Yes, there is too much cash floating about in the UK economy. Probably not what you meant through. There is also the problem that people are not always rational actors when it comes to some purchases. I would like to get involved. Made boats and caravans/campervans in the past, not really very different are they. There was a marine project down a while back. They had some huge blocks of polystyrene left over, ideal for pontoons.
I very much like the idea of a floating house (I am building a boat at the moment, Mk2 should be sleepable). Thing is that is really just shows that building land is overvalued and water is not.
Got my light meter out, blinds closed (they are not a perfect fit), 3 LUX, LED on, 12 LUX, old CFL 7 LUX initally, 19 LUX after warm up. My point is that there is a lot of nonsense spoken about lighting, light quality and bightness levels, colour etc. Get yourself to Poundland. Edit, just opened the blinds, got a light reading of 20 LUX Edit 2, 15 minutes later the reading is 8 LUX
Same as here, chuck it overboard
I swapped out all my 8W CFL last week for 3W LEDs About the same amount of light (never did a reading but I could for a laugh). The bayonet LED bulbs came from Poundland, for a £. So I now have a 38% energy saving. Cost me £8 If I left 2 lights on 24/7, that would be about £8 for a year. So how much do these systems cost?
Alternative to pesky, parky, polycarb roof
SteamyTea replied to Hillydevon's topic in General Self Build & DIY Discussion
You can get aerogel filled glazing, but I would think it is expensive. You may be able to make your own with silica filler and some polycarbonate or toughened/laminated glass sheeting. http://www.cfsnet.co.uk/acatalog/CFS_Catalogue__Colloidal_Silica_402.html http://www.cfsnet.co.uk/acatalog/Q_CELL_Lightweight_Filler.html http://www.cfsnet.co.uk/acatalog/CFS_Catalogue__Glass_Bubbles_403.html Depending on how much light is really needed, you could replace some roof panels with solid insulation. It should be fairly easy to insulated the walls, either internally or externally, and if you can, do the floor as well. There way be a height issue though. Easy enough to fit some thermal blinds on the windows, they can help a lot, as could secondary glazing (making it triple/quadruple glazed. These could be removed in summer. May be worth looking at the heating and seeing if any secondary heating system can be fitted. There is a large choice from a child killing wood burner, though infrared, simple fan heaters, underfloor heating etc. As this is more about comfort that the cheapest running costs and technology payback, don't look at anything that seems to be "magic", it is simply thermal engineering. -
Yes
As always, you need to look at the numbers involved. So you need to know, in no particular order, the min, max and 3 standard deviations (99% of the time) for your space heating load. This will help you choose a boiler of any sort. Domestic Hot Water (DHW) then complicates it if you are running it off the same system. Basically, it cannot do both at the same time, so you loose a bit of space heating while you are heating water. So you go oversize a bit to accommodate this. All that is fairly easy to establish either from first principles or from a local plumbers experience. It gets harder when trying to work out the best options for supplying the energy and power (energy and power are different things). Starting at one end you can have normal resistance heating, just an electric heater that warms the room or water. Then you could have an infra-red heater for the rooms, and resistance for the water. Resistance water heating can take two forms, stored and unstored, so a cylinder that is heated up, or an inline instantaneous water heater (like a cheap shower). Moving up a step, you can get a solid fuel boiler, that can heat water to supply the space and DHW systems. Or an oil one, or a gas one. Then you could look at Air 2 Air Heat Pumps for space heating and resistance heating for water. Or an Air 2 Water Heat Pump (ASHP) for either just space heating (works well) or for both space and DHW. The DHW side is a bit trickier as it needs to deliver at a higher temperature, so can, when it is drawing cold air from outside, have a coefficient of performance (CoP) of 1 (one), which is, in effect, just a resistance heater. ASHP also 'frost up', so need to be sized correctly (oversized) to reduce the periods that this happens. Not a big issue (though people make it one), just a feature of the technology and physics. One way around the lowing CoP is to heat and store DHW at a lower temperature, then boost it up with an inline heater. Then there is Ground Source Heat Pumps (GSHP). These work exactly the same as ASHP, but draw the heat from the ground (actually they tend to use the ground water that passes by). They generally don't suffer from frosting, though it has been known to freeze the ground in some places (when the pipework is not deep enough and sized incorrectly). Generally they are very good and reliable, but still fail to reach a high temperature for DHW, so usually have a resistance heater built in to help out (but this lowers the CoP). Finally you can have a Water Source Heat Pump if you are by a large river or lake. These are the best, but impractical for most people. Now comes the harder bit. The environmental damage that each technology causes. This is usually based around two criteria, CO2e and resource depletion/damage. So Coal has a pretty bad environmental record. It has high CO2e emissions, is limited in reserves (though they are still huge) and wrecks the mining area. Gas and oil are similar, but better, a lot better on all 3 counts. Reserves are more limited, but still huge. Large scale Hydro has low CO2e (though the constant plant growth/decay adds to the CO2e levels) but causes large amounts of damage locally and socially (a million people moved in China). Nuclear has a very low CO2e footprint, but is expensive and not very useful for variable loads (not a criticism, but a characteristic of the technology and physics) Then moving onto the more 'renewable' technologies is Wind, a good method of generating energy, but not so controllable on the power though. To be more useful on power delivery, we would need either, a lot more turbines (like millions of them) or a decent storage methods (and the best is pumped water storage, so see Hydro for issues). Wind is not without problems, it causes great social issues (though not as great as climate change and not having electricity cause). It is cheap to deploy though and can now be integrated quite well into very large national grids (once planning has been overcome). Solar is similar, and oddly, in the UK, would use less land area (but in a different way,). It has the advantage that is is quiet, can be easily scaled, and is easily moveable (it packs up into a truck). Like Wind, it is low CO2e but does rely on some mineral depletions (not a problem today, but could be in the future). Finally there is Ocean Based Generation. The best is probably tidal flow (turbines under the sea) and then tidal lagoons (hopefully one being built near Cardiff). The worse are tidal barrage as they physical change the local environment , though can help with local flood control. They are predictable though. One problem is that when integrated into a grid, is that other systems need to be turned off. This sounds like a good thing as coal fired generation could be turned off, but it is often easier to turn off Gas and Wind as they do not need long lead in times. So not the ideal silver bullet that people thing. The very worst is wave power. They just don't last very long around our coast line. They are still experimenting with them though (I like the Hayle Estuary, it has a cafe at the shallow end). So all that, may or may not, help you decide which is the 'best' system to use. If I had spare cash, I would got for an PV assisted ASHP, UFH, TS with IL RH for DHW. Just had to get all those horrible abbreviations in. But as it is I shall stick with my storage heating on E7.
Psycho Active Substances and piles
SteamyTea replied to ToughButterCup's topic in General Self Build & DIY Discussion
There was some research done on swimming pool water quality back in the 80's, they found that most swimming pools where pregnant. Confirmed what I always though that the words 'swimming pool' has a silent P in it.
You can buy the jets, there are two sorts, water and air. Its is not the jets though, it is all the pipework that needs to be leak free when making one 'back to front'. You can buy a shell at a reasonable price if you hunt around, a lot easier. Try SpaForm in Southhampton (if they are still going).
I used to supply and build, spa baths. The worse job I ever had to do was clean out the DE filter from the Sheffield YMCA leisure club. I still don't like to think what those young men got up to in it. One we fitted in Shrewsbury leaked, the shop below was not happy. Two minutes in the one at Bedford Leisure Centre (the one mention frequently in the Brittas Empire) caused my legs to go very rashy. http://www.skinsight.com/adult/pseudomonasFolliculitisHotTubFolliculitis.htm Vile things that are best avoided.
https://www.amazon.com/Does-Anything-Eat-Wasps-Unsettling/dp/0743297261
You only have to run the numbers to realise there is no merit in having a battery power pack at home yet. Maybe one day it will be viable. Just remember that you can, if you shop around, buy a unit of power for about 13p, and if you are storing power, then on E7 it is less than 9p. So take my house that uses 4000 kWh, with 80% on E7, that is £288/year. If these power packs really can last 10 years, that is £2880 installed to break even. And that is assuming they can survive 3650 charge/discharge cycles and deliver a decent amount of power (say enough to boil a kettle). At the moment my storage is a 29 year old, 200 lt water cylinder on the original element and thermostat. It can hold about 10 kWh of energy, deliver power at 60 kW, has an efficiency of about 75% and would cost less that £300 to replace.
Yes, I think it is frowned upon, and the same 1% voltage drop rule still applies.
Too late, but I always buy rolls, so you made the right decision.
Yes, as it is not legible for FiTs, make the DC side long. If claiming FiTs, then put the generation meter as close to the modules as possible.
Here is some data I have collected for my place: Date Temp 01/09/2015 16.3 02/09/2015 15.9 03/09/2015 15.7 04/09/2015 15.6 05/09/2015 15.6 06/09/2015 15.5 07/09/2015 16 08/09/2015 15.9 09/09/2015 15.4 10/09/2015 11/09/2015 15.6 12/09/2015 15.7 13/09/2015 15.2 14/09/2015 15.1 15/09/2015 14.7 16/09/2015 17/09/2015 18/09/2015 19/09/2015 15 20/09/2015 14.3 21/09/2015 14.8 22/09/2015 14.3 23/09/2015 14.3 25/09/2015 13.7 26/09/2015 27/09/2015 14.8 28/09/2015 29/09/2015 14.2 30/09/2015 13.9 01/10/2015 14.6 02/10/2015 14.5 03/10/2015 14.1 04/10/2015 14 05/10/2015 06/10/2015 13.9 07/10/2015 14.2 08/10/2015 14 09/10/2015 14 10/10/2015 13.7 11/10/2015 14.2 12/10/2015 13/10/2015 13.4 14/10/2015 12.3 15/10/2015 13.3 16/10/2015 12.9 17/10/2015 13 18/10/2015 12.9 19/10/2015 12.8 20/10/2015 13.1 21/10/2015 13.1 22/10/2015 12.9 23/10/2015 13.1 24/10/2015 13 25/10/2015 12.6 26/10/2015 12.4 27/10/2015 12.8 28/10/2015 12.5 29/10/2015 12.5 30/10/2015 12.3 31/10/2015 01/11/2015 13.1 02/11/2015 13 03/11/2015 12.8 04/11/2015 13 05/11/2015 13 06/11/2015 13.1 07/11/2015 13.1 08/11/2015 09/11/2015 10/11/2015 11/11/2015 13 12/11/2015 12.8 13/11/2015 12.7 14/11/2015 12.3 15/11/2015 12.2 16/11/2015 12.4 17/11/2015 12.3 18/11/2015 12.5 19/11/2015 12.6 20/11/2015 12.4 21/11/2015 11.2 22/11/2015 10.1 23/11/2015 10.8 24/11/2015 10.8 25/11/2015 11.1 26/11/2015 10.9 27/11/2015 11.2 28/11/2015 11.1 29/11/2015 10.7 30/11/2015 11.2 01/12/2015 11 02/12/2015 11.4 03/12/2015 11.4 04/12/2015 11.3 05/12/2015 11 06/12/2015 11.3 07/12/2015 11.6 08/12/2015 11.7 09/12/2015 11.5 10/12/2015 11 11/12/2015 10.5 12/12/2015 10.9 13/12/2015 10.6 14/12/2015 11.2 15/12/2015 11.1 16/12/2015 11.7 17/12/2015 11.5 18/12/2015 11.6 19/12/2015 11.5 20/12/2015 11.9 21/12/2015 11.4 22/12/2015 11.3 23/12/2015 11.4 24/12/2015 11.5 25/12/2015 10.7 26/12/2015 10.9 27/12/2015 11.3 28/12/2015 11.2 29/12/2015 11.3 01/01/2016 10:00 9.9 02/01/2016 08:00 9.6 03/01/2016 07:40 9.8 04/01/2016 08:45 10 05/01/2016 06:00 9.4 06/01/2016 08:30 9.7 07/01/2016 07:00 9.4 08/01/2016 08:30 9.4 09/01/2016 09:45 9.5 10/01/2016 09:30 9.4 11/01/2016 08:00 9.1 12/01/2016 18:00 9 13/01/2016 08:00 8.4 14/01/2016 07:30 8.3 15/01/2016 07:30 6.9 16/01/2016 16:00 7.8 17/01/2016 08:00 7.1 18/01/2016 08:30 8.3 19/01/2016 06:00 7.6 20/01/2016 13:30 8 21/01/2016 10:30 8 22/01/2016 09:15 8.7 23/01/2016 07:20 8.6 24/01/2016 18:00 9 25/01/2016 15:30 9.3 26/01/2016 08:30 9.6 27/01/2016 07:30 9.4 28/01/2016 08:00 9.8 29/01/2016 07:30 8.6 30/01/2016 07:30 8.7 31/01/2016 10:30 9.1 01/02/2016 08:00 9.2 02/02/2016 12:00 9.25 03/02/2016 07:00 9.3 04/02/2016 07:30 8.2 05/02/2016 08:30 8.5 06/02/2016 14:30 9.1 07/02/2016 12:00 8.7 08/02/2016 08:30 8.3 09/02/2016 06:00 7.7 10/02/2016 09:00 7.5 11/02/2016 12:00 7.65 12/02/2016 15:00 7.8 13/02/2016 09:00 6.8 14/02/2016 07:30 6.5 15/02/2016 22:00 6.6 16/02/2016 12:00 7.2 17/02/2016 09:45 7.1 18/02/2016 06:00 7 19/02/2016 09:00 6.9 20/02/2016 06:30 6.8 21/02/2016 18:00 7.4 22/02/2016 08:00 8 23/02/2016 08:00 7.9 24/02/2016 09:00 7.2 25/02/2016 07:30 8.1 26/02/2016 08:30 7.5 27/02/2016 08:00 7.2 28/02/2016 07:00 6.4 29/02/2016 07:00 6.5 01/03/2016 06:30 6 02/03/2016 07:00 7.3 03/03/2016 07:30 8.4 04/03/2016 07:30 7.6 05/03/2016 07:00 6.8 06/03/2016 08:00 5.9 07/03/2016 07:15 7.1 08/03/2016 08:00 6.6 09/03/2016 07:00 7.4 10/03/2016 07:30 7.2 11/03/2016 07:30 7.5 12/03/2016 07:15 7.4 13/03/2016 07:30 7.4 14/03/2016 07:00 7.3 15/03/2016 07:30 7.5 16/03/2016 07:30 8.1 17/03/2016 07:45 8.1 18/03/2016 07:30 8 19/03/2016 07:30 7 20/03/2016 07:00 8.2 21/03/2016 07:30 8.2 22/03/2016 07:00 7.4 23/03/2016 07:00 8.8 24/03/2016 07:00 9.1 25/03/2016 06:30 8.3 26/03/2016 06:30 8.8 27/03/2016 07:00 7.8 28/03/2016 06:00 7.5 29/03/2016 08:00 7.8 30/03/2016 07:30 7.7 31/03/2016 08:00 7.6 01/04/2016 07:30 7.3 02/04/2016 06:00 8.5 03/04/2016 14:00 9.3 04/04/2016 18:00 9.7 05/04/2016 07:00 9.5 06/04/2016 07:15 10.6 07/04/2016 09:30 9.3 08/04/2016 07:15 9.8 09/04/2016 00:00 9.5 10/04/2016 07:00 9.2 11/04/2016 07:30 9.1 12/04/2016 08:00 9.2 13/04/2016 08:00 10 14/04/2016 07:00 10.5 15/04/2016 23:30 10.7 16/04/2016 00:00 10.7 17/04/2016 00:00 10.45 18/04/2016 07:00 10.2 19/04/2016 07:00 10.2 20/04/2016 07:30 10.9 21/04/2016 08:00 11.2 22/04/2016 07:00 11.2 23/04/2016 07:00 11.1 24/04/2016 07:00 11 25/04/2016 07:00 11.5 26/04/2016 08:00 10.8 27/04/2016 06:30 11.3 28/04/2016 08:10 10.7 29/04/2016 07:30 11.2 30/04/2016 08:30 11 01/05/2016 00:00 11.35 02/05/2016 08:15 11.7 03/05/2016 07:00 12.3 04/05/2016 07:00 12 06/05/2016 08:30 12.3 07/05/2016 07:00 13.3 08/05/2016 07:00 13.4 09/05/2016 00:00 13.35 10/05/2016 07:00 13.3 11/05/2016 08:30 13 12/05/2016 06:30 13.1 13/05/2016 08:00 13.3 14/05/2016 00:00 13.4375 15/05/2016 00:00 13.575 16/05/2016 10:00 13.8 17/05/2016 22:30 14.7 18/05/2016 14:15 14.4 19/05/2016 08:00 14.1 20/05/2016 07:00 14.4 21/05/2016 07:30 14.2 22/05/2016 07:45 13.7 23/05/2016 06:30 14.3 24/05/2016 07:00 14.3 25/05/2016 08:30 14.1 26/05/2016 07:00 14.8 27/05/2016 07:30 13.8 28/05/2016 07:30 15.1 29/05/2016 07:30 15.4 30/05/2016 00:00 15.7 31/05/2016 07:00 16 01/06/2016 08:15 16 02/06/2016 07:00 16.5 03/06/2016 07:00 16.9 04/06/2016 06:30 17.1 05/06/2016 08:45 16.7 06/06/2016 07:30 17 07/06/2016 07:00 18.2 08/06/2016 07:30 16.7 09/06/2016 07:30 17.8 10/06/2016 07:15 18.1 11/06/2016 07:15 17.7 12/06/2016 07:00 17.7 13/06/2016 07:00 17.1 14/06/2016 07:30 16.6 15/06/2016 07:30 16.5 16/06/2016 08:00 16.1 17/06/2016 07:00 16.5 18/06/2016 00:00 19/06/2016 00:00 20/06/2016 00:00 21/06/2016 07:00 16.2 22/06/2016 07:00 17 23/06/2016 06:30 16.8 24/06/2016 06:45 16.3 25/06/2016 08:30 16.7 26/06/2016 07:00 17.3 27/06/2016 08:00 15.9
Rest and relaxation - escaping from the build
SteamyTea replied to Stones's topic in General Self Build & DIY Discussion
BitPipe You should have said you were coming down, could have met up. Which bit did you go to? -
Still building mine. -
- 16 replies
Rubber Roof Ladder (Or was it a dream?)
SteamyTea replied to Barney12's topic in Roofing, Tiling & Slating
Try Argos http://www.argos.co.uk/static/Product/partNumber/2149347.htm?CMPID=GS001&_$ja=tsid:59156|cid:189934405|agid:18074225845|tid:pla-96619497925|crid:77627770765|nw:g|rnd:17930596787601001801|dvc:c|adp:1o1&gclid=CIqc8sG6z84CFQsW0wodZBMJog I must have been tied (I was and still is). I read this a a rubber roof rack. -
BT/Openreach New Connection
SteamyTea replied to worldwidewebs's topic in General Self Build & DIY Discussion
Have you tried putting the phone at the focal point of a satellite dish and seeing if you can get a better signal. -
No, but as I was paying for a mobile (£10/month), a fixed line with BB for £35/month, but now paying just £20/month with GiffGaff for unlimited downloads, calls and texts, I make that a a £300/year saving. Got to be kept in perspective, I had a dreadful broadband connection and no immediate plans to upgrade the local exchange. -
My cheap MotoG has built in WiFi Hotspot software, I can stick it 20 metres from the house and it works well. I am lucking in that I have a decent 4G transmitter less than a mile away. I was over an Joe90s build and it had no signal, maybe my next visit over there I can play with it a bit more (if I ever get invited back, apart to apologise). If going doing the 4G route, it may take a bit of mucking about and an old satellite dish to see what is going on. I also use an free O2 service that that allows me to connect in cafes and other places. May be worth seeing if there is a map of the coverage.
