SteamyTea
    200
  1. My TOR webserver, which is free to set up i.e. needs no domain registered or a paid for hosting service, is proving to be very reliable. Not sure how well it would work with live streaming video, should be OK as it is relatively low resolution. All encrypted, many times, as well.
  2. Have you finished the ESP based energy monitor yet?
  3. Drive a stake tough its heart. Then bury cover down, under several tonnes of radioactive waste. Never want to see one ever again.
  4. AKA a wanker.
  5. I use mine to impress my neighbours. Make them think I have aa friend staying. Of course, the French only wear the lower half at best.
  6. I have had a Bosch Washer Dryer. The trick is to not use the dryer but spend 2 quid on a washing line and pegs at Poundland.
  7. For your next project, try some pointillism, then maybe work up to chromo-luminarism. Or just spend a week at Park Güell with a bag of drugs for company. Antoni Gaudí knew a bit about tiling. As does our @pocster, would set his OCD off bigtime.
  8. https://en.wikipedia.org/wiki/Four_color_theorem
  9. Could have tested it. https://sitn.hms.harvard.edu/flash/2018/pee-pregnant-history-science-urine-based-pregnancy-tests/
  10. I feel the icy hand of the ghost of SMP. Try plugging some of those questions into ShatPEE. Q; Two men are digging a 52 m tunnel from opposite ends, one digs at 10 m a day, the other at 6 m a day, what time does the cat put the kettle on?
  11. Beef and Dairy Network
  12. Yes they are. I think the DHT11, the blue ones, got the range a bad name. That is useful to know. I wonder that the ESP8266, which I have a few of, works down to reliably.
  13. Looks pretty comprehensive. The AM3202 is not known for reliability and accuracy, but I have used the 'sister' DHT22 with no issues. I even calibrated a few with the salt brine in a jam jar method and found them to be pretty good, unlike the DHT11 (the blue ones) that are very poor. How is that working out? My old powerbank was not delivering a high enough voltage, but it was very old and very, very cheap.
  14. Just down to @joe90 to move and build his new workshop. He is pretty quick at this building malarkey, so should be delivered within the year.
  15. Yes, leave the boot open. Short 120 miles from your new place to London. Almost suburbs of the smoke.
  16. @Adsibob could be persuaded to procrastinate for months. I will deliver them on one of my trips up. In the scheme of things it is just down the road from where my mother is.
  17. MDF is often used purely for the smooth finish. A couple or 3 coats of a decent undercoat often gets you to the same place on cheap ply. I think it is about time you started buying some power tools. A small cordless circular saw, a long straight edge, some G-Clamps and maybe a cheap multi-tool. Assuming you have a drill already. With them, you can make a lot of things, except accurate curves. Then you can put that shed to good use, drink tea, grow a grey beard and smoke a pipe.
  18. I boxed my cylinder in with a combination of PU sheet and mineral wool. Apart from making sure the cables to the immersion heaters are in free air, I did not worry about the thermostats. My thermostats are part of the element boss anyway. Insulation saves me about 2 kWh/day in standing losses.
  19. Picture may be useful. Maybe a 'spray mount' type contact adhesive. Superglue is pretty good as well.
  20. I made thick MDF shelves, not that long though.
  21. St. David's Day today. The 'neighbours' have even upset most of the English listeners by singing on Radio 4 FFS.
