traps needed. (Some ultra low traps don't meet building regs). One down pipe/stack is in a downstairs cupboard, another in the corner of a utility room.
  11. We have a lot of trees and I think some leaf fall rots in the gutters before being washed through the leaf trap when there is a heavy downpour. I have to vacuum out the gutters twice a year with a wet vac but it's impossible to get all the "compost" out of them.
  12. Yes. There is a manhole big enough to climb in but that might be dangerous (lack of oxygen or too much CO2 etc). I can see me hiring a cespit company to pump it out at some point.
  13. We have an underground rainwater harvesting tank with a leaf filter on the input. It's been in use since 2007 and has accumulated about 1 ft of sludge in the bottom. We only use it for gardening and car washing but the water does have a brown tint to it.
  14. We needed two beams because a single central beam would bear on a window and the design of the window made that difficult. Afraid I can't recall how deep the beam are.
  15. We have a large room and the SE specified two steel beams to reduce the span of the concrete beams. Only issue was the steel beams are a bit taller which could have caused issues with the UFH upstairs. PS This was a B&B first floor.
  16. Perhaps an extra layer of 70mm insulation on top of the 155mm beam area?
  17. Do you have any equity in an existing property you could borrow against to buy the land?
  18. I'm sure there are wood burning stoves on legs that are designed to draw external air in at the bottom/rear so perhaps you could drill through the slab at the back? Try Clearview stoves.
  19. Thanks for all the replies. Been a bit busy elsewhere this week. Looks like swapping the RCBOs to C20s is working so soft starts might not be needed. The building and it's normal usage pattern wouldn't be suitable for a heat pump. It's a solid wall uninsulated church hall that gets about 3-4 hours use a week depending on bookings. I'm not a fan of IR heaters but in this case they seem to be a good option. There is also an original fireplace that gets used frequently for the longer sessions. Great to huddle around after poker night. The wiring all looks pretty neat and tidy with modern CU etc. I think the electrician might be giving mates rates so he's good but fits the hall in when he can.
  20. He said the Earth leakage was ok but I don't recall him mentioning the earth loop impedance. I thought he was concerned that a short might not draw enough current to trip the breaker but I might have misunderstood. I know he was going to test the wiring before deciding if 20A breakers were ok. Apparently that test went ok as he's fitted some C20 and I've heard he plans to do the rest. Just to add they only seem to trip immediately at switch on not during use.
  21. Apparently he's experimenting with B and C 20. Jury still out. Got a mixture in at the moment. When I tried them those on C20 seemed reliable. The few on C16 not reliable (tripped 2 of 3 tries to turn on).
  22. @Onoff & @Nickfromwales I think it started getting worse as the weather got colder but then again they aren't used much in summer. I was able to speak to the electrician briefly today. He confirmed.. Each heater is 3kW (approx 12.5A). The insulation breakdown tests he did recently passed ok He plans to change the RCBOs from C16 to C20s but might not be able to do them all. Think he said he needed to check the wire impedance to ensure they would trip if there was a short? He also mentioned he's considering investigating NTC devices to limit inrush. Ive used these before as auto resettable fuses at much lower currents. But not for high power applications like this. I know they can be a bit tricky to get the right spec. Dimplex who sold the heaters say they aren't made/supported now.
  23. As I recall you have to walk around the room switching on each heater in turn so I don't think the issue is multiple heaters being turned on at the same instant.
  24. You can either fight them or find out what bricks they approved on other new builds in your street. Make sure to tell them they are the same as already approved up the road. Ditto the windows.
  25. I think it might be to stop a developer building a house, then just before fitting the front door they sell it to Mr Smith and agree the builder is actually building a self build for Mr Smith. They could split the CIL saving between them. Something like that. Requiring all the paperwork at the outset stops this.
