Little, if any, environmental benefit over OPC, and at least cement set hard. Going to be an interesting challenge to get a non cast foundation system past the building inspector.
- 17 replies
- strawbale
- foundations
(and 2 more)
I am surprised we don't already do that. Not even sure if we have a synchronisation signal. Could use the old number station channels
He actually did not believe his model. Not surprising as it had never been tested. Since then if has been shown to be pretty good and adaptable to others houses.
WPD told me that technically more can be fed back upstream, but then it starts to interfere with the larger generators, they cannot easily be powered down and kept within the frequency range. It is why domestic fridges are not turned on and off for grid balancing, but large refrigeration equipment is. All about knowing, the sinks and sources and their characteristics at startup. Don't want the tail wagging the dog.
That is sales people for you they can only sell what they have.
Not in practice. The times when windspeed is low, solar radiation high, along with high air temperatures are very rare, and the solar radiation levels are probably higher than STP for the modules, so they would be over performing anyway.
You would get a lot more PV on a tradition roof
Have a look at roof integrated. As cheap as tiling and looks much better.
Just thought I would look at the usage of my mother's old Bosch oven. The meter was reading a stead 240W, checked her pie and it went up to 2040W. So 1.8 kW, for an hour. My much newer oven used almost half that at 1 kW. Both are a similar size. Getting my supper cooked by some nice Indian men.
This has been tried by the manufacturers and they found out that for the same quality of wash, it actually takes more energy. And the soap manufacturers where not keen because some if the mixes solidify when cool.
Trickle power. Energy is power, multiplied by time. So they may not be as good as you think.
How does your garden grow?
SteamyTea replied to recoveringbuilder's topic in Landscaping, Decking & Patios
-27⁰C when I last checked. I usually do the temperatures on the cooked food. Why we have 5 stars.
By having it go to export, everyone benefits, a little.
If I had known she would still be alive 5 months after her stroke, I would have got myself a hybrid for the weekly 600 mile journey. Recon I could get 8 kW on this roof. Lovely and sunny today.
Smug. But just think off all the poor people you are helping who have been waiting for nearly two decades for your local nuclear power station to get finished. Just charging up the battery in my mother's car as it has been sitting idle for 5 months. Sounds alright, in tickover, for a diesel.
First two are almost right. The wave power isn't. To the best of my knowledge there has been no, large scale, wave power that has been successful, globally. Mate of mine worked in the industry and he left because he got fed up with 'hopeless projects that were going to fail'. To quote an engineer based at WaveHub, 'it is a bit rough out there'.
C is usually used for coulomb, not sure that 3 of them is 1200A. Or have I misunderstood something. 3C.s-1 = 3A
Well it is meant to work like a mirror. So why don't we put acrylic mirrors on our walls and lofts.
Do you know how much energy you currently use, and when you use it? If not, find out.
What about this bloody monstrosity!
SteamyTea replied to SuperJohnG's topic in Rainwater, Guttering & SuDS
Second idea. How about creating a new facia that runs the full width, and a bit deeper. Use that to cover the existing gutter, 3 short downpipes going into a larger pipe (that is hidden behind the false facia), then to a popper downpipe at one end. -
Is this a good price for oil installation?
SteamyTea replied to harry_angel's topic in Boilers & Hot Water Tanks
What power oil burner has been suggested?- 13 replies
- oil boiler
- oil tank
Which heating system to use on our new build?
SteamyTea replied to Johnny Jekyll's topic in Underfloor Heating
Have a hunt around on here for Jeremy Harris's spreadsheet. That is about as good as you need. As for why you should do it, it is because it allows you to change thermal performance of the fabric elements. That can save you thousands. -
I was just trying out posting from my Kindle, using Brave. It won't let me post from my old one since the forum software upgrade (downgrade in my case). But works fine on my newer Kindle. So time to root the old one and see what it can really do.
We often get asked on here how much a build should cost. Usually this is based on £/m². Why not base it on a multiple of Architects fees. So when you want to build get an estimate of what an architect will charge, then multiply by 20. Then laugh.
