jpinthehouse Posted February 20, 2018 Posted February 20, 2018 It's probably been mentioned before, do you need a specific log burner when mvhr is installed Thanks
PeterW Posted February 20, 2018 Posted February 20, 2018 Depends on the output as it will need to either have an external air feed or a decent flow rate into the room you have the stove in.
ToughButterCup Posted February 20, 2018 Posted February 20, 2018 Lets make this easy @jpinthehouse but painful. Forget the stove. Just a bit of research on this site will save you the expense of a stove. I know, I know, it hurts. I love them too. Ian
Simplysimon Posted February 20, 2018 Posted February 20, 2018 recently speaking to a knowledgeable source on passive houses, he has seen a small, 2kw, stove work well, in passive with mvhr. needs ext air supply
epsilonGreedy Posted February 20, 2018 Posted February 20, 2018 43 minutes ago, PeterW said: Depends on the output as it will need to either have an external air feed or a decent flow rate into the room you have the stove in. I thought Log Burner + MVHR = External Air Feed Only? Wouldn't any room aspirated stove cause so much air leakage it would upset the MVHR air exchange balance.
PeterW Posted February 20, 2018 Posted February 20, 2018 Only in a very tightly sealed house - if you go airtight then you do need some sort of feed as BRegs irrespective of the MVHR issue once below a certain limit.
billt Posted February 21, 2018 Posted February 21, 2018 (edited) 11 hours ago, recoveringacademic said: Lets make this easy @jpinthehouse but painful. Forget the stove. Yes. We've got 3 plus a coal Rayburn (our house needs heating) and they are almost unused - one was lit twice this winter. They are messy, wasteful of space and will almost certainly overheat your rooms if you have reasonable insulation, when run hot enough to minimise pollution. Although I understand the appeal I'm completely bemused by people with near passive houses insisting on installing them. (And they're stupidly expensive for what they are!) Edited February 21, 2018 by billt 1
epsilonGreedy Posted February 21, 2018 Posted February 21, 2018 10 hours ago, PeterW said: Only in a very tightly sealed house - if you go airtight then you do need some sort of feed as BRegs irrespective of the MVHR issue once below a certain limit. Ok fair enough, I am still on the nursery slopes of my self build learning curve. I was planning to design in a through the floor air feed for my wood burner before my build commences. If, to guess a number, I can get my brick & block, concrete beam floor house down to a score of 5 for air tightness i.e. twice as good as current building regulations, would a sealed stove with an external air feed be a wasted endeavour?
PeterW Posted February 21, 2018 Posted February 21, 2018 You can get a decent build down to a very low score just with attention to detail and a few rolls of airtight tape. Windows and doors are your problem, as are any service penetrations. The problem you will face is the stove will dictate the location of the vent - some have below, some have rear entry vents. You may need to decide that first. 1
epsilonGreedy Posted February 21, 2018 Posted February 21, 2018 27 minutes ago, billt said: Yes. We've got 3 plus a coal Rayburn (our house needs heating) and they are almost unused - one was lit twice this winter. They are messy, wasteful of space and will almost certainly overheat your rooms if you have reasonable insulation, when run hot enough to minimise pollution. Although I understand the appeal I'm completely bemused by people with near passive houses insisting on installing them. (And they're stupidly expensive for what they are!) I have only frequented this forum for 3 weeks and it is becoming apparent that solid fuel heating is the closest this forum gets to a political schism. 1
Cpd Posted February 21, 2018 Posted February 21, 2018 3 minutes ago, epsilonGreedy said: I have only frequented this forum for 3 weeks and it is becoming apparent that solid fuel heating is the closest this forum gets to a political schism. Imagine if you were an ipad user with a wood burning stove and a dirty landrover...... devil incarnate..... 1
epsilonGreedy Posted February 21, 2018 Posted February 21, 2018 6 minutes ago, PeterW said: You can get a decent build down to a very low score just with attention to detail and a few rolls of airtight tape. Windows and doors are your problem, as are any service penetrations. This is encouraging to hear and I hope air tightness is where a rookie like me can make a difference by prowling around after 5pm with an array of sealant guns. I cannot find public domain info covering airtight techniques for conventional brick & block designs. 9 minutes ago, PeterW said: The problem you will face is the stove will dictate the location of the vent - some have below, some have rear entry vents. You may need to decide that first. Indeed. I am already discovering that apparent late stage build events need to be designed in detail before foundations are poured e.g. adopting a wall hung toilet design can move an upper floor soil pipe exit by two feet which then means an inconsequential casement window in the room below needs to shuffled a few bricks left or right but oh no that puts the window aperture too close to a 90 degree turn in block work.
PeterW Posted February 21, 2018 Posted February 21, 2018 13 minutes ago, Cpd said: Imagine if you were an ipad user with a wood burning stove and a dirty landrover...... devil incarnate..... Well that’s me and a few others going to somewhere warm when we shuffle off this mortal coil The issue is when you have passive level insulation and an over size WBS - the heat has nowhere to go.
Cpd Posted February 21, 2018 Posted February 21, 2018 Yes i really like the idea of putting a really small wbs in the cottage, there was an open fire for years and then a big wbs but with all the improved insulation and future ufh the need becomes one of fun rather than function. I know we have talked this subject to death but..... due to my remote location and my caveman instincts i am still going to fit one. Finding the “right” small stove will be the challenge...... i will be sitting there overheating... reading about how to repair my fuel guzzling landrover on my iPad. 1 2
ProDave Posted February 21, 2018 Posted February 21, 2018 I think the real issue with a WBS is you cannot turn them off instantly. Perhaps people stoke them up too much to get nice dancing flames then find out the room is hot enough but you can't just turn it off straight away and by the time it runs down, you're too hot. The issue with a passive house is it then takes a very long time indeed to cool down again.
Lesgrandepotato Posted February 21, 2018 Posted February 21, 2018 I think part of the problem is if you are used to an open fire is desire to keep stoking and feeding it. We have our heating profile for the upstairs lounge without and evening boost as we use the stove. That said we have a smallish stove (6kw) in a decent room. 36sqm. We can run that without boiling ourselves for an hour or two with ease. Why? We like the flames and we live in a wood.. 2
epsilonGreedy Posted February 21, 2018 Posted February 21, 2018 23 minutes ago, PeterW said: The issue is when you have passive level insulation and an over size WBS - the heat has nowhere to go. I have a cunning plan for heat dumping, they are called opening sash windows. Trouble is that will confuse the MVHR system and now I am worrying that my house will go critical, will unstable isotopes emitted up the chimney from my wood burner get caught in the EMF field of my racing MVHR system and trigger nuclear fusion?
Bitpipe Posted February 21, 2018 Posted February 21, 2018 1 hour ago, Cpd said: Imagine if you were an ipad user with a wood burning stove and a dirty landrover...... devil incarnate..... Never mind fluffy towels and passive cat-flaps. 1
Nickfromwales Posted February 21, 2018 Posted February 21, 2018 42 minutes ago, epsilonGreedy said: I have a cunning plan for heat dumping, they are called opening sash windows. Trouble is that will confuse the MVHR system and now I am worrying that my house will go critical, will unstable isotopes emitted up the chimney from my wood burner get caught in the EMF field of my racing MVHR system and trigger nuclear fusion? "eureka, Marty! We'll just open the windows" So, to clarify, its cold, in your low-energy house, so you light the stove and then open all the windows to get the smoke and heat out? 2
Woodgnome Posted February 21, 2018 Posted February 21, 2018 "This is encouraging to hear and I hope air tightness is where a rookie like me can make a difference by prowling around after 5pm with an array of sealant guns. I cannot find public domain info covering airtight techniques for conventional brick & block designs." if you are trying to seal tbe house with sealant the horse has already bolted. Airtightness needs to be planned from the start of the build. Google " Denby Dale passive house" or " Golcar passive house" or " Tonys house" lots of info on traditional block and cavity build and how to make them airtight. 1
HerbJ Posted February 21, 2018 Posted February 21, 2018 I believe "Denby Dale passive house" or " Golcar passive house" are houses constructed by the Green Building Store - https://www.greenbuildingstore.co.uk/. Their website is very informative and includes blogs on these builds
joe90 Posted February 21, 2018 Posted February 21, 2018 Well I have built a well insulated, airtight ( I hope) newbuild with a small wood burner that has a dedicated under slab air feed pipe. Yes it may get a bit warm for me but never too warm for SWMBO?
epsilonGreedy Posted February 21, 2018 Posted February 21, 2018 16 minutes ago, Nickfromwales said: So, to clarify, its cold, in your low-energy house, so you light the stove and then open all the windows to get the smoke and heat out? Not quite The starting point is no mains gas, a garden that will not accommodate a regular LPG tank and a dislike of oil heating having lived with it for 4 winters. Cooking via LPG. From a social perspective the happiest occasions in the last few years have been centered around an open fire with for example the grand daughter staying overnight and playing with her dolls house. My current tentative heating design will be based on a 250 l thermal store connected to economy 7, a wood burning stove/boiler and an lpg gas boiler for urgent top up. On a typical working day a brief 6 am central heating blast should bump the house temperature up to a tolerable 18 degrees. At 4 pm the residual thermal store heat should be enough to warm the house then at say 7pm we can elect to fire up the woodburner stove or rely on LPG heating top up if it is a mild day. My concern is heat regulation on those freezing deep winter weekends. If OH gets carried away with stoking the stove then after a long burn the stove's boiler water circuit might struggle to shed heat. I hope that with sufficient water volume the system will not be too thermally spikey. My current guess for total water volume is 200 + 70 (rads) + 25 (pipes), that should soak up a lot of heat and then there are those sash windows.
Woodgnome Posted February 21, 2018 Posted February 21, 2018 7 minutes ago, joe90 said: Well I have built a well insulated, airtight ( I hope) newbuild with a small wood burner that has a dedicated under slab air feed pipe. Yes it may get a bit warm for me but never too warm for SWMBO? Are you ready for your air test yet John?
