flanagaj Posted yesterday at 13:37 Author Posted yesterday at 13:37 4 hours ago, saveasteading said: It has landed on the concrete. That's better than some. I can picture the reaction to that realisation
flanagaj Posted yesterday at 13:39 Author Posted yesterday at 13:39 I wasted a weekend and a £100 in timber .. the surveyor chap marked it all out in 2 hours 🙄
Russell griffiths Posted yesterday at 13:48 Posted yesterday at 13:48 9 minutes ago, flanagaj said: I wasted a weekend and a £100 in timber .. the surveyor chap marked it all out in 2 hours 🙄 Does it look right. 1
Mr Punter Posted yesterday at 15:20 Posted yesterday at 15:20 If you can, transfer the survey markings to just outside the building footprint so you can easily run a string line down the centre of the trenches and re-mark. 2
flanagaj Posted yesterday at 15:39 Author Posted yesterday at 15:39 1 hour ago, Russell griffiths said: Does it look right. I’ll be out with my tape measure later, but I’ll be very disappointed if it’s not 😂
JohnMo Posted yesterday at 16:34 Posted yesterday at 16:34 53 minutes ago, flanagaj said: I’ll be out with my tape measure later, but I’ll be very disappointed if it’s not 😂 Check the diagonal dimensions to make sure it's square, you have nice oblong building so should be easy to get right, but ... 1
saveasteading Posted yesterday at 16:50 Posted yesterday at 16:50 10 minutes ago, JohnMo said: measure later later so that they don't feel threatened/ doubted, and so you have lots of time to get the hang of it. I think you said the site is sloping. The tapes need to be tight and horizontal. if necessary use a spirit level to bring one point op to the level of the other. Then don't panic if it is a few mm different. the diagonals exaggerate any differences and you have more opportunities for precision as you come out of the ground.
flanagaj Posted 22 hours ago Author Posted 22 hours ago 2 hours ago, saveasteading said: later so that they don't feel threatened/ doubted, and so you have lots of time to get the hang of it. I think you said the site is sloping. The tapes need to be tight and horizontal. if necessary use a spirit level to bring one point op to the level of the other. Then don't panic if it is a few mm different. the diagonals exaggerate any differences and you have more opportunities for precision as you come out of the ground. Would you still check even though it was set out with a total station? some of the pins are not vertical, so that will skew the diagonal measurement.
Redbeard Posted 21 hours ago Posted 21 hours ago 38 minutes ago, flanagaj said: some of the pins are not vertical, so that will skew the diagonal measurement. But surely the hole will be in the right place 1
Russell griffiths Posted 20 hours ago Posted 20 hours ago Now you have your pins in place you could set up your profile boards if you want, you can mark external wall and internal then see it all drops onto the foundation. are you going 600 wide or 700. im sure something changed recently regarding regs.
saveasteading Posted 18 hours ago Posted 18 hours ago 3 hours ago, flanagaj said: Would you still check even though it was set out with a total station? some of the pins are not vertical, so that will skew the diagonal measurement. Yes I would, because people make mistakes. Presumably the pins are in the ground at the exact spot, so you measure to that, or to a spirit level up from it. Also check any critical distances, for example to an existing feature or a boundary. I would also do as I said earlier and take references, but it is up to you. This is in case a pin is knocked over. It is simple to place offset pins or pegs. Project the wall lines you have, and put a mark in 1m (typically) beyond, at each end. If using a peg, put a nail in the top. You then have 8 pegs. If you wish , tie an orange stringline between them and you have your rectangle, increased by 1m. Then the digging can all be within that, and you have an immediate check. you may also be saving a visit or 2 from the total station.
flanagaj Posted 9 hours ago Author Posted 9 hours ago (edited) So there has been a cock up. It’s been marked out with a 100mm cavity instead of a 150mm cavity. I’ve just raised this with the surveyor and he tells me that the Dwg file that I provided him showed a 100mm cavity instead of a 150mm cavity. How do people managed to xxxx up the most basic tasks. Edited 9 hours ago by flanagaj Corrected measurements
saveasteading Posted 8 hours ago Posted 8 hours ago 7 minutes ago, flanagaj said: he tells me that the Dwg file that I provided him showed a 100mm cavity instead of a 150mm cavity. So change it / get it changed. He can use the correct drawing next visit. Meanwhile, you have a rectangle marked out too small by a known amount. So you can prepare the area. Perhaps postpone that concrete pour. 11 minutes ago, flanagaj said: How do people managed to xxxx up the most basic tasks. It's not simple, as you are finding. 1
ToughButterCup Posted 7 hours ago Posted 7 hours ago On 15/03/2026 at 23:41, saveasteading said: ... And that many builders assume that by using lasers there will be no issues. Thats how we found out that the guy who set out our plot made a one meter error. So I paid him £1 less than he charged. (But bought him a pint in the pub)
saveasteading Posted 4 hours ago Posted 4 hours ago 4 hours ago, flanagaj said: I’ve just raised this with the surveyor How did you notice the error?
flanagaj Posted 3 hours ago Author Posted 3 hours ago 27 minutes ago, saveasteading said: How did you notice the error? I went out yesterday evening to sanity check the pin spacing measurements and they were around 50mm greater than my cavity centre calculations. So I then contacted the surveyor who confirmed that his drawings showed a 100mm cavity. Architect then apologised for sending over an old drawing which showed 100mm cavity. This was from when we were going to have a 100mm cavity and use 90mm PIR. so I’ve now taken the afternoon off work to validate and move the pins. 1
SteamyTea Posted 2 hours ago Posted 2 hours ago Re taking diagonal measurements. Quick sketch below show what one, half degree out, but correct length does. 1
