Has anyone fabricated TF wall cassettes using i-beams instead of dimensioned timber?
efkor
Hi, I'm on a first-time self-build in Cumbria and I have am about to instruct a timber frame designer. I intend fabricating the wall and roof cassettes myself and I'm unsure whether to replace the dimensioned timber studs with i-beams. Reasons to use i-beams are (1)reduced cold bridging and (2)avoids wrangling with bent/twisted timber.
Initially, I was just going to replace the inner studs with i-beams but my TF designer says that I can replace top and bottom plates and the side plates too. He mentioned that I would have to add packer plates and that the window area would need to be boarded in ply. He didn't elaborate on fixings but I'm having trouble imagining how I'm going to nail up a cassette made entirely from i-joists. I've seen angled nail-plates in JJI brochures but this leaves me none the wiser.
I've seen that a few of you have used i-joists. Can you give me some pointers on connections please? Or should I just stick to replacing the inner studs. Thanks for your help
Edited by efkor
placed in wrong section
All I can say is that nailing them to achieve a 90 joint is no fun. I eventually gave up and where I have 90 deg junctions, around windows, I used Simpson strong tie 90 deg brackets with a backer piece in the reverse webs to take the screws.
When I get around to making my new shed, this is how I intend to do it.
For a house some analysis of buckling will have to be done.
Adhesive bonding.
Adhesive bonding.
A buckling analysis is another reason to avoid the i-beam solution
Adhesive bonding is way less fun than nailgunning!
7 minutes ago, Russell griffiths said:
Why build them into a cassette ?
stick build it on site and clad it in osb all on-site.
theres 3-4 that have done this i believe.
@Gone West and @Patrick
Yes, stick build is an option but the problem of the filler plates and the awkward i-beam to i-beam connections still remains
13 hours ago, Adrian Walker said:
That's very useful, thanks Adrian. I see how they have minimised the number of troublesome i-beam to i-beam connections that are so prevalent in a cassette. They use a portal frame structure and hang the floor cassettes from the internal face of the 2-storey wall. Unfortunately, I can't use a portal frame solution on my site.
Our tf was built from JJI's. Get a copy of the James Jones technical guide. It details the connections.
Where reinforcement was needed they were packed with osb and then nailed together. At right angles, such as window openings they were nailed like normal timber.
Edited by jamieled
Hiya.
Well done you! it seems you are now getting into making big design decisions on the structure and how that interacts with all the other elements of the design.
That all sounds great on paper but in practice unlikely to work given the nature of self building.
It's your first self build so you have a huge amount to learn. I joists are good for carrying bending loads, say a floor. They are generally less appropriate for compression loads, say where you have openings with point loads from above.
My advice is to avoid as the detailing and connection design will be horrendous / costly and unlikely to be "self" buildable.
Take the hit on thermal bridging and consider standard solid studs or something like a space frame. @Kelvin has done a cracking job using a space frame and has lots of practical knowledge on how you make it work and the pitfalls.. to avoid.
Sounds like good pragmatic advice... when my TF designer said there's no problem in designing cassettes using i-beams, he was probably referring to work he's done for building firms. Maybe he wasn't considering the buildabiliity of it for a novice self builder like myself. I've seen the connection details in the JJI manuals and they are scaring me off a little. I might give myself a break, just do a "normal" cassette with solid studs, enjoy some straightforward nailgunning me-time and save the brainwork for other technical stuff, such as ASHP, MVHR etc :)
I'm not clear on what you feel is the advantage of building your own cassettes. I'm not sure there are awkward connections, there's just different detailing required compared to using solid timbers, and yes, if you need to fit to the side of an I-Beam you're likely to need to pack the web out to the same thickness as the flanges.
There's a significant performance advantage to an I-Beam (or twin-stud) structure, it's worth investigating further. If you've also got a frame designer lined up that's confident, it takes the burden off you needing to know every detail beforehand. I've got a pretty comprehensive 3D model of my frame and am happy to post images of any junctions you are not clear on.
Ply lining the window apertures gives a clean surface for the windows to fix into and an easy surface to tape to for good air tightness. The I-Beams weren't packed out though, the ply "just" went across the flanges.
Edited by IanR
We used 350mm portal frames which were made in the factory in two halves for easy transporting. They were joined on site and lifted into position. We used timber I beams for all of the structure, so no solid timber or steel. The whole frame was covered in 15mm OSB3 as racking. I then routed out the openings when the weather improved.
All my windows are framed with plywood. I added that after the fact, which wasn’t easy, once I realised the difficulty I was going to have sealing and taping the windows without a flat surface to fix to. There was one window I didn’t frame (dormer window) and it was a challenge to get the airtight membrane fitted around the frame and then taped for airtightness. I also added the airtightness membrane along the roof/wall junctions before the roof went on.
Edited by Kelvin
Thanks very much everyone for your comments. If I hadn't already spent 4 months on getting my SE to produce drawings, I might be looking seriously at switching to the portal frame solution of Gone West. And looking at the impressive i-beam structure from IanR, I can see what is possible. As you say Ian, the connections are just different to the solid wood connections.
A good question raised is why I am making cassettes onsite instead of doing a stick build. The reason is connected to the fact that I am a solo builder and I have a 2-storey brick house that I am extending upwards, back and sideways into a 3-storey house. To enjoy the build process, I will fabricate the cassettes precisely in the ground floor "workshop" away from the vagaries of the Cumbrian weather. After creating and storing all the cassettes for the ground floor, I will then enlist a couple of helpers for one day to erect them. Repeat for the other two storeys. And how do I get the cassettes up to those floors? I've bought a used half-ton hoist (£600) and installed it above the (removable) stairway. And moving the cassettes around is achieved with used heavy-duty skates (all my kit is purchased from BPI the online auction site).
Consequently, the cassettes will have maybe 4 or 5 times the number of connections that occur in a Gone West or an IanR type structure. On reflection, with all of the extra work required on connections and packing the voids (there lots of 2 and 3-ply also) I think I will go with solid timber and take the hit on thermal efficiency. My wall insulation is 175mm stud plus 40mm EWI and I think the cheaper solid beams will subsidise the cost of the EWI.
By the way, Norbert, I left phone messages with Eden Insulation last week and received no reply. I drove to their premises in Appleby this afternoon and the office/workshop was closed up. Maybe they've gone out of business? They have a great product ... I hope that they stick around.
Good man.
Once set up I find making repeat items quite relaxing.
  • 3 weeks later...
Yes they are still in business and fully booked until the autumn, but the are only a small company, perhaps they were away on site.
