You need to work out the voltage drop over the distance and make sure it is within limits. <2% drop I think. Your electrician should be able to tell you.
When I said I was referring to planning law, no one gives a toss if it is made from platinum or dog turds, or worse, straw.
A big HELLO and a questions about insulation
SteamyTea replied to Otter's topic in Introduce Yourself
Was camping there in August '79, when the Fastnet boat race was on. My tent, along with several others, totally vanished. Was a terrible night and next day. -
Had you put the silicone treatment on the walls by then, or was that after? -
Surely planning is about legal technicalities, not emotions.
What does BA stand for?
The two go hand in hand as the dew point is related to temperature and pressure. You may find that a simple and cheap to run Air to Air Heat Pump will give you all the climate control you need They can warm and cool. Reducing sound transmission is much harder. It is a combination of absorption and decoupling. There are decoupling bars (resilience bars) for plasterboard, worth fitting them. It may be worth stopping for a few days and searching on here for suitable options. But basically, what you want to do is insulate, reduce ventilation losses, then control those losses. You could just give up exercise and spend all your free time on here with a beer and an ashtray. -
I used to work at the Royal National Institute of Blind People. They spend £100ks on lighting. We just turned them on to full power, and then off when we left. As the old saying goes, 'if you cannot measure it, it is not science'.
Do you have enough height to add insulation on top of the new screed? Thermal losses though a floor are constant, all year round. -
The general rule, in the UK's climate, is to stop warmer, humid air, that is inside the building, migrating though the insulation onto the colder surfaces. Depending on the types of insulation used, a vapour control layer is used on the inside, the warmer side, then the insulation, then an air gap for ventilation. The problems start if the cold air, in the air gap, can bypass the insulation. This makes the insulation a lot less effective as it, in effect, reduces the thickness. There are insulations that are called 'Full Fill' that can cope with being damp for a short period of time, @joe90 used it on his walls I think. There are roof system that do the same (warm roof). -
Easy to add 150mm of floor insulation onto that sand. -
I often drive past the Mitchell and Webber building. Could call in, I am sure they would we willing to tell me just how great it is.
Welcome. Insulation is really very simple. For any given material, it has a thermal conductivity, usually denoted as k or ⲗ. This is amount of power, in watts, that can travel though the material for a given temperature gradient. It is usually expressed as W.m-1.K-1. Dense brick is around 1.3 W.m-1.K-1. Mineral wool around 0.04 W.m-1.K-1. From that you can calculate the R-Value which is just proportioning the k value for the thickness. This gives the derived units of m2.K.W-1. Just a case of dividing the thickness of the material by the k value. So take a 100mm thick brick. 0.1 [m] / 1.3 [W.m-1.K-1] = 0.08 m2.K.W-1 Mineral wool at 50mm 0.05 [m] / 0.04 [ W.m-1.K-1] = 1.25 m2.K.W-1 All that is saying is for the same power transfer, you would can have an area 16 times greater for mineral wool than brick. It is more usual to use U-Value as that is more intuitive. The U-Value is 1 divided by the sum of the R-Values. It has the derived units W.m-2.K-1. U-Value [W.m-2.K-1] = 1 / R0 + R1 So 1 / 0.08 [m2.K.W-1] + 1.25 [m2.K.W-1] = 0.75 W.m-2.K-1 Doubling the thickness of the mineral wool insulation to 100mm. 1 / 0.08 [m2.K.W-1] + 2.5 [m2.K.W-1] = 0.39 W.m-2.K-1 Always worth making the insulation as thick as possible. There is nothing to stop you having insulation thicker on some walls and thinner on others, it all contributes to the overall losses. -
Warm exhaust air in the winter?
SteamyTea replied to TonyMorris's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yes. I think you are right. -
And the temperature probes wired in right. Also summer bypass not changed to winter. There is also the terminology, which is not that intuitive. I think Exhaust is the air leaving the room, not the room air being expelled out the MVHR unit, though I am never quite sure. -
Never again.
Where does the hydrogen come from?
What size pencil?
Realistically you are going to have to internally insulate the property, though you may be able to add some external insulation if you do not mind the looks changing. One advantage of adding insulation is that you can also tackle air leakage at the same time. There is the option of digging up the floor and adding 150-200mm of insulation, then under floor heating, but it is messy and expensive. As you already have a heating system, you can at least monitor how much energy it is using. This will inform you as to the sizing of any replacement system is needed. So start taking measurements, internal temperature, external temperature, daily oil usage, electrical usage, kg of timber burned. Which part of Cornwall are you in, it is a long isosceles triangle and the weather can vary along it quite a bit.
High boiler modulation after pressure loss
SteamyTea replied to Adsibob's topic in Boilers & Hot Water Tanks
Linear regression and RMS values. -
Was just getting wet when I past Bristol City 3 hours ago.
The Hideous. I am sure I could knock your wife up suitable.
