Ferdinand Posted October 31, 2017 Posted October 31, 2017 My untreated oak veneer doors have just arrived, and will need treating. I am looking at either normal Osmo oil, or Polyx Oil - also by Osmo and iirc a harder finish. Sprayable versions do exist, albeit at the usual slightly eyewatering prices . I can live with that for only a few litres. http://www.osmouk.com/retail/product.cfm?product=359 Has anyone tried spraying their doors? Are there any lessons to learn? Cheers
Mikey_1980 Posted October 31, 2017 Posted October 31, 2017 The Polyx oil isn’t recommended for use on wood veneer doors as there is a small chance it could cause delaminating. We used the Osmo door oil, applied with a cloth, 3 coats on each of our 22 doors, it took a while but the finish looks great, and just as good as our kitchen worktops which were sprayed.
Lesgrandepotato Posted October 31, 2017 Posted October 31, 2017 I've been doing our internal doors, you can do one with a brush in 20mins or so with a brush, just go lightly on the cover so it doesn't run everywhere. It'll take longer to mask them up and spray them 1
Ian Posted October 31, 2017 Posted October 31, 2017 37 minutes ago, Lesgrandepotato said: I've been doing our internal doors, you can do one with a brush in 20mins or so with a brush, just go lightly on the cover so it doesn't run everywhere. It'll take longer to mask them up and spray them I agree. We did our oak laminated doors with Osmo Polyx using a brush and it was very quick and easy.
Stones Posted October 31, 2017 Posted October 31, 2017 3 hours ago, Lesgrandepotato said: I've been doing our internal doors, you can do one with a brush in 20mins or so with a brush, just go lightly on the cover so it doesn't run everywhere. It'll take longer to mask them up and spray them 2 hours ago, Ian said: I agree. We did our oak laminated doors with Osmo Polyx using a brush and it was very quick and easy. +1, Osmo Polyx, 20 -25 minutes per coat. Brush on, wipe off with lint free cloth. Great finish (far better IMHO than the pre-finished doors you get)
Jeremy Harris Posted October 31, 2017 Posted October 31, 2017 We used Doordeals oak veneered doors and solid oak facings, architrave, skirting and stairs, and used brushed Osmo oil every where. Pretty quick to do, but a fair bit of effort needed to get the oil worked in to every crevice. The process we used was to rub every bit of timber down, along the grain, with a green (coarse) Scotchbrite pad. The timber was then wiped over with a barely damp clean rag, wetted with white spirit. The Osmo oil was then applied neat, with no thinning, and brushed in well. As above, it took around 20 minutes per coat (less for me, more for SWMB). I laid newspaper under the door gaps to catch any drips. Before subsequent coats the timber was rubbed down lightly with a clean Scotchbrite pad, to de-nib the surface. The doors got two coats (they were going to get three, but two seemed plenty) and the stairs got three coats. We used the satin finish Osmo and spent some time with the (Purple) Scotchbrite pads rubbing with the grain on all finished surfaces that were to be touched (banisters etc). This has given a very smooth and hard wearing surface, and I'm frankly amazed at how well the stairs have stood up to what's been a lot of traffic. When they have got a bit scruffy, I've wiped them down with a rag and white spirit, used a green Scotchbrite to remove any marks, then given then another coat, and they come up like new, every time. I do have a tin of the tougher Polyx here, but have yet to try it. I was thinking of using it on the stair treads, unless someone says otherwise. Osmo oil may seem expensive, but it does go along way and needs very little time to apply, so I thing that, in the long run, it's probably pretty good value.
Grosey Posted October 31, 2017 Posted October 31, 2017 Can anyone share photos of their doors that have had 2+ coats of the Osmo door oil (or polyx I suppose)? I’ve just done my first coat on some of our doors but I’m worried about them getting too dark/rich coloured.
Stones Posted October 31, 2017 Posted October 31, 2017 @Grosey Scroll down my blog entry for a picture
Lesgrandepotato Posted November 1, 2017 Posted November 1, 2017 9 hours ago, Grosey said: Can anyone share photos of their doors that have had 2+ coats of the Osmo door oil (or polyx I suppose)? I’ve just done my first coat on some of our doors but I’m worried about them getting too dark/rich coloured. I worried about this with our stairs and newels, but it seems to me that over the week or two after applying they seem to gently lighten up, also the second coat is nowhere near as extreme as the first.
Crofter Posted November 1, 2017 Posted November 1, 2017 Has anybody had problems using Polyx over veneer? Wondering whether to take the chance since I've got enough left in the pot. I could test it out on the inside of a cupboard door, I suppose.
Ian Posted November 1, 2017 Posted November 1, 2017 39 minutes ago, Crofter said: Has anybody had problems using Polyx over veneer? Wondering whether to take the chance since I've got enough left in the pot. I could test it out on the inside of a cupboard door, I suppose. We were concerned about this but we used Polyx on our oak veneered doors and they've been fine. No problems at all since we put the Polyx on 9 months ago.
Stones Posted November 1, 2017 Posted November 1, 2017 @Crofter I've used Osmo Polyx on our Oak veneered MDF window cills and shelving without issue.
Crofter Posted November 1, 2017 Posted November 1, 2017 Thanks both. I'll start with the back of the cupboard door just in case- I've only got two doors in the whole house so not a big job!
Grosey Posted November 1, 2017 Posted November 1, 2017 The Osmo door oil isn’t much more expensive, so I didn’t see it worth the risk. Got it from wood finishes direct with I think free next day delivery.
OldSpot Posted February 4, 2022 Posted February 4, 2022 (edited) @Ian I know this is going back a while but presume still no issue with the doors and Osmo Poly-x? Edited February 4, 2022 by OldSpot
Faz Posted February 4, 2022 Posted February 4, 2022 Just done 3 plots in Osmo Polx Clear Matt - and my stairs come the think of it. Great stuff - well worth the money.
Stones Posted February 5, 2022 Posted February 5, 2022 13 hours ago, OldSpot said: @Ian I know this is going back a while but presume still no issue with the doors and Osmo Poly-x? 5 years on and no issues for us.
Temp Posted February 5, 2022 Posted February 5, 2022 13 years and two kids on our osmo floor and stairs. No sign of needing a recoat. Some slight wear to the bull nose on bottom step due to people using it to avoid bending down to put on shoes grrr. Occasionally gets mopped with a damp mop.
SimonD Posted February 5, 2022 Posted February 5, 2022 I'm rapidly becoming a fan of Rubio Monocoat instead of Osmo. It's a dream to apply and as per the tin it only needs one coat - touch up is simple and invisible where needed. I can't personally attest to longevity yet.
Ian Posted February 9, 2022 Posted February 9, 2022 On 04/02/2022 at 19:13, OldSpot said: @Ian I know this is going back a while but presume still no issue with the doors and Osmo Poly-x? No, the Osmo Poly-x has been great - no issues at all with it in the 5 years since we did the work.
