Beelbeebub Posted yesterday at 13:52 Author Posted yesterday at 13:52 45 minutes ago, JohnMo said: Exactly the same a solar assist heat pump outdoor condenser, but indoors Ha! Yeah, but prettier obviously. What is that product? I wonder if you could get around the big box of an outdoor unit with a large black roof/wall mounted panel
saveasteading Posted yesterday at 14:00 Posted yesterday at 14:00 3 hours ago, Roger440 said: Dont think id want them in my house though. Cheap but noisy, and easy to fit, but just for one room. But buy in southern Spain (prob france too) and they are much cheaper...and noisier. If that was running off solar and battery that shouldn't take long to pay back.
Roger440 Posted yesterday at 14:09 Posted yesterday at 14:09 5 minutes ago, saveasteading said: Cheap but noisy, and easy to fit, but just for one room. But buy in southern Spain (prob france too) and they are much cheaper...and noisier. If that was running off solar and battery that shouldn't take long to pay back. Came very close to fitting 2 in my office and "clean room" in my workshop. Well, the propane filled ones, so no need the an F gas person. Sadly, my "electricity supply" issue means that ill need to go oil for that too. Lots of second hand boilers around at the moment for bugger all money. And easy to DIY. Which is a shame, because this would have been much simpler.
Crofter Posted yesterday at 14:40 Posted yesterday at 14:40 My air to air system doesn't look like that. There's a normal outdoor unit like any other ASHP. Then under the floor there's the indoor unit, completely out of sight. Insulated 200mm ducts go from this too each room (smaller rooms split down to 150mm). The warm air comes out of wall grilles. One in the kitchen plinth, the others are just above skirting level. Each grille has adjustable vanes and a damper to restrict the flow. I've throttled down the kitchen one a little but otherwise haven't touched these. The house is 93m², the ASHP is 10kw, which I thought might be slightly oversized but it's what the installer suggested. In use, we tend to set it to anywhere between 18-20⁰C. The thermostat is in the hallway in the middle of the house. You can close doors on individual rooms if you want them hotter. So usually we leave bedroom doors open and that keeps those rooms comfortably cool, while closing the living room door lets the temperature go up to a degree or two more in the. We could adjust the dampers to achieve the same thing but opening and closing doors is easier! We do light the woodburner in the evenings so when I say we're spending £1-£2 a day, it's not quite the whole story. I reckon we maybe save £1 a day lighting the stove. Which does make me question the wisdom of spending so much time and effort chopping logs 😂 Edit to add: total installed cost was about £4200 including every little jubilee clip and clamp. Most of that was the supply and fit of the indoor and outdoor units. I ran all the ducting myself. A simple but time consuming job that the installer wasn't interested in taking on himself. I likely saved a lot of money by doing that myself. And just to reiterate, zero grant funding towards any of this. 1
JohnMo Posted yesterday at 14:51 Posted yesterday at 14:51 58 minutes ago, Beelbeebub said: What is that product? Video -
-rick- Posted yesterday at 15:01 Posted yesterday at 15:01 Are they defunct? The website they give in the video seems dead. www.sahp.info Whats the website in your earlier screenshot?
JohnMo Posted yesterday at 15:56 Posted yesterday at 15:56 https://acwservicesltd.co.uk/electrical-services/solar-assisted-heat-pumps/ 2
Mattg4321 Posted 10 hours ago Posted 10 hours ago On 29/01/2026 at 09:43, SimonD said: I'm not sure it's agreed that we should extract what we've got. Analogous to the OP, I can't help think about another complex situation we're dealing with in the UK - the NHS - one of the lines of which goes: - Service isn't working - Result = call for more beds/capacity in hospitals - Provide beds/capacity - Find beds filled because patients can't be discharged effectively enough due to internal processes and external capacity (so patients get blamed as bedblockers) - Result is full circle to call for more beds/capacity in the hospital This is the cycle oft shouted from the rooftops from patient groups as well as politicians and the media. The other view, which is mostly ignored from the above is, but very well understood (i.e. they know what needs to change and how to do it but are prevented by those holding the views above): - Model and understand the effects of admitting patients into hospital (including costs) - analyse the data - realise that it is far cheaper, much more effective, and better for patients if they don't have to go into hospital in the first place - costs can actually be reduced to as little as a 10th of the cost of inpatient service - result - a realisation that we have to fundamentally rethink and change how we provide health services, which demands a total mental shift away from what we've been doing for almost 80 years. - therefore resistance, because change is hard and may need additional upfront investment - and what follows is 'oh this is too hard it isn't working immediately. Wards are being closed and we don't have enough beds, so to solve the problem we need more beds' The similarities here are that we know what we need to do, we know how to do it and what is required, we have all the technology in place to do it, but instead we turn back to what we already know, despite all its downsides. Better the devil you know? What possible sensible reason is there for leaving it in the ground whilst we import the same product from abroad at additional cost, with no benefit to the treasury and impact on certainty of national supply? In all honesty net zero is not my biggest concern. High energy prices are. We need to reduce them as much as possible and any number of benefits will shortly follow. If the plan is to steal a march on other countries by going renewable early, and it means we can compete then great, but I’m very sceptical. China will keep burning mountains of coal for generations yet imo. Whilst we get poorer.
saveasteading Posted 9 hours ago Posted 9 hours ago 53 minutes ago, Mattg4321 said: leaving it in the ground whilst we import the same product from abroad at additional cost, The oil isn't the same product. I didn't know this til recently. Neither do the campaigners and anti-green journalists whose messages go far and wide. Or if they know it doesn't suit their narrative. Ours goes away for turning into chemicals, and we can't run our vehicles or heating off it. And it gets ever more expensive to extract as the volume and easy pickings diminish... as I understand it. 1
jack Posted 8 hours ago Posted 8 hours ago 1 hour ago, Mattg4321 said: In all honesty net zero is not my biggest concern. High energy prices are. The UK has some of the highest energy prices in the world, but that's driven by regulation and how the market is structured. I doubt increased local extraction would have much, if any, of an impact on energy prices. I agree, however, that high energy prices are one of the biggest issues facing the UK at the moment, both domestically and industrially. 2
Beelbeebub Posted 8 hours ago Author Posted 8 hours ago 13 minutes ago, saveasteading said: The oil isn't the same product. I didn't know this til recently. Neither do the campaigners and anti-green journalists whose messages go far and wide. Or if they know it doesn't suit their narrative. Ours goes away for turning into chemicals, and we can't run our vehicles or heating off it. And it gets ever more expensive to extract as the volume and easy pickings diminish... as I understand it. This also feeds into the "drill for energy security" argument. For gas it is relatively simple. So *if* we were able to extract enough gas for our needs then we could heat homes and run power stations from our own supply. But oil is another matter. We will *always* be dependent on imports for road fuel because of oil and refinery type mismatches. My understanding is us road fuel is mainly refined from imported oil, despite the US being a net exporter of oil, for this reason. So, as transport is vital to our economy and national security, having a system that relies on a product we have to import is bad. The solution to this is to move transport to an energy source we can domestically supply. Previously this was more or less impossible. However the advent of practical for most purposes electric vehicles has solved this. So the net zero policy of electrification of road transport is also the energy security policy of moving away from an import dependent fuel source. The key things politicians who advocate "drill for energy security" omit are 1. There is no plausible scenario where the UK can produce enough oil and gas for current consumption. 2. Even if we could, type mismatch between oil and refineries would mean we have to import fuel anyway 3. Being an open market means the price of domestically produced oil and gas tracks the world price anyway. Therfore not insulating us from price shocks. 2
SimonD Posted 6 hours ago Posted 6 hours ago 3 hours ago, Mattg4321 said: High energy prices are. 3 hours ago, Mattg4321 said: Whilst we get poorer. Neither oil or gas, or anything to do with them are the answers to these questions, it is just conflation. High energy prices are the result of energy policy and market structure. We're getting poorer as a consequence of neoliberalism and the only link to oil/gas and neoliberalism is that the fossil fuel companies spend billions funding the thinktanks that promoted neoliberalism. From a social and economic perspective, the UK was pretty much a social democracy from just after WWII to the mid 1970s. During that time we saw tremendous growth, redistribution of wealth and equality - we got richer. Come Thatcher and the wholesale introduction of neoliberal policies and we've basically seen the opposite ever since. 3
Beelbeebub Posted 4 hours ago Author Posted 4 hours ago 5 hours ago, Mattg4321 said: What possible sensible reason is there for leaving it in the ground whilst we import the same product from abroad at additional cost, with no benefit to the treasury and impact on certainty of national supply? I have quite a large forest. I could cut that wood, haul it out of the forest, have it saw up into timber, stack it to season it and then use it for my building. I don't because 1. The wood I have is less suitible for general construction than the pressure treated softwood I can buy and more suitible for specialist use such as cladding 2. It is much more expensive for me to get a 4x2 this way than to buy one from a timber merchant 3. If I need a specialist wood, which I do from time to time, I have access to it even if it isn't available or is very expensive or backordered. It is the same with oil (and gas). It costs about $35 a barrel to extract oil from UK reserves but less than $10 a barrel in the Middle East.
Crofter Posted 3 hours ago Posted 3 hours ago I'd presume that in 50yrs time our oil and gas would be worth more than it is now. Nice little nest egg to be sitting on whilst everybody else burns their reserves.
Mattg4321 Posted 2 hours ago Posted 2 hours ago 6 hours ago, saveasteading said: The oil isn't the same product. I didn't know this til recently. Neither do the campaigners and anti-green journalists whose messages go far and wide. Or if they know it doesn't suit their narrative. Ours goes away for turning into chemicals, and we can't run our vehicles or heating off it. And it gets ever more expensive to extract as the volume and easy pickings diminish... as I understand it. That’s not true. Half the world bases oil prices against the benchmark Brent Crude, which comes from the North Sea. It’s light sweet oil that is perfect for making into transport fuel. There are also heavy oil fields in the North Sea. Some as yet untapped. See the Bentley field. 3 hours ago, SimonD said: Neither oil or gas, or anything to do with them are the answers to these questions, it is just conflation. High energy prices are the result of energy policy and market structure. We're getting poorer as a consequence of neoliberalism and the only link to oil/gas and neoliberalism is that the fossil fuel companies spend billions funding the thinktanks that promoted neoliberalism. From a social and economic perspective, the UK was pretty much a social democracy from just after WWII to the mid 1970s. During that time we saw tremendous growth, redistribution of wealth and equality - we got richer. Come Thatcher and the wholesale introduction of neoliberal policies and we've basically seen the opposite ever since. I don’t necessarily disagree with some of this. Neoliberalism has turned out to have a lot of downsides. But the country was in a terrible state in the 70’s. It wasn’t all sunshine and butterflies. 32 minutes ago, Crofter said: I'd presume that in 50yrs time our oil and gas would be worth more than it is now. Nice little nest egg to be sitting on whilst everybody else burns their reserves. That makes little sense if there’s no demand for it then. Perhaps renewables/nuclear or something else will be the future. Or perhaps not. But either way you can’t shut the whole industry down, lose all the experience, skills and infrastructure and expect to just turn it back on in a few decades. Naive in the extreme.
Beelbeebub Posted 2 hours ago Author Posted 2 hours ago 15 minutes ago, Mattg4321 said: That’s not true. Half the world bases oil prices against the benchmark Brent Crude, which comes from the North Sea. It’s light sweet oil that is perfect for making into transport fuel. There are also heavy oil fields in the North Sea. Some as yet untapped. See the Bentley field. Yes but the Brent field has long stopped production and what is referred to as Brent crude is actually from a number of fields as far afield as Texas. Of those oilfields only Forties is in the UK and there current produces about 10k barrels a day. Again, all the fields you mentioned (and some fields not yet discovered) are in those estimates given earlier - the ones where production still falls from it's current level of 50% of our current requirements. 21 minutes ago, Mattg4321 said: That makes little sense if there’s no demand for it then. Perhaps renewables/nuclear or something else will be the future. Or perhaps not. But either way you can’t shut the whole industry down, lose all the experience, skills and infrastructure and expect to just turn it back on in a few decades. Naive in the extreme. Which is why it's important that we wind down the industry in a controlled manner. If only there was another industry that required workers used to working on large steel structures with lots of mechanical plant out in the north Sea. 1
ProDave Posted 2 hours ago Posted 2 hours ago Before you keep banging the net zero drum, watch both of these with an open mind. I am not anti green energy, but I am against the current Net Zero at all cost policy we seem to be pursuing. We need a balanced approach along the lines of lets build renewable energy as quick as we reasonably can to power things that lend themselves to that power source, but keep some fossil fuel usage in particular using our own resources to their maximum extent for the sake of energy security and to avoid just "exporting the polution" pretending it is okay to do that.
dpmiller Posted 2 hours ago Posted 2 hours ago 8 minutes ago, Beelbeebub said: If only there was another industry that required workers used to working on large steel structures with lots of mechanical plant out in the north Sea and it's windy out there too...
Beelbeebub Posted 1 hour ago Author Posted 1 hour ago OK first off, Kisin is a racist, lying s**tbag and I cannot believe (I can) QT had him on. But he says we want to produce the cheapest possible, reliable abundant energy that we can. OK so wind and solar with battery for sub hour backup and gas for longer periods. 1
Mattg4321 Posted 1 hour ago Posted 1 hour ago 18 minutes ago, Beelbeebub said: OK first off, Kisin is a racist, lying s**tbag and I cannot believe (I can) QT had him on. But he says we want to produce the cheapest possible, reliable abundant energy that we can. OK so wind and solar with battery for sub hour backup and gas for longer periods. What about coal? That’s a pretty serious allegation to make. Have you got any examples of him being racist or lying?
-rick- Posted 1 hour ago Posted 1 hour ago 2 minutes ago, Mattg4321 said: That’s a pretty serious allegation to make. Have you got any examples of him being racist or lying? 1
Mattg4321 Posted 1 hour ago Posted 1 hour ago 2 minutes ago, -rick- said: Does he say later that he’s British in the second clip? I think I would tend to agree that Sunak is not English in the ethnic sense. It depends on how you define it though. If he maintains that someone who is not ethnically English, is British rather than English, so what. That doesn’t mean he’s racist - look up the definition. The guy is an immigrant himself.
Mattg4321 Posted 1 hour ago Posted 1 hour ago 40 minutes ago, ProDave said: Before you keep banging the net zero drum, watch both of these with an open mind. I am not anti green energy, but I am against the current Net Zero at all cost policy we seem to be pursuing. We need a balanced approach along the lines of lets build renewable energy as quick as we reasonably can to power things that lend themselves to that power source, but keep some fossil fuel usage in particular using our own resources to their maximum extent for the sake of energy security and to avoid just "exporting the polution" pretending it is okay to do that. Open mind not possible for some people. Net zero is a cult.
-rick- Posted 1 hour ago Posted 1 hour ago 1 minute ago, Mattg4321 said: If he maintains that someone who is not ethnically English, is British rather than English, so what. That doesn’t mean he’s racist - look up the definition. The guy is an immigrant himself. A white person born in england to two white immigrant parents would never be questioned as to whether they were English. They would look and sound like the locals and it just wouldn't come up. Making a distinction (and therefore providing different treatment) about someone due to the colour of their skin meets the definition in my book. There is also no such thing as an 'English' ethnicity. Nationality sure (though we are weird in this country with British being the formal nationality). 1
Mattg4321 Posted 48 minutes ago Posted 48 minutes ago 5 minutes ago, -rick- said: A white person born in england to two white immigrant parents would never be questioned as to whether they were English. They would look and sound like the locals and it just wouldn't come up. Making a distinction (and therefore providing different treatment) about someone due to the colour of their skin meets the definition in my book. There is also no such thing as an 'English' ethnicity. Nationality sure (though we are weird in this country with British being the formal nationality). Kisin says himself that he’s ’brown skinned’, so why would be racist towards non whites. Your reasoning is a case of 2+2=5 If English is not an ethnic group then why is it in the census? There are ethnic groups whether you like it or not. If I walked round a city filled with entirely Slavic peoples then I would realise it pretty quickly. Similarly if they were Latin or Asian or whatever. Stating the obvious doesn’t make someone a racist other than in the kind of someone who has already made their mind up.
