SteamyTea
    200
  1. Should be called Search and Destroy.
  2. Not really. There are SI base units, kg, m, s and a few others. From those, you can make recognised units like newtons, joules and watts And from those, with a bit of mixing up, you get recognised units like kWh, So kg.m2.s-2 = J kg.m2.s-2 / s = kg.m2.s-3 = W kg.m2.s-3.3600 s = 3600 kg.m2.s-2 = kWh as there is 3600 seconds in an hour. In an ideal world, we would use joules for energy and watts for power, but somewhere along the line, someone thought it was a good idea to use the kWh. That in itself is not too bad. But, then it gets corrupted into nonsense units like Killa wots per our, which does not even make sense in English, let alone phyisics. Try the historical records on Weatherunderground. You can usually find a weather station within a mile. Some are better than others i.e. solar meter.
  3. I assume there are 3 pillars, and two separate 'triangles'. Apart from calling the power, energy, it seems about right. Actually it seems very good. Amazing how the losses soon add up the isn't it. Still 300W is not dreadful, a small fan heater on 20 minutes every hour.
  4. @JamesPa Useful list, thanks.
  5. Go skip diving. Or try B&Q. https://www.diy.com/search?sort=product.price&term=Kitchen+sink
  6. I thought my graveled (20mm granite) rear was a bit light at first. I soon got used to it, and it has darkened over the years.
  7. Generally, for 8 months of the year, PV can supply a normal 2 person household with all its DHW. Possibly for 5 or 6 months of the year, the PV will export as well. One has to ask if it is really worth the time, effort and complexity to save a few quid of imported energy. You could just look at a PVGIS hourly report and take the integral, 40% either side of the mean (around noon for most people with south facing PV). Then run things in that window. That window will vary about an hour a month, so you are adding or subtracting 30 minutes to each 'tail', but only during March, April, September and October, the summer can look after itself. I have cheap timers on my DHW and storage heaters. Think they cost less than 20 quid each, they are set up to lock out connection when it is unnecessary. A simple solution to a complicated and variable problem.
  8. All materials basically exist of nothing, the gaps between the electrons and the nucleus. It is the electron forces that stop the screwdriver just falling though the screw. I did see Prof Brian Cox explain that given enough time, though quantum effects, any object can move from one place to another. So rather than getting screws from a supplier, just wait long enough, and everything will be screwed. Got to be easier and quicker than self builder's pontification. This is worth a read. https://www.khanacademy.org/science/physics/quantum-physics/quantum-numbers-and-orbitals/a/the-quantum-mechanical-model-of-the-atom
  9. As above. They took your normal DD payment first, then put it right. Why I dislike Direct Debits, like leaving your card on the bar at a pub.
  10. Generally speaking, most domestic cleaning agents are an alkaline. That is relying on the reaction between a mild alkaline and a mild acid to make lots of bubbles, that may, or may not, dislodge a blockage. Nothing to do with a magical mixture that dissolves anything. The hot water probably does more good. As to why your pipes are distorting/softening, I really don't know. We had a cleaning product that was 95% water, it stained some stainless steels (but not others).
  11. It is really down to the difference between power and energy. Energy is power multiplied by time. To run a heat pump you need a certain amount of power, for a fixed time, otherwise you are importing the difference. This is basically down to having a delay between the HP starting up, and then delivering power. This is not so much of a problem with a purely resistive load like an immersion heater. These can take a few seconds of excess power, heat the water a bit, then shut down till the sky is clear again. The easy way to find out is to monitor every minute or so. Then work out how often the HP would, on average, be importing power.
  12. Right. Sorry to be finickity, units first. I think what you have is a 2.5 kWp PV system and you think you need a 4.8 kWh battery system. Do you currently have a hot water cylinder with an electrical immersion heater in it? If you do, diverting the PV power to that will be the easiest and cheapest way to store your energy. With a small system like yours, it should be possible to self use near enough all your power, have you monitored your energy usage to see what you actually use, and what is using it? Battery systems are all the rage, but remember that the most expensive, bought in electricity, is probably cheaper than current battery systems.
  13. I am sure I read on here that we were going to run out of energy this last winter. We didn't. Seems that coal usage was down as well, again. Edits by Mods to remove full article, provide precis and a link to the full article. "Europe faced an energy crisis six months ago when spiking gas prices, compounded by a once-in-500-year drought, threatened the continent with rolling blackouts and fuel shortages. However, the feared crisis never came to pass due to the mild winter weather reducing demand and high prices pushing energy users to cut back even further. The drop in demand also prevented a resurgence of coal, and renewables, particularly solar, stepped in to save the day. The rollout of renewables and energy efficiency measures is essential to ensure supply keeps up with growing demand, but the weather could still cause major disruption. Europe must bank as much gas as possible for winter, particularly if the summer brings another intense drought. Despite this, energy analysts remain optimistic that Europe won't face a similar situation to last year." (ChatGPT used to create precis, 04.04.2023) Link to full article here: https://www.newscientist.com/article/2366020-europe-survived-its-winter-energy-crisis-but-what-happens-next-year/
  14. His voice took advantage of quantum processes. As does your electric screwdriver. Not sure about Dr. Who's sonic screwdriver, that was just a wooden prop.
  15. After last night's storm, I would think all our beaches are out of bounds. Last week's comic mentioned Cornwall a lot, especially St. Agnes. https://www.newscientist.com/article/mg25734311-000-the-state-of-britains-rivers-slurry-silage-and-sewage
  16. I get all the physiological benefits of cold water swimming (which is just swimming really) from a hot bath. The only difference is that I don't park my car like a complete (expletive deleted). I was driving past Abbey Slip at about 9PM the other night, some bloke was just finishing his swim, car parked over two occupied parking spaces, which also reduced the road to a single lane. Swimmers down here are a menace.
  17. I seem to get it all year. But then I have allergies to anything that is non metallic and moves.
  18. Yes, hayfever has started
  19. Do you mean this stuff https://www.screwfix.com/p/tower-upvc-white-mini-trunking-25mm-x-16mm-x-2m/81974
  20. Do you want an autograph? On a ball
  21. On a football.
  22. Was that the couple of old ladies employing a design company with a CNC router.
  23. I did a reply to this, but just found out it was the wrong thread about 2D printed houses. Was from 2017.
