General question. How the the kVA limit enforced? Is it though hardware i.e. the main fuse blows, or though software i.e. the meter logs and reports over current? I remember having similar problem when we lived in France over 50 years ago.
As others have said, needs a lot more information about your house. How much insulation is there under the ground floor UFH? You also seem to have quite a large buffer tank.
Do you need eARC to enjoy Dolby atmos?
SteamyTea replied to Adsibob's topic in Networks, AV, Security & Automation
I always thought that ARC was Amey Roadstone Construction. If you have to pay extra for it, then definitely. If, it is included as standard, then it is probably something that makes no difference. -
At 3 and 5W, who needs dimming. I do have one of those lamps you tap once to turn on and then tap a second time to brighten, and a third time to brighten more. Came with an incandescent bulb that was way to bright. So went to the 'local lighting shop Volt, in Market Jew Street, and payed a fiver for a dimmable LED. That is still working.
An angle grinder is the second best tool you can have. Every household should have one.
So did I, all still good. The Kia of lightbulbs.
With a mighty circular saw in your hands.
While I think it is an odd rule, it is a bit like speeding. I do it a lot, thousands of times a year. Not been caught for over 20 years. I had a £270 fine and 5 Points that time. Just worth pointing out that within our own boundaries, you are not King of the Castle. So I hope you point out the planning rules to your customers, they could be a bit miffed at you if they had to take it down and ask for a refund, which you would refuse.
Heat demand too low for Vaillant Heat pump?
SteamyTea replied to Ewan's topic in Air Source Heat Pumps (ASHP)
Basically because of the mismatch between volume and low heat demand. Buffer, or volumiser, amounts to the same thing as long as right size for the demand. Like all heating systems, they need to be insulated so that the energy is distributed to where it was designed to be. Not some vague, 'well it all stays within the building'. -
Or Stand Alone Domestic PV Installation Limits and Conditions (Mounted within the grounds your house, block of flats) The effect on the external appearance of the building and amenity of the area should be minimised. The first stand alone installation only will be considered ‘permitted development’. The installation must not exceed a height of 4m at any point. The installation must be 5m or more from the property boundary. The array of solar panels may not exceed 9m2. Stand alone solar installations are not permitted within the grounds of a listed building or scheduled monument. If you live in a conservation area or in a World Heritage Site, no part of the stand alone solar installation should be nearer to any highway bounding the house than the part of the house that is nearest to that highway. If you stop using your system, it should be removed as soon as possible. https://greenbusinesswatch.co.uk/domestic-solar-panel-installation-and-planning-permission-england
Would that need planning permission because it is considered a ground mounted system? (the bonkers 9m2 rule and all that)
You will end up fitting one, so make space. And don't make the tank too small. -
Would be hard to disaggregate what is actually going though the walls/windows/floor/roof/doors and what is ventilation losses. You would also need to know how much has been absorbed by the air and the building fabric. There was a idea to do air leakage tests with a pulse of air, was that what you were thinking of?
What Centrica are try to do down here. https://www.centricabusinesssolutions.ie/knowledge-centre/ideas/matt-hastings-bbc-r4-battery-storage (slight disclaimer, I had to spend 3 years working with Matt Hasting)
Working over the festive period
SteamyTea replied to nod's topic in General Self Build & DIY Discussion
I am working, but not on a building site. Or I am up off upcountry as Mother is seriously ill again. Building something would be a relief. -
Easy enough to work out. Calculate the (leaky) area and volume. Divide volume, m3, by the product of the m3.h-1.m-2 and the area, m2. The thing that stops it being easy is that the leaky area and volumes of houses is different. So taking my house, which is solid floored and terraced and just comparing it to the end of terrace net door, for the same m3.h-1.m-2 @50Pa will give different numbers. Knocking up a spreadsheet quickly and it shows that at 1.5 m3.h-1.m-2 @50Pa, my house would have an ACH figure of 1.5 and my neighbours at 1 ACH. So care has to be taken if the m3.h-1.m-2 is used on its own and in isolation. Bit like U-Value for windows or walls. Great to have a low window U-Value, unless you cover all the walls in glass.
Biology is just a Latin test. I read a good book about epigenetics. Only thing I learnt was the Dutch went hungry and the reason it is so hard to make new drugs. Drugs need to be small molecules so they can pass through cell walls. Most of the useful small ones have already been discovered.
Not sure. Could be that one end of the WD (stands for water displacement) is small and attracts the water out of a hole, them wiggles it's way in. The other end of the molecule may be larger, so, though electrostatic forces gets drawn in. This will act as a wedge, causing the surface to swell. Guessing a fair bit here. I tend to avoid chemists. They have 20 words and just keep rearranging them.
Is that because WD40 displaces the small water molecules in the nylon and the gaps are replaced with the larger molecules of the oil.
