Russdl Posted November 24, 2025 Posted November 24, 2025 Can you reject it under the sale of goods act as ‘…not being of merchantable quality…’? 1
JohnMo Posted November 24, 2025 Posted November 24, 2025 I was thinking "not fit for purpose" it's not a ventilation unit as required by building regulations. So therefore not compliant with BR or manufacturer installation instructions. Several reasons as you have detailed before, recirculation of smells, high humidity etc. 1
Jolo Posted November 24, 2025 Posted November 24, 2025 Exactly right @Russdl and @JohnMo! I've gotten a template letter from the government's consumer authority, and I'm going to send it shortly. It gives them two weeks to repair or replace it, and if that doesn't happen then I can terminate the purchase agreement unilaterally and they have to give me the money back. I'd really prefer that it didn't have to come to this, but I don't see any other option as nothing is happening.
Russdl Posted November 24, 2025 Posted November 24, 2025 19 minutes ago, Jolo said: and I'm going to send it shortly. Hopefully that will be sufficient to concentrate their minds. Good luck. 1
Mike Posted November 24, 2025 Posted November 24, 2025 6 hours ago, Jolo said: On 20/11/2025 at 13:43, torre said: You mentioned a smoke test earlier, has this been done? It sounds the obvious next step. Not yet! Why not get some smoke pellets & test it yourself? Take a video of of any problems. And disable your smoke detectors...
Jolo Posted November 25, 2025 Posted November 25, 2025 15 hours ago, Mike said: Why not get some smoke pellets & test it yourself? Take a video of of any problems. And disable your smoke detectors... I might try this, though I'm not sure if it will hurry Brink up at all. I feel like I've dotted every i and crossed every t, and asked here and elsewhere to test my sanity!
Adsibob Posted January 3 Posted January 3 On 20/11/2025 at 12:28, Jolo said: we're running the unit at around 0.45ach This sounds very low to me, but I may well be wrong. If you increase the ventilation to at least 1 ach you will drop the humidity. You might also improve the smell issue.
Adsibob Posted January 3 Posted January 3 Actually, ignore me. I’ve just checked approved doc F off the Regs, and that only requires 0.3ACH so 0.45 is fine. Have you had works done recently (eg poured slab or screed or plasterwork which could still be wet, that would explain the excess humidity?
Jolo Posted January 5 Posted January 5 Nope nothing like that! I'm very sure that the high humidity is because of a leak inside the MVHR unit, so there's extracted moisture being blown into the house along with the smells.
Jolo Posted Monday at 15:10 Posted Monday at 15:10 Well I said I'd provide updates, but there's nothing much to update other than to say I'm really disappointed with the customer service I've had from Brink. In early December they sent an installer who swapped out the whole unit with a new one which, to our amazement, behaves in exactly the same way. I know you'll think I'm mad, but there is definitely strong odour transfer between the extract and supply ports. We tested this new unit, again just via the ports on the top (to exclude any internal ducting issues) and the problem is the same. I wonder now if Brink have a design flaw or manufacturing issues with the Flair 200/225. The technician from Brink who came checked out our ducting and external connections, and said it all looked very neat and well-installed. I also got him to smell-test the old unit, which he did reluctantly (not sure why, it only takes a minute), and he acknowledged the problem. I didn't do another one on the new unit before he left, as it never entered my mind that the replacement unit would have the same issue. I clearly trusted them too much! So I emailed the supplier and Brink, explaining that this new unit had the same problem, and they wrote back telling me they were going to thoroughly inspect the returned unit, and would get back to me hopefully by the end of December. Well it's now February, and I still haven't heard anything at all. They even seem to ignore the supplier when he emails them (at least, they don't include me if they do reply!). So I've had to send a legal email to the supplier, cancelling the purchase contract due to defective goods. I didn't want to do this, I'd much rather they fixed the issue but they just don't seem interested. I'm not sure how they'll respond to this, I hope they just take it away and refund the money, I have no trust in Brink any more.
Mr Punter Posted Monday at 15:30 Posted Monday at 15:30 How very odd. This sounds like a fundamental design issue as the two flows should not meet. Get a refund and maybe try another brand, like Vent Axia.
Iceverge Posted Monday at 22:11 Posted Monday at 22:11 (edited) Very strange indeed but it's not entirely impossible there's a bad batch of seals or heat exchanger a floating around. It would be easy enough to set up a rig to pressurise one side of the unit and see if it leaks out. I'm thinking a couple of bungs, a Schrader valve and a bicycle pump. Pressurise the exhaust(or inlet) side and see if it leaks out immediately. Perhaps something as simple as a dab of sealant would be enough to cure it. Edited Monday at 22:17 by Iceverge
Jolo Posted 7 hours ago Posted 7 hours ago Agreed, it can only be something such as a design issue or manufacturing flaw. Either way, I've sent the legal email cancelling the purchase contract due to defective goods (and it's been acknowledged) so I guess legally it's Brink's unit now, and I'm just waiting for them to collect it!
ProDave Posted 7 hours ago Posted 7 hours ago Just footnote to confirm smells should not transfer around the house. I had to paint some stuff with Hammerite recently and it was way too cold to do so in the garage, so I painted them in the utility room and kept the door shut. Stinky stuff Hammerite, but not the slightest whiff of it anywhere else in the house.
JohnMo Posted 5 hours ago Posted 5 hours ago 1 hour ago, Jolo said: so I guess legally it's Brink's unit now, and I'm just waiting for them to collect it! So what are you replacing it with? Enthalpy or normal heat exchanger?
Jolo Posted 4 hours ago Posted 4 hours ago 52 minutes ago, JohnMo said: So what are you replacing it with? Enthalpy or normal heat exchanger? Great question -- and one which I've been pondering a lot, so any input is welcome! The main benefit of the enthalpy exchanger, besides not drying the air out, is that there's no convenient drain point right now, so it felt worth the extra price. While the main house drain passes directly beneath the MVHR cupboard, there are two concrete floors in between them, and that was putting me off it last summer! But adding a condensate drain doesn't feel too difficult now I've discovered those drill-patch-pipe things that just clamp on. The enthalpy exchanger options I've found are mostly Zehnder, a few units in the confusingly broad ComfoAir range, which are a few hundred euros more expensive than the Brink we have. The Q350 for example. The main down-side of the Q350 is the size, it's got a maximum airflow of 350 m3/h, which is much larger than we need, and so the unit is physically larger, although I think would just about fit in the MVHR cupboard with maybe 15cm space on each side. It's also a lot heavier at 48kg, so I'd be tempted to get an installer to fit it. The upside of that unit is that, as our top airflow is 180 m3/h, and we typically run it around 70 m3/h, we'd always be running it very slowly, which should mean it's super-efficient. For non-enthalpy units, having looked at other brands, Zehnder is of also a popular choice there, and they have options which cost less than the Brink we have now. I also quite like the look of the Duco Energy Comfort units, they've just introduced a 250 m3/h unit which would fit the bill, although I can't find it listed for sale yet. https://www.duco.eu/uk-ie/products/mechanical-ventilation/ventilation-units/ducobox-energy-comfort 1
JohnMo Posted 4 hours ago Posted 4 hours ago Titon HRV also sold by Beam under a different badge and lower price point. You can get enthalpy exchangers if you want
-rick- Posted 4 hours ago Posted 4 hours ago 11 minutes ago, Jolo said: I also quite like the look of the Duco Energy Comfort units, they've just introduced a 250 m3/h unit which would fit the bill, although I can't find it listed for sale yet. https://www.duco.eu/uk-ie/products/mechanical-ventilation/ventilation-units/ducobox-energy-comfort Looks interesting. Wonder how their multizone stuff works with building regs.
