One of the things we paid someone to do for us.
Spines are powder coated. Cabling for lights runs inside the spines. Steps made from walnut kitchen worktops. Spindles are solid walnut. Glass is 10mm toughened from Cornwall Glass.
Why walnut? It goes with the breakfast bar made from the walnut tree we cut down, also made by same person (Principle  Constructions based in Cornwall).
  • Like 11
Nice!
Thats the first time I've seen the transparent blocking approach to having an open stair that complies with regs. Be interested how that works out (cleaning, etc).
Handrail to be installed on the right?
I like the walnut and that it came from your tree. It is also very different colour from nearly all the other stairs you see now.
Edited by MPH243
Looks fab. Well done. Just make sure you coat the timber with something that is UV resistant. Otherwise, in the same way as Mapel turns a bit orange in the sun. Your Walnut will "Fade to Grey" as the song said.
19 minutes ago, crispy_wafer said:
Can I ask how you lifted the stairs.
Three men and a rope. The two spines are separate pieces.
Lovely. Any idea of a ballpark figure. I've been considering a cut string staircase for upcoming project. Won't be as wow factor as that but will be something different from the usual white string oak handrail carpeted stairs job.
6 minutes ago, BotusBuild said:
Just shy of £10k
How much of that is the wood? Walnut is pricey, but so is the cost of getting someone to mill down your own tree. Curious how that stacks up?
Once signed off, I would remove the glass panel from under the bottom tread.  It adds nothing to safety and will impede the hoover.
  • Sad 1
