flanagaj Posted yesterday at 07:13 Posted yesterday at 07:13 As some of you predicted, our self build has turned into a disaster. We’ve now parted ways with bricklayer number two. Choosing a ground bearing slab was a dumb idea and beam and block would have enabled everything to run more smoothly. i think the bricklayer could have made things simpler by not building up the internal walls the past the block course. This has now made the Radon membrane detailing more tricky and expensive, due to the number of internal door ways. I also feel it’s going to be difficult to lay the slab as the open door ways will mean you have different levels for tamping off. I am contemplating taking the internal walls down to the top block course. What do people think? I don’t want any hate. So if you’ve got nothing constructive to say, please don’t comment. I’ve been contemplating deleting my BH account.
G and J Posted yesterday at 08:41 Posted yesterday at 08:41 We didn't have as many internal walls (open plan), and being timber frame /no radon barrier /different construction may not be helpful , but we did exactly that....popped off some of the internal walls to allow slab/insulation etc to be much easier and then rebuilt internal walls off slab (we did check it out with both our SE and timber frame supplier). Felt like a backward step at time, but was worth it for later simplicity... self build unfortunately does feel like a steps forwards can be followed by steps back 3
flanagaj Posted yesterday at 09:10 Author Posted yesterday at 09:10 27 minutes ago, G and J said: We didn't have as many internal walls (open plan), and being timber frame /no radon barrier /different construction may not be helpful , but we did exactly that....popped off some of the internal walls to allow slab/insulation etc to be much easier and then rebuilt internal walls off slab (we did check it out with both our SE and timber frame supplier). Felt like a backward step at time, but was worth it for later simplicity... self build unfortunately does feel like a steps forwards can be followed by steps back Ok. There is some reassurance that undoing work can make things simpler. The required preformed Visqueen internal door openings will be circa £500 alone. Let alone the additional required taped joints.
JohnMo Posted yesterday at 10:28 Posted yesterday at 10:28 I did mine almost the same as yours, but stopped doing block work at dpm level. Then backfilled floor to get a level site. This allowed the DPM to be installed and taken up the external walls. Above you can see where my internal wall block work stops DPM in place with rebar ready for concrete pour. Once you have poured your concrete, you build the internal walls up from the concrete directly above your foundations. This image show the top of the stub structural walls (after floor insulation and UFH added and prior to floor being poured) You have just carried away and built too high. You need detailed drawings and make sure your workers understand them. Suspect you need to remove the engineered bricks and Marmox blocks only, depending on where you have defined the DPM/DPC levels 1
Andeh Posted yesterday at 10:39 Posted yesterday at 10:39 Sorry to hear it OP, these houses can be such a massive emotional and physical heavylift.... But the shitshow will be temporary and the satisfaction and enjoyment is a lifetime. I promise you it is all worth it in the end, but you do need to smile and endure. 6
Mr Punter Posted yesterday at 11:09 Posted yesterday at 11:09 I have often had to reduce some wall heights or taken down sections built with wrong DPC. You should be able to reuse the Marmox, which is good considering the price! Ground bearing slab is nicer in the winter as you don't have freezing air circulating underneath. So is it MOT, gas membrane, concrete, insulation then screed or are they in a different order? Either way I can't see too many issues that can't be worked around.
flanagaj Posted yesterday at 12:38 Author Posted yesterday at 12:38 1 hour ago, Mr Punter said: I have often had to reduce some wall heights or taken down sections built with wrong DPC. You should be able to reuse the Marmox, which is good considering the price! Ground bearing slab is nicer in the winter as you don't have freezing air circulating underneath. So is it MOT, gas membrane, concrete, insulation then screed or are they in a different order? Either way I can't see too many issues that can't be worked around. Yes. Slab build up is as you have stated. Taking down the internal 3 courses won't take long and it will help considerably with gas membrane installation and concreting. 1
Nickfromwales Posted yesterday at 13:23 Posted yesterday at 13:23 If Radon is known to be a ‘high’ level, then I assume detailing the way that membrane is closed off correctly (as shown) would be a major issue here; not just time / cost, but in having this executed perfectly (BCO and warranty eyes will focus on this quite intensively if the risk is significant). Try knocking a couple of the common bricks off to see how well the Marmox breakers have adhered, as on a previous project you didn’t have to do much more than sneeze for these to come loose (tripped over a few and that was enough to dislodge them, prob too dry a bedding mix). No hate here, just sometimes replies are raw and ‘to the point’ as folk simply want to give you advice / information / direction as best they see it; often not allowing for the state of the recipient at that exact moment, which obvs does get taken the wrong way sometimes. No deleting accounts, take a breath and relax as the support here will help to get you over the finish line, you just need cut through the noise and get to the bits which you find relevant / helpful. Nobody here doesn’t want you to succeed, it’s simply not that type of forum. . If you have high levels of Radon then be aware that the rising ducts / pipes etc need to be detailed meticulously, something discovered on a current client's project. Top hats are slid over the soil pipes etc, are taped to the Radon barrier, and nave to be Jubilee clipped to form the correct detail. 1
flanagaj Posted yesterday at 13:29 Author Posted yesterday at 13:29 Just now, Nickfromwales said: If Radon is known to be a ‘high’ level, then I assume detailing the way that membrane is closed off correctly (as shown) would be a major issue here; not just time / cost, but in having this executed perfectly (BCO and warranty eyes will focus on this quite intensively if the risk is significant). Try knocking a couple of the common bricks off to see how well the Marmox breakers have adhered, as on a previous project you didn’t have to do much more than sneeze for these to come loose (tripped over a few and that was enough to dislodge them, prob too dry a bedding mix). No hate here, just sometimes replies are raw and ‘to the point’ as folk simply want to give you advice / information / direction as best they see it; often not allowing for the state of the recipient at that exact moment, which obvs does get taken the wrong way sometimes. No deleting accounts, take a breath and relax as the support here will help to get you over the finish line, you just need cut through the noise and get to the bits which you find relevant / helpful. Nobody here doesn’t want you to succeed, it’s simply not that type of forum. . If you have high levels of Radon then be aware that the rising ducts / pipes etc need to be detailed meticulously, something discovered on a current client's project. Top hats are slid over the soil pipes etc, are taped to the Radon barrier, and nave to be Jubilee clipped to form the correct detail. We only require 'Basic' Radon protection as we are in a 3-5% area. The one issue I've got is that the membrane sits at the same level as the coupling on the rest bend. No idea how I'm going to solve that problem. But the top hats I purchased won't work. I think Juta do a liquid rubber that you create a dam and pour. The top hats are great for soil pipes in the middle of a room, but not so when your soil pipe is in the corner of a room.
Square Feet Posted yesterday at 13:35 Posted yesterday at 13:35 I don't have any real advice other than to hang in there. I'm sorry it's tough just now. Sometimes a couple of hours away walking along a beach or something can help. It's a lot easier to pick yourself up and carry on again after. You'll sort it and move on from this.
BotusBuild Posted yesterday at 15:33 Posted yesterday at 15:33 Pause, sit back, breathe deeply. Now your relaxed, read the advice, research solutions e.g. the resting bend collar issue, and work out your plan of action. Write it all down, and cross it off as you go. This is satisfying as you can see progress. Regarding the brickie. From the picture it looks like what he's done is good work. Unless you have had a major falling out with angry words exchanged, it may be worth eating a little humble pie and asking them to return when needed. 2
Oz07 Posted yesterday at 15:39 Posted yesterday at 15:39 Taking off few courses is easiest. There may be an alternative though. How much higher is ffl than the top of your current blockwork level. Instead of the planned buildup can you not do mot, dpm, insulation, gas membrane, self compacting concrete slab. No screed needed and brings your membrane level up higher so stripping off less masonry or maybe none? Why have you sacked brickie 2 is it to do with this or something else? 1
Gone West Posted yesterday at 15:59 Posted yesterday at 15:59 This setback will be pushed to the back of your memory surprisingly quickly. We had an insulated slab laid, which the workers cocked up badly and the whole lot had to be cut up and replaced. Just keep plodding on. 1
Nickfromwales Posted yesterday at 16:25 Posted yesterday at 16:25 2 hours ago, flanagaj said: We only require 'Basic' Radon protection as we are in a 3-5% area. The one issue I've got is that the membrane sits at the same level as the coupling on the rest bend. No idea how I'm going to solve that problem. But the top hats I purchased won't work. I think Juta do a liquid rubber that you create a dam and pour. The top hats are great for soil pipes in the middle of a room, but not so when your soil pipe is in the corner of a room. There’s a self-adhesive ‘peel and stick’ detail strip, on a roll, which I applied to these right awkward bastards: LINK Note we added stainless jubilee clips for belt & braces as Radon was v high. 2
flanagaj Posted yesterday at 18:08 Author Posted yesterday at 18:08 1 hour ago, Nickfromwales said: There’s a self-adhesive ‘peel and stick’ detail strip, on a roll, which I applied to these right awkward bastards: LINK Note we added stainless jubilee clips for belt & braces as Radon was v high. Thanks for the photos. So it can be done, just doesn’t look as tidy as a collar, but needs must. Brickie two is not returning. An ego the size of England, unable to understand who the client was and seemed unable to read plans regarding door openings and lintels. 3
Nickfromwales Posted yesterday at 18:30 Posted yesterday at 18:30 16 minutes ago, flanagaj said: Thanks for the photos. So it can be done, just doesn’t look as tidy as a collar, but needs must. Brickie two is not returning. An ego the size of England, unable to understand who the client was and seemed unable to read plans regarding door openings and lintels. I’m constantly firing idiots on my clients behalves. Just shocking how some own a saw but say it’s blunt; then I mention that they’re holding it upside down……😵💫🫣😣. Most recent builder to receive a bullet….you’d have to see how poor the work was to believe it. He of course couldn’t see what the problem was, or when shown just kept saying “ok, I’ll put that right”. The fact he ignored written and verbal instruction was just another day in the office. And a site littered with empty beer cans; instant dismissal applies there afaic. Glad you’ve found your voice! 1
Roundtuit Posted 23 hours ago Posted 23 hours ago 11 hours ago, flanagaj said: As some of you predicted, our self build has turned into a disaster. Minor set-backs my friend! Seriously, I'm sure half of us have had that 'wtf did I start this for' feeling when waking in the small hours soaked in sweat and dreaming of -insert current snag here -. It's hard to keep perspective when it's your life/money/sanity, but it will be worth it when it's finished and the PTSD subsides 🙂 3
Nickfromwales Posted 23 hours ago Posted 23 hours ago 3 minutes ago, Roundtuit said: Minor set-backs my friend! Seriously, I'm sure half of us have had that 'wtf did I start this for' feeling when waking in the small hours soaked in sweat and dreaming of -insert current snag here -. It's hard to keep perspective when it's your life/money/sanity, but it will be worth it when it's finished and the PTSD subsides 🙂 In fairness, given the 5 and 6 figure feck ups I’ve seen, this particular instance is more an annoying hiccup. Glass half full approach is the way to get to the finish line. 2
Mr Punter Posted 6 hours ago Posted 6 hours ago 17 hours ago, Nickfromwales said: In fairness, given the 5 and 6 figure feck ups I’ve seen, this particular instance is more an annoying hiccup. Glass half full approach is the way to get to the finish line. I agree. Far from a shitshow this is barely a skidmark. 1
Spinny Posted 5 hours ago Posted 5 hours ago @Andeh What exactly have you used as your soffit material, it looks very good. Is it actual timber, or something man made ?
Alan Ambrose Posted 2 hours ago Posted 2 hours ago Yeah, if you assume there will be all sorts of contractors, tradesmen, authorities, planners, neighbours etc actively trying to delay / stop / trip you up etc then it’s just business as usual. Self build seems to me to often (a) require the exercise of sheer bloody mindedness on the part of the self-builder and/or (b) being prepared to play a bit part in a Beckett / Brecht play. Sometimes this is just hilarious. We just received a letter from the local environment geezers, courtesy our delightful neighbour, touting ‘light pollution’ ‘cos we forgot to turn the site lights off inside the building one evening a couple of months ago. Guffaw and carry on…
Great_scot_selfbuild Posted 57 minutes ago Posted 57 minutes ago On 20/06/2026 at 08:13, flanagaj said: I don’t want any hate. So if you’ve got nothing constructive to say, please don’t comment. I’ve been contemplating deleting my BH account. @flanagaj hope you're doing ok? I've been finding the 'lows' recently and needing a lot of resolve to find the resilience to keep moving forwards even if it's slower than desired or, in our case backwards on some aspects which still aren't moving forwards yet! Looks like there's some good advice coming through in response to your query. Good luck!
