Just got a few tiles cut ready for a big push! :)
At some stage I've to tile the narrow "shelf", the width of the wall with a mosaic upstand. Tbh this bit was always planned to be tiled so I didn't pay too much attention when plastering along here.
20181116_235934
20181116_235945
I forgot to leave the bottom of the white wall where the mosaics are, unpainted. It's mrpb painted with Leyland Super Leytex. Should I scuff this up or sand down etc pre tiling?
Cheers
Edited by Onoff
Going to get some on today!
But will it look right @Nickfromwales, not having a full square at the bottom of the mosaics? Doing it "your" way as in backs on first.
2018-11-17_11-41-48
1 minute ago, newhome said:
Matches what you’ve got in the other pockets though surely?
Yep I thought that. Sill tile covers about 50% of a square:
20181111_172827
One awkward tile to cut then mixing up 'n layin' some! :)
Mosaics all look good. ?
Go get ‘em tiger ? ?
Ta, but do I scuff up / sand off the paint on the mrpb where I want to tile?
Nah, just go to something that’s not water based so the paint doesn’t soften. CT1 / Sika etc will be fine. Don’t forget to fit the top trim whilst the goop is still ‘wet’.
That seems a lot of work and not a lot to show and yes, they are long nose mole grips:
20181117_174845
There's a bit of ply these grey tiles sit on. It's covered in duct tape. Once set it comes off and the trim goes on to the tile edge.
20181117_174932
13 minutes ago, Nickfromwales said:
And then “Space, The Final Frontier.........” aka the compound cuts on the bath boxing in.
Youd better get more ale and nurofens in for that :)
What compound cuts? Vague memory of a mention is this before...
Edited by Onoff
5 minutes ago, Russell griffiths said:
Is there a reason mosaic number 2 doesn’t match the rest.
F***!
Moment of panic, looked at tile 2 and aok. Thought "pi$$ taking git!" Then looked and realised tile 1 is the wrong way up! :(
20181117_174932
  • Haha 1
The angles that meet on the external corner of the bath panel bob.
Remember your top idea for the toe-tuck angled approach .......?
I d’oth my cap. :D
I d’oth my cap. :D
Ah yes! The tiles coming up the overhang will need a chamfer to meet the trim properly:
20181117_214820
More fun will be this one:
20181117_214733
Still going to be left with "sharpish" corners on the trim here but better than it being 90deg.
I’ll tell you how to get around that ;)
Not tonight though ?
If your meaning this:
I may give up now! :)
Never thought it'd be the tiling that let The Big Bathroom Build down!
Can’t you buy ‘caps’ for trim ? . Corners you stick over it st 45 , 90 degrees etc to hide tricky mitre joints ?
kind of
https://www.trimtraders.co.uk/other-trim-types/trim-and-seal-corner-pieces.html
Edited by pocster
And the faux pas' keep coming!
Happy enough with these few:
20181120_225535
The 5 full tiles to the left are within a mm of the (white) wall so that's good.
Finished the shallowest pocket bar the grouting. Trickier the  I thought. The thicker grout lines between the mosaics might stand out when grouted:
20181120_225803
Didn't achieve the aimed for 1mm gap at the top either side. It's OK though down the sides and the sill.
20181120_225818
20181120_225810
However.....
Takes a deep breath.....from about here:
20181120_225748
The tile strip, above the bath pocket, is a bit :ph34r: out:
20181120_225642
And the other end:
20181120_225657
Which translates to a tile a 1/4" 'ish out:
20181120_225549
(Sounds so much better than 8mm.. :ph34r:).
So I'll have to kick the next tile down in a bit...quite a bit in fact. The trim there will be fun.
Edited by Onoff
Looks a lot better than the bathroom I was wiring yesterday. 5mm tile gaps all round except the bottom row that had a 10mm gap.
man on a galloping horse wouldn't see that.  If someone turns up with a level - don't allow them in.  Keep going.
I promised warts and all! Looking down the run it's this "out".
20181121_171034
Down the bottom I've to put 10mm of adhesive under the 7mm tile to get it at least a little better. In effect I'll get the tiles plumb from here on down.
Anyone, how do you invisibly join this sort of trim? I don't want water going inside.
20181121_184647
20181121_184637
20181121_184713
This is all taking shape. Do you reckon you'll have it done for Christmas? You're making good progress lately with the tiling and it looks sharp. What's left after the grout? Hang the WC and connect the WHB? Anything else?
