21 minutes ago, ProDave said:
It was probably mentioned on page 22, but how will you get under that bath now if you need to?
Side access:
20190101_191055
End access:
20190101_191112
Push comes to shove the "room" side of the bath surround can separate if I break two tiles and split the tanking tape (the darker blue patch).
5 minutes ago, pocster said:
Working on New Year’s Day ! A sin surely ! ?
I recall a very disturbing live performance of It's A Sin by the Pet Shop Boys in the late 80s at Wembley Arena! :)
I’m not familiar with that ; but can only imagine them tiling in a provocative manner!!
1 hour ago, newhome said:
How many tiles to go? Or bits of.
Really? I've just sat down to watch Law & Order! :) Hang on...
Edit: About 50, pretty much all cuts. 8 out of that lot cut/whole & ready to go on when I next mix up.
Edited by Onoff
That's them all nailed down. Couple of oversize joints but hey ho! "Proper" tiling can recommence!
20190104_221855
20190104_222036
  • Like 2
@Nickfromwales, I'm applying "your" method here that I used in the pockets. Laser line with the tiles upside down to mark them. Set on  the yellow 1mm shims.
Once stuck on do I:
Clear CT1 to be run into the 1mm gap then a white silicone bead
OR
Grout along with everything else then the silicone bead?
2019-01-05_03-17-16
Cheers
Fill the bath with water and grout.
Leave it full until the grout has cured then empty it.
Wipe all the grout dust off, and give the lot a good polish. Get your silicone gun out and do all the internal angles until your happy.
Bingo chuffing Bango. ??
  • Haha 1
16 minutes ago, pocster said:
As @Onoff you near the end of your biblical quest - what mountain will you climb next ?
Noooo please @Onoff that quest must be tiling related - you need to do another bathroom this thread is too good to close ?
2 hours ago, newhome said:
Hey you lot - don't jump the gun! I'm sure @Onoff can drag this out for a good while longer :)
He might put up photos of every grout joint ... ??
  • Haha 1
