Looking at getting a van, what do you think?
SteamyTea replied to CalvinHobbes's topic in General Self Build & DIY Discussion
If I leave the bath full of water to cool, I get a damp house, unless I keep the extractor on, which defeats the object. Having MVHR would help. A cubic metre of water costs me about £8. Cost about £6.50 to heat up at night. Short, cold showers are really the answer, not the hot soak in the bath I prefer. I get all the health and wellbeing advantages of cold water swimming from a hot bath.
They are offering you a size they have in stock, not a deal. Payback on a RWH system is really dependant in how much you pay for your water and waste, I pay the most for it the country, and it is a poor service. Had more water disconnections than electricity ones. Anyway, no one looks at payback on kitchens or bathrooms. RWH should be thought of as 'doing the right thing' rather than a monetary gain. £4k in a £400k house is 1% of the value, so keep the price in perspective.
I had a lodger who had aa very bad stroke when she was young, had medical problems every since. One was epilepsy. Now with an epileptic in the house, doors are never locked, never, not even the bathroom. Simple rule, close the door if you are in there, leave it open when you are not in there. So returning home after a long journey, I need a wee, quiet house so rush upstairs and the bathroom door is ajar, rush in, then see the body of my lodger laying in a still bath of water. "Oh Becky" I sighed in a very mournful way. Then the (expletive deleted)ing bitch came alive and sat up. Neither of us froze, we both shriek with fright, then hysterical laughter. Still, I go to see my lodger, who was 21 years younger than me, naked.
Any sources for plastic greenhouse-type glazing bars?
SteamyTea replied to Surfdude's topic in Windows & Glazing
First Google hit https://www.palextrusions.co.uk/products/glazing-products/ -
Fridge Door Slider Kit - snog, marry, avoid ?
SteamyTea replied to ToughButterCup's topic in Electrics - Kitchen & Bathroom
Can you still put those important 'Welcome to Rhyl' fridge magnets on the door? -
And make your own bubble bath
That is where the VCL usually is. I don't actually think having a VCL in the right place, and then a final vapour proof covering attached will give any problems, as long as there are no leaks.
The term Vapour Control Later is a bit misleading. All it is, is a barrier to water vapour. So is imperious both ways. The concept is that the inside of the building (in UK) is warmer and has more water, by density, than the external air. By stopping the flow of this warmer, wetter, air from passing though to the colder, insulated cavity, there is less risk of dew forming. This reduces the chance of mould forming and causing problems. As you have a GRP roof covering, which is a good vapour barrier, in the outside, is there any ventilation space below?
Heat demand too low for Vaillant Heat pump?
SteamyTea replied to Ewan's topic in Air Source Heat Pumps (ASHP)
Thinking about this modulation a little bit. As an ASHPs performance is reduced when the external air gets colder, is the minimum modulation output a fixed amount i.e. 1.2 kW, or a percentage of deliverable power i.e. 20% of what it can achieve at the temperature. Quite often a supplementary heater kicks in and makes it look better than it really is. -
What is the aim here?
I think there are BMS packages that integrate into the CAD software.
In the scheme of things, I have spent very little time replacing lightbulbs and switched. I changed two single switched to one double one once. Think that is it. You probably need a screwdriver as well as a computer.
I use basic Raspberry Pi Zeros for as much as I can. They change the OS and Python version. Not a problem at the moment, but may well be in a decade or two. I did some work at Bletchley Park before Dr Sue Black took over. The guys there were all retired programmers (and very dull and unimaginative). I remember one telling me that he made a good retirement living doing work for the banks as he was there when they started to work with FORTRAN and they were still using it. All a heating system has to do is keep a building within set temperature limits, if you make those limits to tight, you will spend way too much effort on the control side. KISS
Cost/benefit analysis of different size of array
SteamyTea replied to Omnibuswoman's topic in Photovoltaics (PV)
Your SAP calculations, and double checking with Jeremy's spreadsheet should give you a good idea what the new place will use. DHW usage generally don't change much, not as if we move house and decide not to wash. Cooking will probably not change much either, I boiled potatoes for the same amount of time for the last 50 years, they taste the same. Why are you heating the DHW with an immersion heater and not a heap pump? -
I have never felt the need to know who is at the door.
I am with @Gus Potter I dislike anything that is over complicated. I have very basic E7 storage heaters, they have two controls, energy in, power out. Sometimes I adjust them. Below is a chart that shows this year's energy usage and temperatures. This year has been useful as we have had extreme (for UK) heat, cold and dryness (more solar gain). At the beginning of the year, I was away for a few days at a time a lot, I would turn all the power off and let the house do its things. This used less energy, but larger swings in temperature. Heating was totally off by the 14/03/2022 and did not come back on till 15/11/2022, so 119 days of heating and 246 days without. A quick look at the data shows that at the start of the year, the mean external temperature was 7.5°C and the house temperature was 19.1°C. End of the year mean external temperature was 6.3° (1.2°C lower) and the house temperature was 19.3°C (0.2°C higher). Energy usage was similar at less than 0.8 kWh/day difference, with the beginning of the year using less. When looking at the variation in temperatures, at the beginning of the year, the min and max external temperatures were 0.1°C and 15.9°C, with the house swinging between 5.2°C and 23.3°C (this was when I was turning everything off). The maximum power draw was 10.6 kW. So far this winter, the min and max external temperatures have been between -2.7°C and 13°C, with the house temperatures between 16.1°C and 22.6°C, maximum power draw has been 8.3 kW. Two proper temperature distribution would show what is happening better rather than the extremes.
Do you know your current usage profile, and will it change much in the new place? -
Have you taken the rusty covers off and made sure the heat exchangers are clear?
Sometimes, having a decision taken away is a good thing. One less thing to think about and pay for.
Which set point are they talking about?
SteamyTea replied to Radian's topic in Boilers & Hot Water Tanks
And now Matter is coming along, so another one to play with. Yes Captain Manwaring, an awful mess. Like people in a carpark. They get there by adhering to a few simple and well understood rules, get out their vehicles and, for some unknown reason, make up their own protocols about the best way to move about. -
I have just been to the Screwfix website, searched for central heating controllers. I can see why there is a problem. There is 104 different types. https://www.screwfix.com/c/heating-plumbing/central-heating-controls/cat831042#category=cat831042&page_size=100&page_start=0
