  • entries
    20
  • comments
    124
  • views
    24889
About this blog
Getting started at last
Like a good few people on the build hub it's taken us a while to get to the point where we are finally breaking ground. We now have the diggers arriving the week 11/02, so time to get blogging.
I'll start by providing some background and project overview. We'll update the blog as we progress.
We started well over a year ago, kids grown up and house more than we needed, and both with no intention of ending up in sheltered accommodation. Fortunately for us our existing house is on a corner plot with a large detached garage providing an opportunity to build a small house without detracting from the original house. We want to future proof the house as far as we can.
Having played with the idea for a number years we started to actively look at what we could achieve. It was not long before we came across the concept of passive housing. We ended up speaking to PH15 and to Zero Bills (Zed Factory). PH15 do passive house timber frame solutions, had a really good feel about the organization but quickly realised they were talking much bigger budgets than we could manage. After a visit to the building research establishment (BRE) and a look at the Zed Factory house there we decided to take a look at that route. ZED provided either a shell or turnkey solutions, both of which were within our budget. The cost per square metre in the ZED literature at BRE indicated a very competitive turnkey price in the region of £1,350 a square meter. As with all things the low price came with compromises as it was a “cookie cutter” solution and finish was not all that we would have liked. We had a meeting with ZED, to talk about what we wanted. It quickly became apparent that the “small changes” we would have liked came at a very high price pushing the cost per square metre to £1,6434 which is in the region of 40% higher. Some of the additional cost were also high, for example £7000 for preparing tender documentation, £4500 for planning documentation and £5000 for building control drawings. All in all a deflating experience, got the impression that ZED are structured for big developments not the self builder.
We took a while to get over the disappointment of the ZED negotiation and ended up going to a self build show a couple of months later at Bicester. It was a good show and we came across MBC who had a small unassuming stand, one technical guy and a very satisfied customer. After a long chat we realised we could achieve our build for our budget and get a house designed for us rather than generic build.
Planning permission was the next big hurdle. We had spoken to our neighbours over the years about the opportunity to build on our plot to replace the garage with a small house, they had not raised any objections. At this stage we used Sketchup to model a couple of designs and engaged with the local planning department pre-planning process. This was very useful as it allowed us to establish what would and would not be considered, basically set the boundaries for us to push. We came away from the process with the knowledge we could probably build but not necessarily on the scale we wanted. At this point we found a local architect and started the design process and the subsequent planning approval process. The design process is a odd one, conflicting interest between the architects creativity and what you want to build and can afford. It's certainly a phase that having done once you are a lot wiser. Not a disastrous relationship but a very frustrating one. In any event after a couple of iterations with our planning officer we reached a point where we could submit a planning application. I'll not go into the problems we faced in planning other than to say it's arcane and the neighbours who were supportive at the start now raise issues with bat flight paths, ancient privet hedges and many more distractions. In any even after going to committee twice we finally got approval.
At this point it should have been simple order the MBC kit...enter the build hub. Having done a bit of reading on construction techniques and their problems we decided to take a look at ICF as it was comparable in price with timber frame without some of the long term problems that timber frame can face with external water ingress. More research looking at ICF block led us to JUB who had a “no cut on site solution” which appealed. The block are not flat pack and have substantial webbing which should reduce the risks of bulges and leaks when the concrete is cast. Having selected a brick the next problem was to find a builder. Not as simple as we would have thought as builders who use ICF are would appear in the main to be in exclusive partnership with the a block manufacturer. In the end we went with “Intelligent Building Solution” a firm with considerable ICF experience who are based in Glasgow.
JUB ICF:
The web site literature for JUB sells the blocks as a well established solution. JUB have integrated raft, wall roof and render systems which should minimise compatibility issues.
It was not long into the process before we discovered from sources other than JUB that they had not built any houses in the UK. The bricks are in use in Europe but mainly in off the peg solutions, in the UK it's being marketed as a solution that can build pretty much any house you like within a 75mm of your design. The marketing support for the blocks is best described as tentative, having nothing to base there quotes on. We had expected them to be keen on getting a build under way but getting a competitive price was not straight forward. At £79 per square meter for the 390mm blocks and £58 for the 300mm blocks put it toward the high end for ICF. What I will say in their favour is that the technical support has been excellent. We are now dealing direct with the JUB technical guys in Slovenia and they are being very practical and helpful.
Structural calculations:
One problem you face with the JUB solution is that the block plan can alter the build dimensions, not only by the 75mm figure but also to simplify wall interfaces. The result is that you have a bit of a “chicken and egg” dilemma with what order you get things done in. We opted to get a first pass on the ICF block layout and use this as input to the structural engineers. This has worked out well with only minor rework of the calculations and amendments to block layout.
As far as finding a firm to do the calculations, our builders warned us to go with a firm who were familiar with ICF to prevent over specification of the steel in the structure. We ended up getting in three quotes and decided on Tanner Structural Design a firm used by others on the buildhub. Not having any experience of the process it was most refreshing to deal with Tanners. I have no reservations recommending them, their communication was excellent and they were happy to take external input into account.
Insurance:
We wanted to get build insurance. JUB recommended BLP. We got quotes from Advantage, Aedis, BPL, and Global Home Warranties. We wanted to combine the warranty with building control as we figured this would get the best result for us on the basis “if your going to provide insurance it's in your interest to make sure it's built properly”. BPL provided a very expensive quote so have been ruled out. Aedis put additional liability on the builder which may discount this option. It will be interesting to see just how usable the service turns out to be.
Windows:
This proved to be a decision that consumed a lot more time than anticipated. Who would have thought there would be so many manufactures out there, spoilt for choice I think is the expression. The build hub proved a very useful source of information and advice. We very nearly went with Rhino who make a very competitively priced double glazed aluminium solution. In the end we went with triple glazed windows from Velfac which rather stretched the budget but we felt would pay back in quality of living/comfort.
Site soil survey:
This was a new area to us like so many when you come to self build. In order to do the raft foundations design the structural engineers needed us to get site soil test done. We duly got in three quotes, the cost was a complete surprise as it was not an item we had budgeted for. Professional fees of over £800 for an engineer on site for the day, sample holes, and reports drove the figures close to the £3000 mark. A bit of research opened a whole new world of soil plasticity. We contacted our structural engineers to establish what they required and they were happy with the soil plasticity figures. More digging and we found a firm Ashdown Site Investigation who provide site survey and laboratory services. They were happy to do sample analysis and only charged £35 for each sample. We dug a hole 1200 deep taking 1kg samples for each layer, in our case there were just four pretty well delineated layers. We bagged and labelled the samples with their depth from the surface and sent them of for analyses. A week later we had the information required to do the structural calculations.
Entries in this blog
Finishing off
It’s been over a year since we got our completion certification and we’re still mopping up tasks in the garden and generally cleaning up. It occurred to us that some aspects of the discovery process of the build may be off use to others on BuildHub.   It’s too hot in here: Thermal modelling limitations. Our thermal modelling done as part of the design stage SAP suggested we had minimal thermal gain problems. However we suspected that thermal gain from our east facing windows would
Simon R
Simon R in Finishing off
Done and dusted!
Building controls have issued our “Completion Notice” a big milestone for any self build and definitely called for a celebration. A big sigh of relief from both our councils building control and us.?   Our many thanks to all the contributors at BuildHub, we certainly could not have done it without the support of the forum members. Particularly Jeremy Harris @Jeremy Harriswho’s broad knowledge and good advice...goodness knows where he’s disappeared to but the forum is a poorer place wit
Simon R
Simon R
In at last!
In at last! Building controls came out and checked the site and have issued a “temporary habitation certificate”. Big sigh of relief especially for a self build where you’ve been the main contractor.   Lots of bits and pieces jobs, as you would expect at this stage of the project. Adding stairs to second floor, making lights work, finishing off bathrooms, the last bits of flooring etc… it’s a long list but getting shorter by the day helped by being on site.   The stairs are a
Simon R
Simon R
The end is nigh
We’re getting there! flooring, kitchen and stairs, just bathrooms to go. It’s great to see it all taking shape as the finishing jobs get done. Not that it’s all gone to plan.   The first job we tackled was to get the floor down. We wanted to get it done before installing the kitchen rather than having to work around the units. As the kitchen is part of the open plan living area on the first floor it meant doing the whole area some 70m2. It’s a lot of flooring and we needed something th
Simon R
Simon R
Window dressing
After a slightly odd but pleasant summer on our narrow boat we returned to site at the beginning of the month to resume work.   We started with a simple job, putting our doors. We had done one last spring and had four more to do. It’s a simple and rewarding job, the Horman doors have a very solid feel to them.   Next on our work list was completing the window reveals, a task we had started back in May and had completed two windows. While we were still fresh we had decid
Simon R
Simon R
Twiddling our thumbs
With the lock down continuing it’s been hard to keep our enthusiasm levels up without the required supplies to continue any major projects. It’s been a case of “what can we do today” picking off tasks.   The gas boiler needed to be plumbed in, nice easy job as screwfix and toolstation were operating click and collect. Good to get a job ticked off.   Our electrics had got to pretty much second fix stage, so we ordered an 12 way RCBO consumer unit, sockets and isolator switches
Simon R
Simon R
Fenced in and painting
Following on from the plastering work we did a quick stock take. Our plan was to be back on our narrow boat for the summer but with the current problems that was out of the question. We didn’t have materials to start flooring or fit bathrooms or kitchen and there was little hope of getting them. After a bit of head scratching and phoning around we found we could get fencing material and paint. We also had a few other jobs on the list that we could tackle, commissioning the water harvesting syste
Simon R
Simon R
We're plastered
Well it’s been an exhausting and rewarding three weeks. The plastering work started on the 25th February and finished today the 18th March. Keeping ahead of Shaun our plasterer has been a real challenge and has meant we have not had a day off.  Our internal doors arrived from Germany intact which was a welcome diversion, we've stored them safely in the garage until we get the painting done.   The heat and humidity that goes with plastering has been interesting to say the least in
Simon R
Simon R
The plasterer commeth....
In my last blog entry we had done the majority of first fix and were about to tackle the lighting circuits. We had intended to do this in the conventional ring and switch runs. Reading up on our options it soon became obvious this was not the best option and that running radial circuits made much more sense. A radial approach will let us install led drivers and any automation in a central area for ease of maintenance and to allow us too upgrade with wi-fi switches at some point in the future. In
Simon R
Simon R
Getting started again- MVHR, first fix
After a summer spent cruising the canals we arrived back on site with a little trepidation and a lot of enthusiasm.   When we left the build we had just got the scaffold down and had a lockable water tight shell,. Well almost water tight, we still have two leaks. One where our roof lights join and another on a roof seam that abuts the wall on the house gable. Fortunately neither were bad enough to have caused any damage over what has been a pretty dry summer.   The internals
Simon R
Simon R
Scaffolding down - windows in
Scaffold down and windows in...big dose of euphoria....feels like a real milestone. We can now get a sense of the completed project. With the scaffold removed the house now looks far more suited to the plot and we hope our neighbours will be as relieved as we are. The window install went well. Our windows are Velfac and we opted to use an approved installer as it extended the warrantee to six years. It cost a bit more but the standard of install was good with great care being taken. A
Simon R
Simon R
Standing seam roof
Since our last entry we've been concentrating of getting the standing seam roof covering on. It's one of those jobs where it would be nice to do someone else's roof before doing your own. We're using a roofing system from Blacho Trapez, broadly similar to the Tata colourcoat.  It requires no crimping and minimal special tooling. It's around half the price of Colorcoat. The HPS200 coating we chose comes with a forty year guarantee. Our first impressions is that it's a quality product that's
Simon R
Simon R
Schedules...what schedules?
Lies, damn lies and building schedules! Where does the time go! it's been a month since the roof was started a process that should have taken a week...and we're only just ready to put the standing seam roof panels on a month later. More on the standing seam roof in my next blog. At the time of my entry we were trying to find a roofing team to finish the work. The team drafted into build the roof had had to return to Glasgow to meet other commitments requiring our builder to find anothe
Simon R
Simon R
Putting the lid on
With our final concrete pour over last Friday, we breathed a sigh of relief. The worst of the messy work was done and it we could start work on the roof.   It was a heck of a week and loads got done, on a very busy and noisy site. Good for us but not for our neighbours. It’s a problem every build faces, maybe worse for a self build where you have known your neighbours for years and been on good terms. We’ve done what we can to keep noise down and not to work antisocial hours, but somet
Simon R
Simon R
Three pours down..none to go - thank goodness
We’ve just done our final concrete pour, in fact two pours in one week. From ground floor to gables in two weeks with Easter in the middle is quick, a little too quick to enjoy. We can now get a real sense of how the house will look. Next week we are ready to start work on the roof.   Before building the first floor, a temporary floor was laid around the room perimeters using 12mm OSB. This was done to provide a working area to build the blocks from and allow bracing to be put in
Simon R
Simon R
First concrete pour done and scaffolding up
Well, it’s been a month since my last blog update. We've witnessed out first concrete pour and now have floor joists so we are all set to build the next floor. The bracing plan we have from JUB looks like we have the potential to pour the second floor and gables in a single  pour. This is a decision I'm only too happy to leave to the builders who continue to impress us with their ability to get on with a job regardless.     In my last blog we had got on really quickly and ha
Simon R
Simon R
Blocks delivered and we're up to the first floor
It's been a week of mixed emotions, we've made good progress on site but hit our first major budget overrun. First the good stuff, blocks got delivered on Monday. JUB will only ship them on pallets which sounds OK but in practice, but causes several problems on site. For a start we didn't have a fork lift on site and fork lifts don't tend to do well on soft ground. In the end we got in a tele-handler for which a single days hire is a significant cost. It should have been a small unit, but i
Simon R
Simon R
Raft delivered, conrete poured and rocks in the road
Bang on schedule the raft components arrived on Monday morning. We knew it would be quite a big volume of material on a small site and getting it unloaded and put somewhere it would not get damaged or need moving was s little tricky. JUB insisted on sending the raft on pallets. Our builder was not that impressed with this as unloading the lory requires a folk lift which is something we don't have on site. So we had to hire a set of folks for the digger. With the raft safely stored at the back of
Simon R
Simon R
And we're off
The firework instruction phrase "light the blue touch paper and retire to a safe distance" comes to mind.  It's been a real baptism of fire, however our builder says it's the worst time and it should settle down now.  All in all it's been a productive week and almost all work has moved us forward.   The digger arrived to dig out the raft area at 8am as requested and work got under way. We had muck lorries scheduled for Tuesday and it quickly became apparent that we did not h
Simon R
Simon R
Almost ready to start
Well with just days before we start we have our house block plan. All the bricks have ID's so all we have to do its put them in the right places.   The blocks are coming loaded on pallets, each with it's own manifest. The scale of the kit is a bit daunting and having done my bit of Lego with the kids in the past I can't help remembering the fun of looking for that special brick that seems so illusive. Fingers crossed we don't end up with one left over after the last concrete poor.
Simon R
Simon R
