sgt_woulds Posted Friday at 14:26 Posted Friday at 14:26 3 hours ago, Nickfromwales said: If moisture was routinely buffered any further into the fabric of a domestic residence, that’s just too far and has not been addressed or controlled properly. Seasonally, perhaps this is an acceptable swing, but day to day it should be the immediate room interior surfaces at most. I dislike this approach, and am not afraid to say it! Grab the heat and moisture, use it to better facilitate heat recovery, and get the MVHR in and running. Tin hat time. Restricting moisture sorbing and release to the surface materials (Gypsum plaster boards) limits the positive benefits of stable indoor moisture levels that natural insulations can provide. Not an issue with MVHR of course (unless there is a sustained power cut in winter with high occupancy) as this is artificially removed. Personally, I'd rather not rely on a mechanical system to stay healthy indoors. Horses for courses. And I prefer my straw hat to tin foil 🙂 1
JohnMo Posted Friday at 14:46 Posted Friday at 14:46 11 minutes ago, sgt_woulds said: Personally, I'd rather not rely on a mechanical system to stay healthy indoors. I've done both, woodcrete ICF is a good hydrophilic material I believe, but good airtightness and MVHR to capture any ventilation heat losses. 1
Nickfromwales Posted Friday at 15:57 Posted Friday at 15:57 1 hour ago, sgt_woulds said: I'd rather not rely on a mechanical system to stay healthy indoors So no mechanical fans in kitchen / utility / bathrooms etc?
sgt_woulds Posted yesterday at 12:43 Posted yesterday at 12:43 With iPSV you don't need a fan in the bathroom or kitchen, to maintain overall conditions. You might want a small fan to assist with kitchen odours though. We do have an extract fan in our kitchen, as an easy route for passive stack was not available. Building from scratch, these problems could all be mitgated at the design stage.
SimonD Posted yesterday at 12:49 Posted yesterday at 12:49 On 20/02/2026 at 15:57, Nickfromwales said: So no mechanical fans in kitchen / utility / bathrooms etc? If it's all properly designed, there's no need for them, but BCO might ask for them to be installed. I have an old inline fan in a cupboard in the kitchen but not connected, another in the guest bathroom not connected and a small one in the ensuite that I've just put in at minimum fan speed because my wife was worried.....
sgt_woulds Posted 4 hours ago Posted 4 hours ago (edited) One of the drawbacks I can see with iPSV is hot days and sustained heatwaves with little wind to drive ventilation. Currently we 'sail' or house through heatwaves by closing off all ventilation and shading the south facing windows (curtains, but we are planning external shades when we replace the front windows). Our roof and walls contain lots of woodfibre so we have good decrement delay, and occupation is low during the day so CO2 and moisture levels are not an issue. In the evening after the sun has set and the air temperature has dropped, we open the north facing windows and the skylight and purge ventilate the house - you can feel the cooler airflow and it is very refreshing. However, after a couple of days of heat, the night time temperature difference is reduced (due to radient heat from the earth and buildings) so this option tails off and CO2 levels inevitably rise. We then use portable fans to make life bearable. I know they considered this issue with the Bedzed buildings and tried using ventilation cowls / wind catchers but I don't think it was very successful. It is pretty much a given that climate change will lead to more frequent and longer heatwaves so I'm considering building a solar chimney with soil pipe ventilation - I have to build a patio out the back anyway so it is just a little extra excavation. The chimney might be an issue with building control, but sod 'em! We'll stick it up and see if anone notices! I have a couple of ideas on the design, and I'm considering buying the Handbook of Domestic Ventilation but I don't know if this is a good sourceof information or if there is better text elsewhere. It is an expensive book to take a punt on... Edited 4 hours ago by sgt_woulds missing words
