How long did she sit on it before she got hot, sweaty and cross eyed. Leave it plugged in and you can play with your new stereo.
The physics of cement cohesion All answers are above. Good luck, it is a technical read.
Isn’t that what this means As the difference is a pressure i.e. Pa = kg⋅m−1⋅s−2 Then a relatively small difference can, over time, have a large affect.
Really just got to replace the air, for drier air, at the boundary layer.
Narrowest retaining wall options for hedge boundary
SteamyTea replied to flanagaj's topic in Landscaping, Decking & Patios
Remember this. -
If the box covered area continues to show high humidity, then I think that it shows that there is chemical curing happening i.e. the exothermic heating is driving out excess moisture. It may be the case that there is a sudden decrease in RH as the process stops. I am rather guessing here, but can't think of any other reason to check the RH in an airtight box above a wet floor.
Good idea. Fibres can be coated with hydrophobic molecules, this is why some wool type insulation can be used to fully fill the cavity. @boxrick I may not fully understand your drawing, but I would be concerned about solid insulation below the DPM floating upwards in a flood situation. It is likely to cause other issues above it. I would raise concerns with the Architect before talking to the builder, though you may need to mention that work in that area will have to stop.
Concrete, well cement, uses water as part of the exothermic curing reaction. Excess water is used as a lubricant to help the mix flow. If the air has high relative humidity, no amount of fanning it will reduce the amount in the cement mix. This is almost the definition of Relative Humidity. At 100% RH, the partial pressure is equal to the vapour pressure. At that point, no meaningful transfer takes place. You may be better off fitting a dehumidifier if you are in a hurry. Portland cement hardens quite fast, but can take weeks to cure.
Who members this from 1998. 'Lord Irvine told the Commons Public Administration Committee on Tuesday he had no reason to apologise for spending £59,000 on wallpaper'
I made up my own secondary glazing to cover up my old double glazed windows. The noise reduction was quite amazing. Very rarely does it go above 20 dB now, and I am not far from a busy road. This is what I am hearing at the moment and it is quite breezy outside.
Would the losses of having a small area of reduced insulation make much difference, thermally. As it is a pipe, there is only a very small area on the upper facing area, and it is mainly full of air, which is a good insulator. Try modelling it and see what the numbers say.
- 17 replies
- ufh
- raft foundation
(and 3 more)
Oddly enough, it doesn't. Now that may sound controversial but it is to do with fluid dynamics, which are often categorised by a Reynold's Number, which is a unitless descriptor. Another way to think about it is not by the volumes being moved, but the masses moved. Reynold's Numbers tend to be big, Air is around 1500 and water around 1000. This does not imply a 50% difference and temperature and pressure make a huge difference, as does turbulent or laminar flow (pipe size and shape). That is a very brief, and simplified explanation, fluid dynamics is a horribly complex area of science/engineering. Apart from that, I can't help, but it probably explains the odd numbers quoted.
BBC Archive (1981) Future Home 2000
SteamyTea replied to Nick Laslett's topic in Property TV Programmes
Was it that cheap, I can't remember. I think electricity was about 5p/kWh 1981 was the start of a recession, and we had had high inflation during the 'winter of discontent'. I opted out, rented out my home and went back to university.- 27 replies
- bbc
- innovation
(and 3 more)
It is on BBC Youtube Channel, not iPlayer.- 27 replies
- bbc
- innovation
(and 3 more)
Finishing window reveal around brackets?
SteamyTea replied to BadgerBadger's topic in Windows & Glazing
Yes, more than you think. Insulation follows an inverse rule. So say uninsured that the losses are 1 W.m-2.K-1 and 5mm of insulation reduced that to 0.8. The next 5mm will only reduce it to 0.64, not 0.6, next 5mm to 0.512. So even a small amount is worth it. It can also affect the condensation point, which can be problematic around windows. -
Is that also known as a reed bed system, or is that something else again. I quite like the idea of my waste going through a treatment plant (having seen inside one, they don't seem very complicated, a bucket with an air bubbler in it) and then into a hole in the ground with some damp living plants growing out the top. Must be more to it than that.
I thought it meant we could not go skinny dipping: no swimming between red flags.
Yes, I think total capacity is the important part. Less washes needed. Think it is the mass of laundry. Water needed to be replaced as the soap powder has to be washed out. I recently got so decarboniser for work, it is mixed with water and you dump the blackened pots, pans and grills in it. Looked at the chemicals in it for the COSHH file, same stuff as washing powder. Worth knowing if you have a blackened kitchen tool.
I heard you used to be a gynaecologist, until you got caught.
It is pennies difference. My Bosch uses between 30 litres and 110 litres, with temperatures ranging from between 30°C and 60°C. It can also take up to 9 kg of load. So taking the worse case, cottons at 60°C, max load of 9kg, the manual says it uses 1.75 kWh. So even at my day rate, that is about 61p. As I usually run it at night, it is 25p. On the mixed load 40°C setting, which can take up to 4 kg, it uses 0.64 kWh. So either 23p or 9p. I usually use the 'speed perfect' setting at 30°C and I seem to remember that it uses 0.3 kWh. So 11p or 4p. So really, washing machines are pretty good. The big saving is is not using a tumble dryer. I am on my second Poundland washing line (I still have some left from the second one I bought), so that has cost be 10p/year. Just thought that at about £8/m3 for water and waste, the small, 30 litre wash costs 24p. Have I ever mentioned that we have the most expensive water in the country, which will also make it one of the most expensive in the world.
