31 minutes ago, Barney12 said:
As long as the ply doesn’t move/flex (and knowing you I bet t doesn’t !) and the tanking is well adhered (ply really well primed) what you’ve suggested will be fine. I did exactly that on some ply bath panels in the barn some 15 years ago and they’re still there!
Are you saying prime the ply before I tank it? I was intending to tank the ply, then prime. Cheers.
Yes, you should have a primer under your tanking “goop”. It’s normally supplied in the kit. The tile adhesive goes straight onto the tanking goop. You need to stop the absorbency of the timber.
Sorry yes, forgotten that. It's a while since I've "tanked". Since then it's just been tiling primer. Tbh looks and smells like the same stuff!
Ye olde pizza box template trick:
2018-11-05_07-38-12
Pity that capped 15mm is live, no local isolation so I'll lose hot in the upstairs ensuite whilst I tile here.
A little more progress! ;)
Back of the pockets:
20181106_203150
3 tiles round the pipes and the waste wedged over a bit to try and "straighten" it:
20181106_203140
Not sure whether to put a strip of tiles up here - varied from 20 - 22mm.
20181106_170353
There's going to be more of a gap at the top than the bottom...the "blue" wall is plumb, it's the tiles that are a bit off!
20181106_171101
20181106_170915
Wondering if I could fill that gap with adhesive rather than tiles?
I wouldnt, that looks like a 10mm packer?!
Yep, I've used a 10mm notched trowel to bring the tiles out a bit.
It needs to look right - if that means its not plumb then so be it.  How many take a spirit level when visiting a bathroom?
Looking like you'll see this grout line as you walk in. Easiest to slip the tiles to go on behind the ones already on. Tbh it'll be obscured a fair bit by the basin & pedestal.
20181106_232538
Got to trim a few tops off!
20181106_232815
6 hours ago, newhome said:
Only @Onoff I imagine ?
AND my mate John The Chippy!  He walks in and says "Oh, you've a bit of a shadow line there...what happened?" & "Still, is it the first time you've tiled?" Git! Literally carries a tape wherever he goes! "What you could have done is..." is my favourite.
I did once consider a tape measure tattoo on a finger, for measuring bolts... :ph34r:
  • Haha 1
Bruvver from another muvver clearly then! ?
6 hours ago, Onoff said:
20181106_232815
Time for a caption competition?
"I swear to it, Officer, the Martian was right there !"
Edited by Ferdinand
  • Haha 1
7 minutes ago, recoveringacademic said:
@Onoff, you are the only person I know who still writes essays on your walls.
I think there needs to be a buildhub cartoon behind one of those tiles, for posterity.
Tbh I'd just got out of the shower when I took that. If those tiles had been reflective you could have played spot the ball! :)
Only 1?
Too much information.
I have a tape measure tattooed on my penis . I now measure massive things with ease ! ?
  • Confused 1
Measuring tall stories is a breeze I bet...
  • Haha 1
Proper planning:
20181107_193056
Going to wet cut these visible rips. The Rubi cutter just doesn't give a good enough edge on these ceramics.
