The big phone switch over/off in 2025
SteamyTea replied to Temp's topic in Networks, AV, Security & Automation
The Daily Service is still on Long Wave, along with the cricket. No need to let them know that the Empire has gone, but we can still pretend that it is there, well here. Next week I am getting my tailor to make me a new suit, going to cost 6 pounds, 17 shillings and threepence farthing. Should be good as it will be 20°F in some places. I am off to the Lyons Tea House now. -
These VOIP phones, do they make every sound like a Radio 4 interview i.e. don't work reliably. Who was that journalist with the troops in Afghanistan in the early 2000s, the one on her satphone? -
Generally my modules are not earthed, or bonded. But, as the old saying goes, RTFM.
Free Grand Designs Live Tickets
SteamyTea replied to Gone West's topic in General Self Build & DIY Discussion
That would be a fantastic day. Except for being surrounded by complete, pretentious twats. Still, could ask them to explain 'thermal mass' and what sort of windows they want to be delivered 4 months late.- 1 reply
We should have installed air conditioning… now what?
SteamyTea replied to Adsibob's topic in Other Heating Systems
That is a good idea. Whether heating or cooling, they are still heat engines. The devil is in the demon. Most have settings that can be changed to deliver either hot or cold. -
All depends on what the mass flow rate to building volume is and by how much you drop the temperature. Just physics. I have often wondered why we don't fit larger diameter MVHR ducts. Be nice if the MVHR units, which is basically always running, could also supply heating or cooling for 90% of the year. -
Having not had a telly since 1994, I struggle with TV remotes. Too many buttons. My Mother on the other hand, does not have a problem. She can always find Midsomer Murders or Poirot. Volume is set at 11. -
I was just wondering what sort of certification you need to put windows into a new build. https://fensahelp.zendesk.com/hc/en-gb/articles/360059195914-If-you-haven-t-got-any-work-to-assess @craig, any idea? You can save a bit of cash by putting in a vented DHW system. They come in for some stick on here, but then a lot of people are from the 'combi boiler' generation, i.e. under 55. I agree with this Though some knowledge is needed i.e. installation/reference methods.
@Omnibuswoman Nothing to do with this at all, but was wondering what sort of MPG you get from your car, both running around locally, and on a long M4/M5//A30 run. It is one of the vehicles on my short list. To do with this thread. I hope you have optimizers on those PV modules, going to be a bit of shading on them, all year round.
One physical inverter can still be 3 Phase. I am sure it has been mentioned about putting the most effective (probably south the facing ones) onto the house phases that gets used the most during the day i.e. washing machine, hob, cooker, DHW, HP or car charger. It would probably take a half decent electrician 20 minutes to work out which phase has what on it, the rest of us maybe half an hour. Usually just a case of looking closely at the consumer unit.
My Great Uncle Colin was an engineer for Smith Industries. His hobby was clock restoring. He had a set of wall clocks that were synchronized to the 50Hz mains. -
Constance Cummings as a switchboard operator in "Looking for Trouble" I wonder how much heavy breathing she did. -
You have mentioned the inverter a number of times. Apart from a few different features, there really is not a gnats cock between them. Unregulated DC goes in, regulated AC comes out. They disconnect when they need to. The more important thing is how the modules are wired into it i.e. are the separate 'strings' within the inverters limits, is the inverter wired into the most used phase in the house, or in the case of 3 phase, is the largest/most productive string/s wired into the most appropriate phase (3 separate inverters is so much easier with 3 phase). Why I suggested that you do a simple sketch and state what you want the system to do i.e. help run the washing machine, charge the car, heat the DHW...
Who remembers SystemX? Shall stick with this. -
We had our roof at work repaired with something similar. I wish I had been there when the guy was doing it. Looks like he did a fine job. But it has not rained since. A good fall of snow is what is needed, then the thaw. But this is Cornwall, so like High Wycombe, just drizzle, with the occasional storm.
Had a girlfriend that must have worked for them, she turned them on all the time. (make of that statement as you will)
Inflation is killing my build
SteamyTea replied to farm boy's topic in General Self Build & DIY Discussion
Most of that will be spent at the start though, the 20% on the last small tin of gloss is neither here not there. Having run out of cash and had a failed business because of it, hoping/waiting for things to change is a killer. -
Folkstone and Dover Water Corporation.
(expletive deleted)ing Waste Water Cover Is it Flow Control Waste Cover? but in the wrong order. https://www.jdpipes.co.uk/products-and-services/surface-water-management/flow-controls-chambers
@patp Quickly sketch out what you have, and what you think it should be doing. Then post up. Hopefully we, as a collective, should be able to identify areas you need to ask about.
