joth Posted May 23 Posted May 23 2 hours ago, nod said: The problem that you have with switching to HPs Is in most homes the the running costs are considerably more than gas and are better suited to UFH Isn't this topic about a new build self build where UFH can be installed and running costs will be much lower. I really can't see how debating hydrogen in some far off future is a useful thing to consider when building a brand new house at this point in time 1
nod Posted May 23 Posted May 23 5 minutes ago, joth said: Isn't this topic about a new build self build where UFH can be installed and running costs will be much lower. I really can't see how debating hydrogen in some far off future is a useful thing to consider when building a brand new house at this point in time 🥱
Ed_ Posted May 23 Posted May 23 Regarding gas cookers, the evidence shows that having a gas cooker is detrimental to your health, due to the emissions. If, like many here, you are aiming for an airtight house with MVHR then the recommendation seems to be to have a recirculating hood. I think the combination of the 2 would be bad news. 2
SteamyTea Posted May 23 Posted May 23 8 hours ago, nod said: government needs to be honest Or the installers.
JohnMo Posted May 23 Posted May 23 6 hours ago, LnP said: Dunkelflauten Are you German? Or just like using fancy words? So have to look then up.
Temp Posted May 23 Posted May 23 We wanted a gas hob but there is no mains gas in the village so we opted for a pair of 47kg LPG cylinders. These work very well with a cylinder lasting at least 18 months when we had kids to feed. Now they have left home probably 2 years? Can't remember when we last had to change one. They would probably be too expensive per kWH for heating but the absolute cost for running the hob is OK.
Oz07 Posted May 23 Posted May 23 Where I am in The country a gas connection is about 300 quid for newbuild. It's literally the cheapest service to bring on site. God knows why seems to be subsidised by govt. You'd think water was more important?! It's a no brainer for me I'd get gas every time. As for standing charge that isn't the case. If you don't have a gas meter you won't be paying a standing charge. Isn't gas the cheapest energy per khw for a standard punter? Also cooking on gas is something I prefer but haven't tried induction tbf.
JohnMo Posted May 23 Posted May 23 18 minutes ago, Oz07 said: Isn't gas the cheapest energy per khw for a standard punter Depends. I pay 6p per kWh for gas and two rates for electricity 13p and 29p. Add to the gas cost and efficiency of 85% the actual cost is nearly 7p for heating. If running a heat pump at night I get a CoP of between 3 and 4 depending on outside temperature. So 13/3 is 4.3p and 13/4 is 3.25p. So for a heat pump run on cheap rate, electric is quite a bit cheaper. Running in expensive period a heat pump is about the same cost on a cold day a limited expense. On a standard tariff of 25p for a normal punter I would get an average SCoP of just over 4 to 5 so then it's cheaper at all times of the day, to heat via a heat pump. Add a battery and PV it gets way more complex, but overall cheaper again for electric heating via heat pump. So overall on a new build you are not correct.
Wadrian Posted June 13 Author Posted June 13 Many Thanks everyone for your comments - looks gas will be a no, no for me.
JamesPa Posted June 13 Posted June 13 (edited) On 22/05/2025 at 12:55, Wadrian said: With that in mind was wondering if it is still worthwhile having a gas connection to the property? Definite no here. Having just retrofitted an ASHP to my 1930s house there is no way I would bother with gas in a new build. Its cheaper to run by about 20%, much more comfortable (because there are fewer thermal gradients due to the way it works) and can do cooling as well as heating. Whats not to like? Incidentally, ignore the people who falsely claim that hydrogen heating is the way forward. Hydrogen does have a place but not for domestic heating, its for applications where there isnt an alternative. There is a very simple reason for this - to be green (which is the argument for swapping to it in the first place) it has to be made from electricity, and this is a factor of 3 less efficient than a heat pump, so is guaranteed to cost much more. 'Hydrogen ready' is just filibustering by vested interests in the oil industry so they can continue to sell gas boilers. Edited June 13 by JamesPa 1
JohnMo Posted June 13 Posted June 13 To add to what @JamesPa says our new build (started in 2020) was originally gas. In 2023 we put in an ASHP. Messed about with hybrid and have now asked for the gas meter to be removed. Having gas meter standing charges are £110. Saving made running gas over ASHP near zero and below about £20 per year. Gas is costing me money (£90).
