pulhamdown Posted yesterday at 10:14 Posted yesterday at 10:14 (edited) Hi. We built our house in Scotland in 2012, just before the EPC system became compulsory. So we are not on the Scottish register, but we had an EPC done and it came out as A100. We just scraped into passiv haus territory, with an airflow reading of just under 0.6 ach, but didn't get it certified. When we replaced our oil fired boiler with a heat pump, we needed a new EPC for the grant. So the original EPC was based on the SAP, but the new one was based on the rdSAP for existing homes. We ended up with a C74. Clearly something not right. The system is not fit for purpose, but how on earth can it be changed to make it useful for purchasers? Perhaps keeping the original EPC based on the SAP, and renewing that every 10 years with appropriate changes taken into account? The assessor who came to do our second EPC had never seen a "passiv haus" and clearly didn't really get it. When he saw our EPC of A100, he said there must have been a mistake, and that he'd never given a higher score than C75! I do realise that the current system faults are mainly down to the methodology of the rdSAP, and I believe there is a plan to change the system sometime next year, but I'm not holding my breath. Edited yesterday at 10:14 by pulhamdown Typo
JohnMo Posted yesterday at 11:03 Posted yesterday at 11:03 The system just uses people that are happy to cut and paste - sh!te in st!te out. Many assumptions made, but you pay maybe a £100 or less for the EPC - but to do the EPC correctly would take tens of hours. What can we expect? Just treat as a tick in a box and move on would be my advice. Keep your electric bills for a future buyer - way more important than EPC. 1
saveasteading Posted yesterday at 13:13 Posted yesterday at 13:13 2 hours ago, JohnMo said: to do the EPC correctly would take tens of hours. There are a lot of useless people doing this, and good too of course. the test is whether they ask questions and/or give suggestions. interested or its just a job. have some questions. some are just random guys that have been given the task by their employer. I recall a family purchase and upgrade, of traditional brick walls and somebody came to assess for the gas or electric company for some reason. He spent 5 minutes making assumptions for 'this sort of building'. didn't check in the loft. wouldn't listen that we had upgraded the party wall. I wouldn't be surprised if he thought this was a cushy job and would start his own assessment business.
Gone West Posted 20 hours ago Posted 20 hours ago Isn't it possible to fork out a bit more and have a full SAP EPC calculated rather than an rdSAP version.
SimonD Posted 20 hours ago Posted 20 hours ago 8 hours ago, pulhamdown said: but I'm not holding my breath. The Future is HEM - https://home-energy-model.co.uk/
JohnMo Posted 19 hours ago Posted 19 hours ago 31 minutes ago, SimonD said: The Future is HEM - https://home-energy-model.co.uk/ More complex but will still be sh!te in.... Same monkeys will just use a different computer program.
Alan Ambrose Posted 18 hours ago Posted 18 hours ago “At its core, HEM is a building physics simulation. It takes detailed data about a home (its construction, heating system, ventilation, insulation, glazing, orientation, and local weather) and calculates its energy performance at half-hourly intervals throughout a full year.‘ Well it’s probably a step forward being single & open source / cloud / written & paid for by the government. It’s effectively UK govt’s answer to PHPP. The usual problems won’t entirely go away though: + since we have little idea how our current housing stock is built, there will be lots of guessing i.e. ‘assumptions’. So a bit GIGO. + we’ll need loads of custom psi calcs if the results are going to reflect the actual heat loss. + these are only models and reflect assumptions about how we live in these houses - probably there will be little comparison of actual vs. model (just like EPCs) so the man in the street may pay them very little attention. The 1/2 hour intervals are marketing BS and won’t help the accuracy one bit. Lastly, one of the helpful things about PHPP is its database of real world components - this will be key but a lot of work to replicate.
SimonD Posted 18 hours ago Posted 18 hours ago 1 hour ago, JohnMo said: More complex but will still be sh!te in.... Same monkeys will just use a different computer program. Sadly, the implementation probably will be.
SimonD Posted 18 hours ago Posted 18 hours ago 23 minutes ago, Alan Ambrose said: we’ll need loads of custom psi calcs if the results are going to reflect the actual heat loss. The promise is to use a different cold bridging methodology, probably using FEA tools, so yes a lot of work required, but better than blanket defaults as per SAP currently? If used correctly..... Quote The resulting heating or cooling demand needed to maintain the zone setpoint But this is interesting, because there is no mention of using BS EN 12831-1:2017 which is the UK standard for designing the space heating load. And this standard has only just been implemented. I wonder if this is going to lead to different standards being used for new builds using HEM that aren't necessarily going to be consistent with BS EN 12831-1. Or is there going to be another poorly considered change to the industry.
-rick- Posted 3 hours ago Posted 3 hours ago 16 hours ago, JohnMo said: More complex but will still be sh!te in.... Same monkeys will just use a different computer program. Just been reading it now. With everyone forced to use the same calculation engine and the defaults being designed to be 'punative' the incentives for accurate data entry go up a lot. How that translates will be interesting. Definitely going to increase costs and I'm sure plenty of lazy accessors will try to find ways to be lazy but will probably lead to more accuracy overall. Going to be annoying from a scheduling point of view if you have to specify a lot of this detail early in the design. Pipe diameters, length, flow rates per outlet, make/model of mhvr/heatpump/hot water cylinder/etc.
JohnMo Posted 2 hours ago Posted 2 hours ago But for 90% of housing stock they will not be drilling into walls to find out how construction was done or any improvements completed in x years. You may be lucky and they will poke their head into loft, if it has a suitable ladder. They will make a huge bunch of assumptions. Funny old thing just like MCS assessments for heat pumps. 1 hour ago, -rick- said: specify a lot of this detail early in the design. make/model of mhvr/heatpump/hot water cylinder/etc. We have to most of that now in Scotland, as we need an as designed EPC prior to Warrant issue. Getting those details for existing housing - 90% of the public would not reply, as it's all stuff for someone else to understand.
Mike Posted 17 minutes ago Posted 17 minutes ago 17 hours ago, Alan Ambrose said: probably there will be little comparison of actual vs. model (just like EPCs) so the man in the street may pay them very little attention In France - where EPCs significantly affect property values & saleability - EPCs now have a legally enforceable status throughout their 10-year validity - the same status as asbestos reports and the like. That is, if an EPC is proven to be wrong, a buyer / lessor can take action against the seller / landlord for the cost of improvements to reach the EPC rating / extra central heating costs incurred + interest / loss of value / loss of enjoyment / potentially the annulation of the sale or lease. The seller / landlord can also take similar action against assessor (unless they provided false information, in which case there are very severe penalties). The assessor may also incur a fine of €1,500 fine in case of error, or €45,000 & up to 3 years prison for falsification. Of course you can't get an EPC for £35 in France. Previously, French properties were often falsely bumped up into the next EPC band, as per the chart below. Presumably this won't happen (much) going forwards. chart from an analysis by KRNO: étude KRNO sur la fiabilité du DPE, 28 novembre 2024
