flanagaj Posted 4 hours ago Posted 4 hours ago The SE we used for designing our cut roof specified C24 47mm x 225mm for a 5.9m span for a flat garage roof. The timber which arrived was rather crap, not straight and twisted. Whilst doing some googling, I looked at span tables and all of them are saying that even at 400 centres the maximum span is ~ 5m. I have tried contacting said SE a few times and she is on radio silence. I am getting concerned now. How do I double check that she is a registered SE as she has made a number of mistakes now.
Roger440 Posted 4 hours ago Posted 4 hours ago Im no SE, but 6m sounds a rather long span for 225mm. 2
Oz07 Posted 3 hours ago Posted 3 hours ago Yeh I'd probably pause before putting these on. I have a similar issue with 6m garage flat roof. When I eventually found a span table I think it ended up being something like 70x250 or 225 c24 at 450 centres for 6m garage roof span. I'd want to speak to said SE and query it.
JohnMo Posted 3 hours ago Posted 3 hours ago 1 hour ago, flanagaj said: The SE we used for designing our cut roof specified C24 47mm x 225mm for a 5.9m span Maybe use posi joists - ours are 256mm our kitchen span is about 7m (12 Deg angle) and at 600mm centres 1
-rick- Posted 3 hours ago Posted 3 hours ago 1 hour ago, flanagaj said: The SE we used for designing our cut roof specified C24 47mm x 225mm for a 5.9m span for a flat garage roof. The timber which arrived was rather crap, not straight and twisted. Whilst doing some googling, I looked at span tables and all of them are saying that even at 400 centres the maximum span is ~ 5m. I have tried contacting said SE a few times and she is on radio silence. I am getting concerned now. How do I double check that she is a registered SE as she has made a number of mistakes now. Before engaging her you asked for a copy of her credentials and insurance right? What does she claim to be on her communications/advertising? If she claims to be a Chartered Structural Engineer then this is the professional body that you can check with: https://www.istructe.org/
flanagaj Posted 3 hours ago Author Posted 3 hours ago 14 minutes ago, Oz07 said: Yeh I'd probably pause before putting these on. I have a similar issue with 6m garage flat roof. When I eventually found a span table I think it ended up being something like 70x250 or 225 c24 at 450 centres for 6m garage roof span. I'd want to speak to said SE and query it. I'm concerned. Said SE hasn't replied to my emails. Not even the one regarding her issuing the invoice. She was originally tasked with designing a suspended staircase, but after two months of continually asking, I eventually stopped. The cut roof / garage was another job I asked her to do. Her site states she's a civil engineer, but I am thinking I need to validate that is the case. I've just reached out to a local firm for i-joists as I think these are cheaper and I don't need to run lots of ducting.
flanagaj Posted 3 hours ago Author Posted 3 hours ago 3 minutes ago, -rick- said: Before engaging her you asked for a copy of her credentials and insurance right? What does she claim to be on her communications/advertising? If she claims to be a Chartered Structural Engineer then this is the professional body that you can check with: https://www.istructe.org/ No I did not. Agreed. Naive and stupid.
-rick- Posted 3 hours ago Posted 3 hours ago 2 minutes ago, flanagaj said: Her site states she's a civil engineer, but I am thinking I need to validate that is the case. In that case the reg body is: https://www.ice.org.uk/ This is all very clearly stated on the government website. All I'm doing is googling it for you. All these orgs will likely do is be able to confirm that this person is qualified/has active registration. You really need to check the insurance of the professionals use because if something goes wrong that's what you will be relying on. Mortgage companies, buyers will care about the qualifications.
flanagaj Posted 3 hours ago Author Posted 3 hours ago 3 minutes ago, -rick- said: In that case the reg body is: https://www.ice.org.uk/ This is all very clearly stated on the government website. All I'm doing is googling it for you. All these orgs will likely do is be able to confirm that this person is qualified/has active registration. You really need to check the insurance of the professionals use because if something goes wrong that's what you will be relying on. Mortgage companies, buyers will care about the qualifications. Thanks. I've been very stupid here. I've just gone over the T&C's and there is no mention of her active registration. But I'm assuming that just like an individual cannot call themselves a Solicitor or Architect unless there are registered with the associated body. The same applies for an SE.
-rick- Posted 3 hours ago Posted 3 hours ago 2 minutes ago, flanagaj said: Thanks. I've been very stupid here. I've just gone over the T&C's and there is no mention of her active registration. But I'm assuming that just like an individual cannot call themselves a Solicitor or Architect unless there are registered with the associated body. The same applies for an SE. I'm at the end of my knowledge. Hopefully one of the professionals on here will speak up with more details. Everything I've put above can help you verify Chartered engineers but don't think you need to be chartered to practice so long as qualified and that might be an area that's a little harder to check. 1
ETC Posted 2 hours ago Posted 2 hours ago https://www.buildingcontrol-ni.com/assets/pdf/TechnicalBookletD2012.pdf
Mr Punter Posted 1 hour ago Posted 1 hour ago I doubt you will find longer than 6.0m. Can you break the span with a steel or flitch beam?
Gus Potter Posted 1 hour ago Posted 1 hour ago 2 hours ago, flanagaj said: The SE we used for designing our cut roof specified C24 47mm x 225mm for a 5.9m span for a flat garage roof. The timber which arrived was rather crap, not straight and twisted. Whilst doing some googling, I looked at span tables and all of them are saying that even at 400 centres the maximum span is ~ 5m. I have tried contacting said SE a few times and she is on radio silence. I am getting concerned now. How do I double check that she is a registered SE as she has made a number of mistakes now. 42 minutes ago, -rick- said: I'm at the end of my knowledge. Hopefully one of the professionals on here will speak up with more details. Everything I've put above can help you verify Chartered engineers but don't think you need to be chartered to practice so long as qualified and that might be an area that's a little harder to check. 1 hour ago, Roger440 said: Im no SE, but 6m sounds a rather long span for 225mm. Hope this helps lift your spirits a bit. The following is a bit of "chat", but also serious at times. Firstly. Well done you for looking up some span tables, what you are doing is carrying out a "sense check", you've clocked that the joist span looks out with normal expectation. I agree you are right to question. Also @Roger440, no dafty is asking.. and I'm pretty sure @saveasteading, @JpManning et al may bring professional opinion to the table. The thing that disappoints me most is this radio silence you are experiencing. There is generally no excuse for this. This is a common complaint on BH, Engineers not communicating or just being downright arrogant. But on the other hand your Engineer may have fallen unwell, this happens more often than you think. I have a long standing Contractor on my books who is mentally unwell, I'm supporting him. His business is suffering, he is a sole company director and employs folk that rely on him for their income. It may be your Engineer is unwell? That said SE's in particular seem to be very poor when communicating with Clients. It's actually a core objective of the IStructE, ICE to communicate with your Clients. I would try and determine if this lack of communication is due to say ill health. You'll maybe feel bad if you give them pelters and then find out they are on their death bed. Ok your joist span looks.. questionable. But your Engineer may have taken the view that it's a garage thus, no brittle finishes on the inside, thus we can tolerate extra deflection, so long as the deflections are not too big we can handle that. If deflections get too big then they can introduce what we call significant second order effects. Us folk with knowledge of structural design get wary about second order effects when we relax standard deflection limits. What your Engineer may have done is to just to design the timbers for strength alone, relaxed the deflection limits, as it's a garage. But if I adopt this approach I'll always tell the Client I've done, why I've done it, get their approval and check to see if these second order effects are significant or not. Now if you have a flat roof on a garage and you can push the spans. Yes, the timbers may be strong enough (just to not break and fall down) , but if they deflect in the middle too much then we have to be very careful the fall is still enough so we don't get ponding of water or snow melt on the roof as this can be dangerous. I would try as best you can to establish communication with your Engineer. Then you can ask what they were thinking was when they designed your garage roof. The may say, I relaxed the deflexion limits to save you money, but neglected to seek your approval for this.
