SteamyTea
    200
  1. Here we go, with thanks to @Trw144 https://www.wolseley.co.uk/product/vaillant-arotherm-plus-air-source-heat-pump-35kw/
  2. Yes, but as it will only run for a short time, frosting may not be an issue. When I get home i shall see if I can find the little pump someone suggested. When I looked at the physical size, it was the same as the 5 kW one. And probably more expensive.
  3. I found (well someone else did) a 3.6 kW (may have been a 3.8) ASHP. A bit of searching on here should find it. All I need is a very small ASHP and keep wondering if a very basic swimming pool one, connected to the heating via a decent size buffer, will do the job. Not as if it will run for very long.
  4. SteamyTea
    Rainfuel
    This 1956 paper is easier reading. It explains why we don't use lightening to charge the national grid. The Electrification of Individual Cloud Droplets.pdf
  5. SteamyTea
    Rainfuel
    From 1926. So a reality check is needed. If a few drops of water could produce a usable amount of power, think of all the metal things, especially aluminium, that is insulated from the ground, say a boat on a trailer. Touching it would hurt. As this is not a new concept, with the physics known about for over 100 years, if it was viable, we would be doing it. rspa_1926.0108.pdf
  6. Always compare any extra you have to pay for that with a small (2 kW) portable generator and an extension lead.
  7. All this assumption that bills are going to keep drastically rising is worrying. Now I don't know what any individual pays, or what 'deal' they are on, but over the recent decades, household energy bills have averaged about 5% of household income. If there is an expectation that the fraction will become 15%, then the government will step in (again). There is also transport fuel costs to take into account. These have gone up. If an ordinary household uses 1000 litres a year (oil companies used to work on 1 tonne a year per car), then that is approximately £500 extra year. It is just a matter of how the government steps in (individual allowances, or state aid to the producers or retailers) and when. Still, we have paid the $400m to Iran by the looks of it.
  8. Possibly caused by static charge, so just electrify the roof. https://physics.nyu.edu/grierlab/charge6c/
  9. Just get a third meter that switches on when cooling.
  10. SteamyTea
    Rainfuel
    It was alright till 10:30 AM.
  11. SteamyTea
    Rainfuel
    Here is the data for Niton. Did not rain much on Jan 1st. https://www.wunderground.com/dashboard/pws/IENGLAND232/table/2022-01-1/2022-01-1/daily
  12. SteamyTea
    Rainfuel
    What you do is drill a large diameter hole down to sea level. Then, when the waves hit the bottom of the hole, the air in the tube is compressed, this then runs a turbine at the top of the hole. The Wells turbine is the type to use as it spins the same way regardless of air direction.
  13. SteamyTea
    Rainfuel
    Wave power would be better.
  14. SteamyTea
    Ouch
    I used to use a company called London Toughened Glass. The sheets used to pass though a tunnel with gas burners in it. There was nothing done to recover the waste heat in the building.
  15. SteamyTea
    Rainfuel
    This going to be fun. As for rainfall, what is your location, nearest town North East of you should give a fairly good indication. Statcoulomb is a good word. https://en.m.wikipedia.org/wiki/Statcoulomb
  16. Reputation points are one way. But then, for a laugh, I got @pocster to keep voting for me, then I returned the favour, once. This is why it has been suggested that with things that require calculation i.e. thermal losses, electrical power, seasonal heating loads, some basic calculators are created. Nothing fancy, just basics, with an explanation of the workings. Then, when we get asked for the umpteenth time about how much insulation to put under an UFH system, we just point the person to the calculator, maybe a permanent link to a page, somewhere near the top, like the banner. When I suggested this, I was told, not by you, but another, that if it was so simple, why don't I do it. So I did and posted up a link to a simple example. Then I went to Canada and forgot all about it. Think I may still have a folder if HTML5 calculators in my PC.
  17. I moved from a very hard water area (Bucks) to a very soft water area. Never had an element go in a washer or kettle in 20 years. The DHW cylinder one went, after 33 years, but the cylinder was also leaking. Probably saved myself about 100 quid, or £2 a year in replacements.
  18. Shame the did not do the tracking. Another trip to get that sorted. Still, it sounds better when I hit potholed. Going to phone up Rod.
  19. It is because just about everything has to be bigged up, turned to 11. You can't get your car cleaned without it being called 'detailing' by some nob. I am currently sitting in a garage as my car needs a new ball joint. They are also going to put it on 'the diagnostics'. It is a suspension joint.
  20. I always like to see an electrical outlet close to a tap.
  21. SteamyTea
    Ouch
    Depends on the contract with their customers. I know the MD of a large haulage customer, they have a fixed price plus a fuel surcharge that is auditable. Generally when inflation goes up, so do the bank rates. We lived abroad when the 1970's 'stagflation' hit the UK. It is a hard position to get out from.
  22. Yes. But it can be standardised to a set temperature i.e. 15.5°C or 12°C. What you will get is a distribution, that can be useful.
  23. Does that mean there is some other kit that goes with it?
  24. If you plot energy usage against heating degree days, that gives you a fair estimate.
