February 8, 20197 yr A question asked from a state of ignorance! What distance should there be between the brackets that support guttering?
February 8, 20197 yr Whatever the manufacturers spec states would be a good starting point. I fitted rainclear aluminium clic system which asked for 750mm centers. You need more brackets than you think as the snow loading can get pretty high.
February 8, 20197 yr https://www.guttersupplies.co.uk/guides-and-tips/gutter-installation/your-questions/how-far-apart-should-fascia-brackets-be-installed/
February 8, 20197 yr Just picking up on @PeterW's comment in your other thread, I've used two types of Floplast gutter and on both needed to trim the edge off the actual gutter to get it to fit in the plain brackets/union brackets. Beware.
February 8, 20197 yr One thing we got wrong was the gutters, that I need to get around to replacing this spring. Our roof pitch is 45° and the combination of that and a large area of in-roof PV panels means that heavy rain seems to come off the roof in torrents, which then overwhelms the standard half round gutters and spills over the edges. I plan to replace the standard gutters with the deeper/wider high flow rate one, just to stop them from spilling over in heavy rain.
February 8, 20197 yr I think it depends on the manufacturer guidelines but I've set mine at 900mm for Brett Martin Prostyle 106mm on a 32 degree roof. Incidentally these seem to have a pretty high capacity for a given width and seem really well made.
February 8, 20197 yr 30 minutes ago, JSHarris said: One thing we got wrong was the gutters, that I need to get around to replacing this spring. Our roof pitch is 45° and the combination of that and a large area of in-roof PV panels means that heavy rain seems to come off the roof in torrents, which then overwhelms the standard half round gutters and spills over the edges. I plan to replace the standard gutters with the deeper/wider high flow rate one, just to stop them from spilling over in heavy rain. Yes I was working on two selfbuilds for friends and they were having the same issues with summer storms I’ve used a deeper cutter Only slightly more exspensive But seems to be ok
February 8, 20197 yr 35 minutes ago, JSHarris said: One thing we got wrong was the gutters, that I need to get around to replacing this spring. Our roof pitch is 45° and the combination of that and a large area of in-roof PV panels means that heavy rain seems to come off the roof in torrents, which then overwhelms the standard half round gutters and spills over the edges. I plan to replace the standard gutters with the deeper/wider high flow rate one, just to stop them from spilling over in heavy rain. just a thought but I have seen same problem when gutter is fitted to tight to end of slates and a bit low ,so when water comes off roof in downpour it nearly shoots over the outer edge . some roofs are built with a different shallower angle for last couple of slates or even just the last slate to slow it down the water for that reason . there is a name for it ,but i can,t remember it at this time .old age
February 8, 20197 yr I think we need to change our thoughts on rain, I think we will be getting more heavy rain, unlike the drizzle normally associated with England. A thing to look out for is how many outlets, normally never enough and the gutters start to struggle i think the norm used to be one outlet every 6m.
February 8, 20197 yr Going back to bracket spacing I always go 600mm, I hate saggy guttering, causes all sorts of problems and looks rubbish, brackets are cheap. I also hate guttering that creaks in the sun when warming up, then creaks when it clouds over, I always shave a little off the back of the guttering where it goes into a bracket so its not too tight and can move to take up expansion.?
February 8, 20197 yr 3 hours ago, joe90 said: ... I always shave a little off the back of the guttering where it goes into a bracket so its not too tight and can move to take up expansion. Has this worked? In the past I was not sure if the creaking was from the fascia board.
February 8, 20197 yr 23 minutes ago, epsilonGreedy said: Has this worked? In the past I was not sure if the creaking was from the fascia board. Oh yes, particularly black guttering that heats up in the sun, most gutters are tight in the brackets and the creaking is the guttering expanding and “clicking”as it tries to slide through the bracket.
February 8, 20197 yr 3 hours ago, joe90 said: Going back to bracket spacing I always go 600mm, I hate saggy guttering, causes all sorts of problems and looks rubbish, brackets are cheap. I also hate guttering that creaks in the sun when warming up, then creaks when it clouds over, I always shave a little off the back of the guttering where it goes into a bracket so its not too tight and can move to take up expansion.? Anyone used the black guttering with white internal to help with the problem of expansion?
February 9, 20197 yr 13 hours ago, Vijay said: Anyone used the black guttering with white internal to help with the problem of expansion? Yeh I fitted some 2 weeks ago on garage. I thought it was a cheap foil on outside but the bloke explained this was the reason. Never had a problem with gutter expanding so can't see the point.
February 9, 20197 yr 19 hours ago, Russell griffiths said: I think we need to change our thoughts on rain, I think we will be getting more heavy rain, unlike the drizzle normally associated with England. A thing to look out for is how many outlets, normally never enough and the gutters start to struggle i think the norm used to be one outlet every 6m. which on most builds will mean a down pipe at each corner of the building with be fine,maybe an extra one in the middle someone will have a roof area calculator /gutter size spread sheet. If they have would a handy post as a "sticky"
